If a VIP TFR says "AIRCRAFT FLIGHT OPERATIONS ARE PROHIBITED WITHIN THE FOLLOWING AREAS UNLESS OTHERWISE AUTHORIZED BY ATC IN CONSULTATION WITH THE DOMESTIC EVENTS NETWORK (DEN)", does an IFR clearance thru the TFR qualifies as "authorized by ATC"? In this particular case, I'm referring to TFR http://www.aopa.org/whatsnew/notams.html#6/5316 that covers the PAE airport. As my luck turns out, I might have to land there right during the time when TFR is active this Sunday. |
"M" wrote in message
oups.com... [...] In this particular case, I'm referring to TFR http://www.aopa.org/whatsnew/notams.html#6/5316 that covers the PAE airport. As my luck turns out, I might have to land there right during the time when TFR is active this Sunday. The way I read the AOPA info you linked to, "ATC authorization may be provided for GA". To me, that says that you *might* be able to get ATC authorization into the TFR (presumably for the purpose of landing or taking off from PAE). Of course, they would have the option of refusing a clearance. But with a TFR like that lasting 19 hours, I can't imagine they are actually going to keep the airport closed for the entire time. That said, the weather's gonna suck all day Sunday anyway. Hope you have deice equipment on your airplane. ![]() Pete |
On 13 Apr 2006 17:03:00 -0700, "M" wrote:
If a VIP TFR says "AIRCRAFT FLIGHT OPERATIONS ARE PROHIBITED WITHIN THE FOLLOWING AREAS UNLESS OTHERWISE AUTHORIZED BY ATC IN CONSULTATION WITH THE DOMESTIC EVENTS NETWORK (DEN)", does an IFR clearance thru the TFR qualifies as "authorized by ATC"? Normally as they have it listed even VFR into and out of the airport is probably permitted. As I recall you just need to make sure they give you permission to enter the TFR unlike those big ones with the 10 mile no fly zone. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com In this particular case, I'm referring to TFR http://www.aopa.org/whatsnew/notams.html#6/5316 that covers the PAE airport. As my luck turns out, I might have to land there right during the time when TFR is active this Sunday. |
M wrote:
If a VIP TFR says "AIRCRAFT FLIGHT OPERATIONS ARE PROHIBITED WITHIN THE FOLLOWING AREAS UNLESS OTHERWISE AUTHORIZED BY ATC IN CONSULTATION WITH THE DOMESTIC EVENTS NETWORK (DEN)", does an IFR clearance thru the TFR qualifies as "authorized by ATC"? In this particular case, I'm referring to TFR http://www.aopa.org/whatsnew/notams.html#6/5316 that covers the PAE airport. As my luck turns out, I might have to land there right during the time when TFR is active this Sunday. Call the controlling facility TODAY before close of business and get their honest opinion on what to expect. I'm sure FSS somewhere will have the facility number, or the AFD will. Dave |
M wrote: As my luck turns out, I might have to land there right during the time when TFR is active this Sunday. So, what happened? |
Well, my schedule was a bit off for other reasons, so by the time I flew the TFR was no long covering the airport. I did see the Dick Cheney's motorcade on the freeway and his escort helicopter flying over my house at about 200ft though. wrote: M wrote: As my luck turns out, I might have to land there right during the time when TFR is active this Sunday. So, what happened? |
| Thread Tools | |
| Display Modes | |
| Flying on the Cheap - Instruments | [email protected] | Home Built | 24 | February 27th 06 03:30 PM |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| Passing of Richard Miller | [email protected] | Soaring | 5 | April 5th 05 02:54 AM |
| Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 | [email protected] | Piloting | 0 | April 3rd 05 09:48 PM |
| ADV: CPA Mountain Flying Course 2004 Dates | [email protected] | Piloting | 0 | February 13th 04 05:30 AM |
