![]() Chris Wells wrote: #1 has been circulating for years in motorcycle banter. I've seen for myself that folks who only take short trips on their bikes get white dipsticks, from all the moisture in their oil. ------------------------------------------------------------------- "Patriotism means to stand by the country. It does not mean to stand by the President." - President Theodore Roosevelt -- Chris Wells Seen the same on VWs when they only get short ground runs. The small oil quanity probably exagerates the problem, but it's there in all reciprocating engines. As to the hot air aspect, what's in the cylinder after shut down? If you pull the mixture, the cylinders are cleared with a few blades of clean (?) air before the prop stops. Turning off the switch, however, leaves some fuel in the chamber. One of them is probably under pressure too. $.02 |
![]() "Richard Lamb" wrote Water boils off at 212.9 F ? So operating at 180 oil temp removes water - how? (Yeah, I know - s l o w l y) That sounds a lot like "go fly it for an hour". Obviously the best solution, but not always possible. I have had it put to me that the 180 is more like an average temperature. As the oil circulates, it comes into contact with hot parts of the engine, and until it falls back into the sump, or hits cooler parts of the engine, it is temporarily well over 212, thus instantly evaporating the water in that part of the oil. Sooner or later (in an hour's time) all of the oil has passed over the hot parts, and all the water is magically gone! g -- Jim in NC |
On Sun, 23 Apr 2006 00:24:07 -0400, "Peter Dohm"
wrote: I just watched a program about the huge Oresund bridge between Denmark and Sweden, and there was a segment about how the corrosion problem for the bridge was dealt with. Instead of painting, they use sealed compartments that have the air humidity kept below 60%. This they said eliminates corrosion. This started me thinking about the corrosion we aircraft owners are told to guard against, since I have personally been told by an overhaul shop, that half of all the engines he sees that need work, need it because of corrosion. There are several "facts" that I am beginning to question as to their validity. The ones that come to mind a 1) You have to get the oil up to 180 deg F or the water in the oil won't evaporate. 2) Starting and ground running the engine for a minute or so is the "worst" thing you can possibly do. 3) Flying for an hour will "clean" the oil (or at least evaporate the water, preventing acid formation) so that it doesn't turn to acid and dissolve the engine while sitting idle. ----------------snip----------- Blue Skies Rusty 1) In automobiles years ago, the standard assertion was that you had to get the engine temp up to 160 degrees for the water to evaporate from the oil. As it happened, that was actually measuring water temp. 160 degrees was simply the most common coolant thermostat temperature in those days. So if the same jack asses are still breathing in and out, they are probably claiming that 205 degrees is mandatory today. About all I know for sure about water water condensing into much of anything is: a) it almost never happens inside a garage or hangar, We must live in different climates. Here in Central Michigan it's not unusual to find the airplane "dripping" wet with temperature changes. I have an garage attached to the house. It's not unusual to find the cars sweating with temperature and humidity changes. I had to work on the garden tractor today and the engine is wet from the humidity and temperature changes. (It's been 100% since last night and rained most of the day. Current temp is 50F) The weather for the area says 85% but it's raining with light fog. Of course the briefing I printed out at 3:00 AM says visibility 6, 5000 sct, 10,000 bkn with temp 4 in light rain and thunderstorms with 5,000 sct. It's now starting to clear from the west and MOP is showing Vis 10, 1000 sct, 1500 bkn. Most of the afternoon was 1 and 500. b) an engine covered with plastic and sitting on the ground will accumulate MASSIVE amounts of water, We get the same thing in our hangars on the airplanes and engines. If I went out to the hangar today I'd find the plane dripping. The temp is dropping slowly. It'll be near the upper 30's tonight. Opening the cowl would find water droplets on the cylinders and crankcase. This is in a well ventilated metal hangar with a concrete floor. c) a small light object such as a medicine vial with a snap type lid will accumulate water outdoors in the shade--such as under a patio roof. As to evaporation, warmer is faster; but if the ambient humidity is 100%, a surprisingly small temperature rise (10 or 20 degrees IIRC) above ambient will bring the relative humidity inside the engine below 50%. Also the engine breathes in and out with temperature changes. So cooling not only raised the relative humidity inside, it brings in more cool, damp air. 2) I am not an aircraft and engine mechanic. However, I am confident that running a Lycoming engine to circulate the oil is FAR BETTER than letting it stand; both for the cylinders and the famous cam and tappets. If it's going to set long it needs to be protected not ground run according to the engine manufacturers literature. If I owned it and was not flying at least weekly, you're