Torsional Vibration and PSRU Design
Old April 15th 06, 11:23 PM posted to rec.aviation.homebuilt
Default Torsional Vibration and PSRU Design
My original remarks and the quote was in response to the following
statement you made:
Gordon Arnaut wrote: "Yet another source of excitation in airplanes is
the spring effect of the prop, where the blade tips whipsaw back and
forth as they undergo acceleration and deceleration due to the torque
spikes of cylinder firing."
I had assumed that you were refering to the potential of the blades to
flex parallel to the axis of the hub due to variations of blade loading
created by the periodic variations of torque. I made that assumption
since you were describing the prop as the source of the excitation and
yet still made specific mention of the engine torque variations. I had
once thought axial loading and flexure might feed back into the system
at one time myself, but Ker states that it does not( except in
extraodrinary cases), which I took note of in my studies -- thus the
quote. If you were not refering to axial vibrations, then your
statement is silly since you identify the prop ( or its spring effect)
as the source of excitation and yet you end the statement with the
actual excitation source ( torque spikes ). Alter the frequency of the
"torque spikes" and the system returns to normal.
Dan is the one that brought up blade interactions with disturbed
airflow. And I quoted the passage regarding issues of a non axial
airstream (which is not the same as disturbed airflow).
Even via he prop, Wilson is relatively proscriptive:
Wilson wrote: "The airscrew is one source, of aerodynamic origin,
arising from the passage of the blades through a non-uniform airstream,
or due to the airstream entering the airscrew disc obliquely when the
aircraft is executing certain manouevres ...."
The phrase "of aerodynamic origin" when not cropped out is the
significant part. You may want to claim the prop as a source since it
is complicit in the translation of the vibrations, but the same could be
said of the crank, so whats the point? In any event you state:
the spring effect of the prop"
The Wilson quote mentions nothing of spring effectof the prop as a
source of excitations and in fact if you think about it you will see (
or at least most people would) that the vibrations "of aerodynamic
origin" do not require any springiness of the prop blade to impinge upon
the system.
And I didn't even bother to comment on this gem of yours:
Gordon Arnaut wrote: "My original point was that if you have a flywheel
with enough inertia, it will be an effective restraining force to act
against excitations that would otherwise produce vibration."
Which is just plain wrong. In the industry I work in there are machines
with moments of inertia measured in tons and they are still subject to
torsional vibration issues. Upping the moment of inertia just alters
the resonant frequency ranges. Without damping of some sort, excitation
in the critical range will still drive the system into resonance. If
you meant to say "if you have a flywheel with enough inertia, it will
lower the resonant frequency of the system to a range conducive to safe
operation" that would be a different thing.
Charles
Charles,
What exactly are you saying? Once again, I find myself scratching my head
trying to fathom your actual point. You are nothing if not a master of
obfuscation.
I said very plainly in my original post that the prop is a source of
excitations, as is the cylinder firing of the engine, as well as imbalance
in the system.
I don't know who said what, but your post contained this in quotation marks:
"In aero-engine/airscrew systems there are, in general, two series of
excitations. The airscrew is one source..."
So whoever said that, whether it is you or Wilson, it is quite plain and
quite true. The Prop IS a source of excitations, whether they are of
aerodynamic origin or whether they are due to resonance.
If you disagree with this, please say so plainly, otherwise do not try to
muddy the waters further -- it is only doing a disservice to the discussion.
Regards,
Gordon.
"Charles Vincent" wrote in message
et...
Actually Gordon, the words you quoted were my words not Wilson's. You
will notice there are no quotaion marks around them in my original post.
The text with the quotation marks is from Wilson. The excerpt was
actually confirming Dan's contention that the excitation source was
disturbed airflow, that it does not originate in the prop. Take the
disturbed airflow away and the natural hysterisis of the prop and rest of
the system will cause it to return to normal. So while excitations can
enter through the prop or they can enter through the crank, these two
components don't create the excitation, they react to them. There are
components in a redrive system that can originate excitations though,
which is why if you just want to fly it is easiest to pick a direct drive
wooden prop snd go fly. Not guaranteed, but much simpler.
Charles
Charles,
Thanks for that snippet from the Wilson book.
Please note the part where he says how the "flexural properties of the
propellor are key in determining how the SYSTEM (my emphasis) will
respond to the excitations since the prop will resonate."
Is this not exactly what I said about the prop beginning to resonate and
then cuasing something else in the system to break?
