I've decided that I'm going to go ahead and try my hand at gas welding
aluminum. I have the TinMan's video. I have the flux. And I have lots of experience welding...steel. The one question I have is cleaning the flux. The video has the TinMan welding and then cleaning coupons with a damp rag. But how would you clean the inside of a closed fuel tank? -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Ernest Christley wrote:
I've decided that I'm going to go ahead and try my hand at gas welding aluminum. I have the TinMan's video. I have the flux. And I have lots of experience welding...steel. The one question I have is cleaning the flux. The video has the TinMan welding and then cleaning coupons with a damp rag. But how would you clean the inside of a closed fuel tank? By not making it a closed fuel tank. Put in an access panel. -- John Kimmel remove x "He's dead, Jim." |
John Kimmel wrote:
Ernest Christley wrote: I've decided that I'm going to go ahead and try my hand at gas welding aluminum. I have the TinMan's video. I have the flux. And I have lots of experience welding...steel. The one question I have is cleaning the flux. The video has the TinMan welding and then cleaning coupons with a damp rag. But how would you clean the inside of a closed fuel tank? By not making it a closed fuel tank. Put in an access panel. That is so obvious, there is no way it could be right. 8*) The construction method I was considering was to make sides with rounded edges, so that they cupped in like the bottom of a Coke can. There would be a convenient flange to weld, but it would leave a sharp crevice on the inside for flux to hide in. Having never done it, I'm not sure if I'm being overly concerned about a nit, or if overlooking it would have catastrophic results. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Ernest Christley wrote: John Kimmel wrote: Ernest Christley wrote: I've decided that I'm going to go ahead and try my hand at gas welding aluminum. I have the TinMan's video. I have the flux. And I have lots of experience welding...steel. The one question I have is cleaning the flux. The video has the TinMan welding and then cleaning coupons with a damp rag. But how would you clean the inside of a closed fuel tank? By not making it a closed fuel tank. Put in an access panel. That is so obvious, there is no way it could be right. 8*) The construction method I was considering was to make sides with rounded edges, so that they cupped in like the bottom of a Coke can. There would be a convenient flange to weld, but it would leave a sharp crevice on the inside for flux to hide in. Having never done it, I'm not sure if I'm being overly concerned about a nit, or if overlooking it would have catastrophic results. If you have a pretty fast connection, go download my Texas Parasol CD from Matronics. There is a photo section on building the aluminum gas tank in it. This particular example looks a lot like a Cub tank - 12 gallons. Formed end plates with aluminum wrapper skin. I didn't weld it - Sonny did, using electric stick. I can sorta do ok with a torch now. Just practice on scrap first... Plans and CD: http://www.matronics.com/photoshare/...et.03.04.2006/ Richard |
Drain the gas first.
Colin |
COLIN LAMB wrote:
Drain the gas first. Colin The gas I'm referring to is oxygen and acetylene. It's not a tank, yet. Just a sheet of aluminum that needs to be formed into a tank. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 03:46 PM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 06:23 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 04:52 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 07:24 AM |
| TIG welding video? | Russell Duffy | Home Built | 3 | October 6th 03 06:55 AM |
