WAAS GPS approach question.
Old April 20th 06, 03:06 AM posted to rec.aviation.owning
Default WAAS GPS approach question.
Hello,
I read on the Garmin page that their 480 is Waas certified...so that
you can fly precision approaches without an ILS... what does this
mean exactly? If I'm coming into an airport with only an NDB
approach, can I use the 480's capabilites to fly a precision approach
and get down to a lower MDA/DH?
-dr
Old April 20th 06, 04:02 AM posted to rec.aviation.owning
Hello,
It means you can use the LPV minima line on a RNAV(GPS) approach chart, and
that assuming your 480 was properly installed you can follow localizer-like
and glideslope-like needle guidance on that approach.
Old April 20th 06, 04:46 AM posted to rec.aviation.owning
"Dico" wrote in message
Hello,
If the airport has only an NDB approach, how are you going to fly a GPS
approach of any sort?
Old April 20th 06, 04:52 AM posted to rec.aviation.owning
Can you use the 480's glideslope to guide you into a VOR approach that
is NOT GPS, but using a descent gradient that will hit the altitude at
the waypoints as charted? Same approach as flying it by hand, just a
stabilized, even descent. Hope that makes sense.
Old April 20th 06, 05:00 AM posted to rec.aviation.owning
"Matt Barrow" wrote in message
Hello,
In other words, if there isn't a published approach, you can't invent one
for your own use. It's not legal and not safe.
Old April 20th 06, 07:05 AM posted to rec.aviation.owning
Assuming it's a VOR(GPS) approach, and not a circle to land only, Yes. The 480 provides VNAV
guidance suitable for LNAV/VNAV or if not charted, then referred to as "advisory VNAV", but basically it
works the same - you get vertical guidance to the runway.
Mike
Old April 20th 06, 07:31 AM posted to rec.aviation.owning
-dr
No.
But if you have an RNAV approach with precision/vertical guidance
component, (and I am presuming the approach lighting is up to snuff
before that type of approach chart is issued).. then you could use the
480 box to execute that approach without any ground based navaid guidance.
Dave
Old April 21st 06, 12:24 AM posted to rec.aviation.owning
WAAS Approaches have vertical guidance but they
are not classified as "Precision"
Bill Hale
Old April 21st 06, 02:01 AM posted to rec.aviation.owning
Officially, LPV refers to "Localizer Performance with Vertical
Guidance". Officially it's not precision, perhaps
not-so-non-precision. With horizontal and vertical accuracies in the
1-2m range, its arguably more accurate than a Cat III ILS. It does not
however,have the integrity of a Cat III. The LPV approach does indeed
have a decision altitude which currently is as low as 250ft HAT, and
the recent approval of 200' DA's will likely start showing up on
procedures next year.
Brad
GPS approach question Matt Whiting Instrument Flight Rules 30 August 29th 08 04:54 AM
GPS missed approach question xyzzy Instrument Flight Rules 15 September 15th 05 03:24 AM
Approaches and takeoff mins. jamin3508 Instrument Flight Rules 22 September 14th 05 03:51 AM
Contact approach question Paul Tomblin Instrument Flight Rules 114 January 31st 05 07:40 PM
Where is the FAF on the GPS 23 approach to KUCP? Richard Kaplan Instrument Flight Rules 36 April 16th 04 01:41 PM