damned right I'd ground run it! Not very long, but enough to circulate the oil and If you are going to ground run it you want to bring it up to operating temp. It's the short runs that not only don't evaporate much of anything they put a lot more *stuff* into the oil as the cold engine isn't running as efficient as a warm one and the byproducts can condense inside. Find a good clean spot on the ramp, let the engine warm up normally. Then stand on the brakes and wind 'er up for a prolonged run. Of course then makes the neighbors unhappy. at least get the temp needle off the peg. If, for any reason I was unable to run the engine frequently, I would certainly place dessicant packages in the intake(s), exhaust(s), and crankcase breather. They usually put desiccants in the plugs and plug off the intake, exhaust and breathers. Go into Pioneer Airport and look at the antiques that have the engines preserved. I've forgotten the term, but at any rate each prop has a note on it that says "Do not turn prop. Engine has been preserved". 3) Yep, I agree that's an old mechanics tales as well. OTOH, any reason to fly might bew a good reason. Might be but both Lycombing and Continental subscribe to it. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com As to the bridge, apparently the Danes and Sweedes haven't shelled one another across the straights for so long they've forgotten about that. ;-) In any case, small amounts of surface rust are trivial for a structure like a bridge; but seriously debilitating inside an engine! Peter |
![]() "Roger" wrote We must live in different climates. Here in Central Michigan it's not unusual to find the airplane "dripping" wet with temperature changes. I have an garage attached to the house. It's not unusual to find the cars sweating with temperature and humidity changes. I had to work on the garden tractor today and the engine is wet from the humidity and temperature changes. (It's been 100% since last night and rained most of the day. I feel your pain! g NC is like that, at times, also. Want a good piece of advise? Insulate your garage, put up good insulated garage doors, and with good seals installed. Run one 8" duct into the garage from your central heat and air. It makes a huge difference at not all that much expense. -- Jim in NC |
"Morgans" wrote in message
... "Roger" wrote We must live in different climates. Here in Central Michigan it's not unusual to find the airplane "dripping" wet with temperature changes. I have an garage attached to the house. It's not unusual to find the cars sweating with temperature and humidity changes. I had to work on the garden tractor today and the engine is wet from the humidity and temperature changes. (It's been 100% since last night and rained most of the day. I feel your pain! g NC is like that, at times, also. Want a good piece of advise? Insulate your garage, put up good insulated garage doors, and with good seals installed. Run one 8" duct into the garage from your central heat and air. It makes a huge difference at not all that much expense. -- Jim in NC I am currently in Florida. However, I'll keep your solution in mind in case of a move to a cooler climate. Thanks for the advice. Peter |
On Sun, 23 Apr 2006 18:36:42 -0400, Roger
wrote: On Sun, 23 Apr 2006 00:24:07 -0400, "Peter Dohm" wrote: I just watched a program about the huge Oresund bridge between Denmark and Sweden, and there was a segment about how the corrosion problem for the bridge was dealt with. Instead of painting, they use sealed compartments that have the air humidity kept below 60%. This they said eliminates corrosion. This started me thinking about the corrosion we aircraft owners are told to guard against, since I have personally been told by an overhaul shop, that half of all the engines he sees that need work, need it because of corrosion. There are several "facts" that I am beginning to question as to their validity. The ones that come to mind a 1) You have to get the oil up to 180 deg F or the water in the oil won't evaporate. 2) Starting and ground running the engine for a minute or so is the "worst" thing you can possibly do. 3) Flying for an hour will "clean" the oil (or at least evaporate the water, preventing acid formation) so that it doesn't turn to acid and dissolve the engine while sitting idle. ----------------snip----------- Blue Skies Rusty 1) In automobiles years ago, the standard assertion was that you had to get the engine temp up to 160 degrees for the water to evaporate from the oil. As it happened, that was actually measuring water temp. 160 degrees was simply the most common coolant thermostat temperature in those days. So if the same jack asses are still breathing in and out, they are probably claiming that 205 degrees is mandatory today. About all I know for sure about water water condensing into much of anything is: a) it almost never happens inside a garage or hangar, We must live in different climates. Here in Central Michigan it's not unusual to find the airplane "dripping" wet with temperature changes. I have an garage attached to the house. It's not unusual to find the cars sweating with temperature and humidity changes. I had to work on the garden tractor today and the engine is wet from the humidity and temperature changes. (It's been 100% since last night and rained