Buzzed?
Old April 22nd 06, 05:45 AM posted to rec.aviation.piloting,rec.aviation.ifr
Default Buzzed?
On Mon, 17 Apr 2006 00:01:55 -0700, "Peter Duniho"
"Mike Granby" wrote in message
roups.com...
[...] I wonder
if this was indeed an interception, but if so, wouldn't the controller
know? Coincidentally, or not, a small plane crashed into the terminal
at Gainesville just south of there around that time, so perhaps
"someone" felt there might be rogue airplanes out there? Comments???
Don't know. But given that I've heard stories of pilots flying
lower-powered airplanes using other airplanes as simulated targets, it sure
wouldn't surprise me to find someone out there in a Mustang, or L-39, or
what-have-you doing the same thing (though, I assume the visual ID rules out
the L-39, in spite of that plane technically being a single ).
Back in the "old days" it was not uncommon to be flying along US
27/I-75 between Grailing and the straights and see fighters up close.
Of course like the traffic cop you never saw them until they were
there. Having a pair of jets pass 100 yards off each wing tip and 500
MPH plus it certainly startling. Often you could count on them not
being a single pair and if not loaded with ordinance they sometimes
.... never mind.
Down in the Grailing area you end up flying between a gunnery range on
the west and a bombing range on the east. It can sometimes be quite a
show from 5000 feet, but the planes now days give us civvies a wide
berth. (usually)
If you go wayyyy back I was up at the brides when the two F-102s flew
under it. As I understand they ended up grounded. I missed the time
Arthur Godfrey flew his plane under it.
www.rogerhalstead.com
IMHO, the controller should have tracked the airplane to its landing, and
had an FAA inspector find out what was going on. Even better if the C172
pilot could get a good visual on it and identify the type (perhaps that did
happen later).
I would think that ATC would be informed regarding an intercept, and in any
case jet or no jet, I would expect the intercepting aircraft to be flying
slower than 250 knots. Sure doesn't sound like an intercept to me.
Pete
  #52
Old April 22nd 06, 05:47 AM posted to rec.aviation.piloting,rec.aviation.ifr
Default Buzzed?
On Tue, 18 Apr 2006 22:57:18 -0700, "Matt Barrow"
"Paul Tomblin" wrote in message
http://www.ntsb.gov/ntsb/brief.asp?e...17X00210&key=1
"One witness, located at the golf course indicated that he saw the
airplane make a 65-degree bank"
Not 60 degrees, not 70 degrees, but 65. Did he have a protractor with
him?
Damn good eyesight?
I could have used him when I worked on a survey crew.
Kinda like the (very) old Johnny Badmouth joke, "Okay, just a c*#% hair to
the right...".
That is a royal *** hair, sir!
  #53
Old April 22nd 06, 03:59 PM posted to rec.aviation.piloting,rec.aviation.ifr
Default Buzzed?
There was a case 5 or 10 years ago when a couple of fighters decided to
play "practice intercept" on a commerical airliner that had been cleared
through their MOA, not realizing that airliners have TCAS now. The
airliner reacted rather violently to the RA, and now the military doesn't
do that any more.
Paul Tomblin http://xcski.com/blogs/pt/
"I kept the faith and I kept voting/Not for the iron fist but for the helping
hand/For theirs is a land with a wall around it/And mine is a faith in my
fellow man" --Billy Bragg
  #54
Old April 23rd 06, 02:57 AM posted to rec.aviation.piloting,rec.aviation.ifr
Default Buzzed?
On Sat, 22 Apr 2006 14:59:42 +0000 (UTC),
do that any more.
Now that would have been a ride worth paying for:-)) IF you had your
seat belt fastened. I hope they had lots of lucn bags.
  #55
Old April 23rd 06, 03:04 AM posted to rec.aviation.piloting,rec.aviation.ifr
Default Buzzed?