I have said all of this in my posts, with the exception of the part about
prop excitations arising from aircraft manouevers, which is really part
of the point about distubed flow.
Thank you for confirming the correctness of my position. For the record
now, I don't think there can be any serious question that the prop does
not contribute a very real component to the excitations side of the
equation.
Regards,
Gordon.
y.net...
Dan Horton wrote:
Hello Charles,
According to Ker Wilson, prop flutter has no real impact on
torsional vibration. He could be wrong, but he devoted more than a
half century to the subject. Blade passing frequency, however,
apparently does come into play in some systems. So does whirl, but
that isn't the internet topic of the year.
Ahh, thank you, appreciate the confirmation.
Lucky dog, wish I had my own copy. I have to beg my local
librarian to get it from the UA library.
Dan
A quote:
"In most practical cases coupled axial/flexural modes occur independently
of coupled torsional-flexural modes since there is usually no appreciable
coupling whereby component harmonics of the shaft torque are able to
excite symmetrical blade vibration."
And to your earlier point:
excitations. The airscrew is one source, of aerodynamic origin, arising
from the passage of the blades through a non-uniform airstream, or due to
the airstream entering the airscrew disc obliquely when the aircraft is
executing certain manouevres ..... The other series originates from the
non uniform character of the engine torque."
Hence the blade passing frequency. Still the flexural properties of the
propellor are key in determining how the system will respond to the
As far as modeling the propeller and determining its natural frequencies
(it has multiple as well) it appears to be a right bear. The shape is
complex and there are multiple modes of vibration and all of them have to
be adjusted for RPM because the stiffness varies with the centrifugal
force (the real kind). For an adjustable prop, the stiffness in the
plane of rotation changes with angle.
Charles
  #42
Old April 15th 06, 11:36 PM posted to rec.aviation.homebuilt
Are you saying the springs immediately begin to compress at the first
sign of torque? Hence the plot beginning at 0-0?
Very good Gordon. That is indeed what a 0-0 datapoint indicates.
I don't see how this is possible unless the springs were installed
without any preload at all.
You find out all kinds of interesting things when you actually
measure and think. Steady reliance on Google searches results in a lot
of GIGO g
My understanding is that the springs in a clutch disk are under
preload, so the torque has to rise to a certain level before they will
compress.
Some clutch disks are indeed that way. No need to start at 0-0
when designing a clutch for an engine that makes, say, 150 or 200
ft-lbs of torque at idle. They only need to be soft enough to set
system F1 well below idle speed.
If the springs had no preload, it would never be a solid coupling.
Very good Gordon! And even if they do have preload, as described
above, it still isn't intended to be a solid coupling when in
operation.
Again consider the lessons found in the Subaru clutch. The range
of torque capacity is 0 to 162 ft-lbs. A late 1980's EA81 was rated
73hp @4800 and 94 ft-lbs torque @ 2400. Don't know about idle speed
torque (anybody have a chart?), but let's guess 40 ft-lbs. So, we have
40 ft-lbs as we ease away from a stop, 94 ft-lbs in economy cruise, and
80 ft-lbs when pushing hard. Read carefully Gordon. All these numbers
are well within the range of 0 to 162. Actually they are all within
the single 1547 ft-lbs/rad spring rate found between 3.5 degrees and 6
degrees. Clearly engine torque has the springs in play at all times.
It would contantly be compressing and decompressing.
Give that man a gold star! Yes Gordon, overall angular
displacement of the clutch center varies with throttle position. At
the hertz level, angular displacement oscillates at the exciting
frequency.
How could that kind of clutch even be usable in a car? It would be
lurching all the time.
Think again.
Dan
  #43
Old April 16th 06, 12:16 AM posted to rec.aviation.homebuilt
Jim asks:
What was this rig-up on? What is it you do, Dan? It sounds
interesting. So, do you have a marketable Suzuki flying? What
association are you with the project?
Scale JN-4C. In the real world I'm an automobile dealer, and it is
not very interesting. However, it is a hell of a lot more profitable
than getting in the PSRU business, so the only Suzuki you can buy from
me comes with 4 tires and a horn.
The JN-4C project had several goals. A friend wanted to proof
custom software written to model torsional vibration in a complex
aircraft drive system (a pusher with with long shafts, might I add). I
wanted a new and improved PSRU. So, we modeled the old drive and then
altered the model for optimum predicted results. Then I designed a
drive to match the model inputs, built it, and ran it with telemetry to
check the accuracy of the predictions. Along the way we developed a
damper and tested it, ran two different props while I had the
telemetry, played with strobing linear vibration, and a whole bunch of
other stuff. End result was proven software and a pretty good PSRU,
plus an education.