most of the day. Current temp is 50F) The weather for the area says 85% but it's raining with light fog. Of course the briefing I printed out at 3:00 AM says visibility 6, 5000 sct, 10,000 bkn with temp 4 in light rain and thunderstorms with 5,000 sct. It's now starting to clear from the west and MOP is showing Vis 10, 1000 sct, 1500 bkn. Most of the afternoon was 1 and 500. b) an engine covered with plastic and sitting on the ground will accumulate MASSIVE amounts of water, We get the same thing in our hangars on the airplanes and engines. If I went out to the hangar today I'd find the plane dripping. The temp is dropping slowly. It'll be near the upper 30's tonight. Opening the cowl would find water droplets on the cylinders and crankcase. This is in a well ventilated metal hangar with a concrete floor. c) a small light object such as a medicine vial with a snap type lid will accumulate water outdoors in the shade--such as under a patio roof. As to evaporation, warmer is faster; but if the ambient humidity is 100%, a surprisingly small temperature rise (10 or 20 degrees IIRC) above ambient will bring the relative humidity inside the engine below 50%. Also the engine breathes in and out with temperature changes. So cooling not only raised the relative humidity inside, it brings in more cool, damp air. 2) I am not an aircraft and engine mechanic. However, I am confident that running a Lycoming engine to circulate the oil is FAR BETTER than letting it stand; both for the cylinders and the famous cam and tappets. If it's going to set long it needs to be protected not ground run according to the engine manufacturers literature. If I owned it and was not flying at least weekly, you're damned right I'd ground run it! Not very long, but enough to circulate the oil and If you are going to ground run it you want to bring it up to operating temp. It's the short runs that not only don't evaporate much of anything they put a lot more *stuff* into the oil as the cold engine isn't running as efficient as a warm one and the byproducts can condense inside. Find a good clean spot on the ramp, let the engine warm up normally. Then stand on the brakes and wind 'er up for a prolonged run. Of course then makes the neighbors unhappy. at least get the temp needle off the peg. If, for any reason I was unable to run the engine frequently, I would certainly place dessicant packages in the intake(s), exhaust(s), and crankcase breather. They usually put desiccants in the plugs and plug off the intake, exhaust and breathers. Go into Pioneer Airport and look at the antiques that have the engines preserved. I've forgotten the term, but at any rate each prop has a note on it that says "Do not turn prop. Engine has been preserved". 3) Yep, I agree that's an old mechanics tales as well. OTOH, any reason to fly might bew a good reason. Might be but both Lycombing and Continental subscribe to it. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com As to the bridge, apparently the Danes and Sweedes haven't shelled one another across the straights for so long they've forgotten about that. ;-) In any case, small amounts of surface rust are trivial for a structure like a bridge; but seriously debilitating inside an engine! Peter If you feel the need to get the oil moving in a stored engine, crank it over with the fuel and mags shut off untill full oil pressure is acheived, then recharge the battery. Do NOT ground run for short periods without getting the oil temperature up to dry it out. Particularly important with top-cam engines, as the cams and tappets are very prone to condensation induced corrosion failures. And worse with Synthetic oils than standard petro oils. *** Posted via a free Usenet account from http://www.teranews.com *** |
("Roger" wrote)
Go into Pioneer Airport and look at the antiques that have the engines preserved. I've forgotten the term, but at any rate each prop has a note on it that says "Do not turn prop. Engine has been preserved". Pickled? Fogged? Montblack |
![]() Morgans wrote: "Roger" wrote We must live in different climates. Here in Central Michigan it's not unusual to find the airplane "dripping" wet with temperature changes. I have an garage attached to the house. It's not unusual to find the cars sweating with temperature and humidity changes. I had to work on the garden tractor today and the engine is wet from the humidity and temperature changes. (It's been 100% since last night and rained most of the day. I feel your pain! g NC is like that, at times, also. Want a good piece of advise? Insulate your garage, put up good insulated garage doors, and with good seals installed. Run one 8" duct into the garage from your central heat and air. It makes a huge difference at not all that much expense. -- Jim in NC That's good advice... |
Water in our oil, or just alot of hot air? | [email protected] | Piloting | 9 | April 24th 06 05:30 AM |
Water in our oil, or just alot of hot air? | [email protected] | Owning | 24 | April 24th 06 03:27 AM |
Induction System Water Problem | Mike Spera | Owning | 1 | January 30th 05 05:29 AM |
Questions regarding Air/Oil Separators | Doodybutch | Owning | 6 | April 20th 04 05:56 PM |
Water Cooled Jet Engines: a possibillity then and now? | The Enlightenment | Military Aviation | 3 | December 18th 03 09:41 AM |