On Mon, 17 Apr 2006 12:42:32 GMT, "Ted" wrote:
"Ted" wrote in message
news
So I'm flying IFR down V441 in Florida today, when I hear the
controller who's working me call traffic to a VFR airplane he's
providing with advisories. "Traffic, twelve o'clock, opposite
direction, very fast, same altitude, suggest you descend now." The 172
he's talking to descends in a hurry, and the traffic passes without
being seen. A few minute later, the controller says the same traffic
has circled around and is now coming back at the VFR airplane once
again. Once again, negative contact. Next time, the traffic is reported
circling ahead of the 172, until he breaks off and again makes a pass
around the Cessna. This time the now rather panicked VFR pilot see the
traffic, and reports it to the controller as "some sort of single." The
controller points out that at 250 kts at 5000 ft, it's unlikely to be a
piston and it must be some sort of jet.
I wonder if it was one of these?
http://www.if1airracing.com/IF1_Planes.shtml
These guys tend to fly around in circles at 250kts.
One day years ago after I did my runup in my little Cessna 152 and announced
my departure on runway 34 one of these little single seat buggers pulled out
onto the runway in front of me and took off. No waiting in line on the
taxiway for his turn, no radio calls, no nothing. I was quite annoyed at
his complete contempt for proper airport procedures until I saw him use
about 450 feet of runway to lift off. His climb out was essentially
vertical and in another few moments he flew over my head and out of sight.
http://www.if1airracing.com/IF1_Bio....0Hav en%20Bio
A couple of years back I was headed to Muncie In with a couple of
friends riding along. We were passing Ft Wayne at roughly 9000.
Approach had us looking for some F-16s doing touch and gos. They made
three complete circuits from way above us, down to the runway, a touch
and then a darn near vertical climb that must have been to 15 or
20,000, then a steep descent (essentially a split s) and back to the
runway. We were passing through at just shy of 200 MPH and they made
those 3 complete circuits just while we transited the area.
  #56
Old April 23rd 06, 05:04 PM posted to rec.aviation.piloting,rec.aviation.ifr
Default Buzzed?
Jose wrote in news:hCd2g.4265$mu2.4052
@newssvr24.news.prodigy.net:
What agreement?
This one:
We have a sign at the fuel pump as a reminder.
I'm not a lawyer, but I think you have no basis unless you can prove that
the "buzzer" bought fuel at that pump...
  #57
Old April 24th 06, 10:47 PM posted to rec.aviation.piloting,rec.aviation.ifr
Default Buzzed?
The airport is KSWI. The ordinance is very specific in what determines
"buzzing". It is basically unenforceable, except for those that
continually do it and the tail number is recorded. Not sure what the
fine it. What started this was that during a Young Eagle Rally there was
a bi-plane showing off that darn near hit a hangar. There was a local
tenant that decided to do a low (25') pass down the runway the same day.
This with all the YE events going on. Not a good day. Then I told you of
the guy that did low high speed passes in his areobatic plane
interfering with other traffic. Well, he got killed doing low aerobatics
over a marina. The city enacted the ordinance. Like I said before, the
city attorney is a pilot. Missed approaches and balked landings would
not exceed the limits of the definition.
Ross
What agreement?
This one:
  #58
Old April 24th 06, 11:53 PM posted to rec.aviation.piloting,rec.aviation.ifr
Default Buzzed?
Wouldn't matter what the fine is - any competent aviation attorney could
get the idiot off on the grounds that the airport has no jurisdiction once
you're in the air.
Programmer (n): One who makes the lies the salesman told come true.
  #59
Old April 25th 06, 03:27 PM posted to rec.aviation.piloting,rec.aviation.ifr
Default Buzzed?
"Ross Richardson" wrote in message
continually do it and the tail number is recorded. Not sure what the fine
it.
As they have no jurisdiction, it doesn't matter if they do it once, or fifty
times.
  #60
Old April 25th 06, 03:28 PM posted to rec.aviation.piloting,rec.aviation.ifr
Default Buzzed?
you're in the air.
And it doesn't matter if they do it once or "continually" (maybe he's doing
loop-de-loops over the airport).
Buzzed? Mike Granby Piloting 81 April 28th 06 12:35 AM
A4 just buzzed Mangere Airport Jeremy Thomson Military Aviation 3 July 10th 03 04:27 PM