Dan
  #44
Old April 16th 06, 12:34 AM posted to rec.aviation.homebuilt
Really wonderful stuff you've been posting here Dan.
Thank you very much for answering so many silly questions!
George Graham
RX-7 EZ with RD-1A Redrive.
On 15 Apr 2006, Dan Horton wrote:
Jim asks:
plus an education.
Dan
George Graham
RX-7 Powered Graham-EZ, N4449E
Homepage http://bfn.org/~ca266
  #45
Old April 16th 06, 01:57 AM posted to rec.aviation.homebuilt
plus an education.
Have you considered releasing some plans for the PSRU?
How about your JN project? Are there pictures anywhere?
Congratulations on your achievements. You should write a blog about it.
I'm sure it would be an interesting read.
Jim in NC
  #46
Old April 16th 06, 02:08 AM posted to rec.aviation.homebuilt
Today's multi-v belts -- the kind used to drive engine accessories on newer
cars -- are highly efficient and can handle huge amounts of power, up to
1000 hp.
Best of luck to ADK with his project.
Regards,
Gordon.
"cavelamb" wrote in message
Hmmmmm. If you are stating that a "serpentine belt", one that is a
about 1 inch wide and is used in most current vehicles will transmit
1000HP you might need to get another very stiff drink.
!!!!!!!!!!!!!!!!!!!!!!!!!!! G
Ben
  #47
Old April 16th 06, 02:21 AM posted to rec.aviation.homebuilt
plus an education.
Dan
Ya know, I really like this guy. This is "experimental" aviation at its
finest............................................ .
Only in America !!!!!!!!!!!!!!!!
Ben.
  #48
Old April 16th 06, 04:03 AM posted to rec.aviation.homebuilt
What is it you do, Dan? It sounds interesting.
It is refreshing to hear from someone who knows his stuff, unlike some
other
poster, as of late! g
Jim in NC
I can certainly second all of that--and add that I have deservedly stood
corrected for blindly reciting a few things I heard of read on an earlier
and vaguely related thread.
Pete
  #49
Old April 16th 06, 04:50 AM posted to rec.aviation.homebuilt
Dan Horton wrote:
Gordon says:
It works because the springs have a preload of a certain force and
will compress only when torsional oscillations reach a certain
amplitude.
Gordon, this is YOUR lucky day! You've bumped into the only guy on
the net who has actually measured the spring rate of clutch disks.
Gosh, Subaru, Chevy truck, Ford truck, Suzuki, a few others too! Let's
look at the spring data for an EA81 2WD clutch disk. No trouble, got
it right here on my hard drive.
Everybody draw a plot, torque up the left side, degrees rotation
across the bottom. Ready? Draw a straight line from 0-0 to 40 ft-lbs
at 3.5 degrees, and from there, proceed straight to 162 ft-lbs at 6
degrees. At a tad past 6 degrees, the springs bottom and the spring
rate becomes near infinite.
Gordon, you got that? Please show us the "preload" that "will
compress only when torsional oscillations reach a certain amplitude".
Dan
Gordon, if you preload the springs, what will protect your transmission
when you rev the engine and pop the clutch?
This is by far the hardest lesson about freedom. It goes against
instinct, and morality, to just sit back and watch people make
mistakes. We want to help them, which means control them and their
decisions, but in doing so we actually hurt them (and ourselves)."
  #50
Old April 16th 06, 04:58 AM posted to rec.aviation.homebuilt
Dan,
I wasn't talking about bottoming the springs, just compressing them in order
to introduce flexibility into the coupling and bring about a change in the
critical frequency of the system as a whole.
And this is exactly what happens. The springs do compress at a certain point
when the twisting oscialltions overcome the spring pressure and rotational
inertia. Up until that point the springs are not compressed and the coupling
is in effect a solid coupling.
As soon as the springs are compressed we have a flexible coupling that
changes the critical frquencies of the system.
Most clutches I've ever seen, you can easily twist the springs with no
problem. Some will even rattle just slightly.
Could you tell us what protects the transmission gears when someone revs
the engine and pops the clutch? How could this component do it's job if
it were already preloaded?
PSRU design advantages ADK Home Built 74 April 12th 06 09:31 PM
light twins? Bellsouth News Server Home Built 83 August 12th 05 02:56 AM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 06:46 PM
