MRA Question
Old April 15th 06, 06:18 PM posted to rec.aviation.ifr
Default MRA Question
Hi,
Reference IFR enroute L-1, panel C (64 south of SEA), MALAY
intersection is defined by:
The intersection of V23 and V287, each having an MEA of no higher than
6000;
DME distances on each of the airways; and
A cross-radial from the Astoria VOR, located ~55 NM west of the
intersection.
MALAY has an MRA of 9500.
Question: if MEA ensures an adequate navigation signal at 6000, then
why the MRA of 9500?
If I'm equipped /U, can I fly V23-MALAY-V287 (or reversed) below 9500?
Thanks in advance!
Old April 15th 06, 06:41 PM posted to rec.aviation.ifr
On 04/15/06 10:33, Mark Hansen wrote:
On 04/15/06 10:18, wrote:
Hi,
I don't have that chart, so I can't look at the specific case, but...
6000;
intersection.
The MRA is defined so that you can navigate the airway, it's defined so
Oops, I meant to say "The MRA is *not* defined so that you can navigate
the airway..."
sorry about the confusion.
you can receive the off-airway station which is used to define the
intersection for fix.
Do you need to be able to identify the fix? Without seeing the chart, I'm
not sure. If you do, then you just need some way to identify it - what
method you use is up to you. If you can't receive the off-airway station,
then DME would work.
Basically, if you need to identify that fix with the off-airway navaid,
then you need to be at the MRA to be sure you'll receive the station.
Thanks in advance!
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old April 16th 06, 02:19 PM posted to rec.aviation.ifr
Hi,
6000;
intersection.
Thanks in advance!
Assuming Slant/U:
It's a bit confusing because MALAY is located at the turn point of those
airways. But, the turn point does not have to meet the same fix
tolerances as an intersection must meet for reporting or holding.
You would treat this as any another non-compulsory reporting point.
There is no requirement for you to file an altitude that will meet the
reception requirements of a non-compulsory reporting point, nor would
ATC require you to report or hold at that fix if you are assigned an
altitude below 9,500.
You do not need to identy MALAY to make the course change for V-23.
But, since MALAY is also an MEA change point for V-23 you could not use
the lower MEA (applicable only to a cruise clearance or lost comm) until
you had determined with certainty by other means that you were in the
airway segment with the lower MEA. Two-way MEAs in both segments of
V-23 doesn't make it any easier but, again, that is usually academic.
Lyc. O-360 cylinder question JB Owning 13 November 27th 04 09:32 PM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 03:07 PM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Question Charles S Home Built 4 April 5th 04 09:10 PM
Partnership Question Harry Gordon Owning 4 August 16th 03 11:23 PM
