IAP without inbound course?
Old April 24th 06, 01:02 AM posted to rec.aviation.ifr
Default IAP without inbound course?
"Jose" wrote in message
news
Then count me in. I was never taught the procedure; I asked here some
time ago and practiced it on my own. However, my training is not
"seriously lacking". The DME arcs were not around much (DME was not in
the aircraft either) when I took my training. I've kept up, but one
cannot keep up with what one does not know to keep up with, and some of
those things are obscure "gotchas".
DME arcs were much more common years ago than they are today.
Old April 24th 06, 01:43 AM posted to rec.aviation.ifr
Not a bad skill to brush up on during an IPC or something. I usually
start doing them about 10 DME from the VOR once I'm in the grove turn
inwards to 8 DME and try again, going successively closer until you're
really cranking around.
I've never had to fly one in real life though.
Robert
news
Old April 24th 06, 02:25 AM posted to rec.aviation.ifr
Jose wrote:
There is only one such IAP in the country (probably the world). If,
however, you mean most pilots don't know how to fly DME ARC initial
approach segments, then their training is seriously lacking.
Jose
The procedure for flying DME ARCs was in the old instrument flying
handbook, both with and without an RMI.
I was never taught the procedure, either, when I obtained my instrument
rating. But, as a professional CFI-I, I became proficient in their use
and how to teach them as soon as it became apparent (circa late 1960s)
that they better be part of the proficient instrument pilot's toolkit.
Old April 24th 06, 02:42 AM posted to rec.aviation.ifr
The track on the arc is +- 1 NM, it can be done closer.
I've flown them in actual, no radar approach control used
the arc as a means to get required sep.
If you lead the initial turn about 1 mile, you should roll
out pretty close.
Like a lot of IFR training, procedures that are taught may
never be used in real life, such as time/distance to station
by bearing change.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Sam Spade" wrote in message
news:6OV2g.174009$bm6.4021@fed1read04...
world). If,
ARC initial
lacking.
asked here some
training is not
(DME was not in
up, but one
with, and some of
| Jose
instrument flying
my instrument
in their use
late 1960s)
pilot's toolkit.
Old April 24th 06, 05:39 AM posted to rec.aviation.ifr
Not for the bugsmashers I learned in. DME was stuff you'd see in
somebody's personal high performance airplane, as was an intercom.
Jose
The price of freedom is... well... freedom.
Old April 24th 06, 03:04 PM posted to rec.aviation.ifr
om...
DME arcs were more common on IAPs years ago than they are today. Many
procedures that had them saw them removed in the early '80s.
Old April 24th 06, 04:02 PM posted to rec.aviation.ifr
om...
As you say, many of them were removed in the late 80s or so. The
present policy is:
4) Arc Initial Approach Segment. Requirements for arc initial approach
segments must be fully evaluated to determine if this type of procedure
entry is essential to the local traffic flow. Experience indicates that
arc initial segments have been established at locations where they are
used on a very limited basis or have not been fully accepted by the
user. Long arcs and/or multiple arcs have contributed to undesirable
chart clutter with minimum operational advantage.
(a) An arc initial segment in a radar environment shall not be
authorized unless it is operationally required.
(b) When a DME arc segment of an approach lies along an arc which
traverses an area of unusable radial information, the provisions of OA P
8200.1, paragraph 214.3 apply.
(c) Arc initial segments should be authorized via the shortest routing
when flight time can be reduced.
(d) Arc initial segments shall be designated by CW for clockwise and CCW
for counter-clockwise.
(e) Arc initial segments shall be designed to satisfy requirements for
executing the instrument approach. They shall NOT be established for the
convenience of routing aircraft around a terminal area.
(f) Arc initial segments less than 3 miles in length are not
recommended. Use of aircraft heading to intercept the intermediate
course should be considered as an alternate action in lieu of short arc
segments.
(g) DME Arc courses must be predicated only on collocated facilities
providing azimuth and DME information. Arc initial segments must not be
authorized on DME collocated with ILS or localizer facilities due to the
lack of constant azimuth information. See Order 6050.32, appendix III,
section 2 for collocation parameters.
  #28
Old April 24th 06, 08:35 PM posted to rec.aviation.ifr
news:0M53g.174115$bm6.54516@fed1read04...
What does this mean?
  #29
Old April 24th 06, 10:51 PM posted to rec.aviation.ifr
I'll give it my best guess: It is federal redundancy saying in another
way that ARC initials are to be used only when they can reduce initial
segment miles and only when it is the shortest distance within some
particular quadrant.
  #30
Old May 9th 06, 04:25 AM posted to rec.aviation.ifr
They used to have several DME ARC final approaches in Germany. The
military especially used them as backup procedures to get to the airport
if the base facilities were off the air, and sometimes as primary
procedures if there weren't any on-field facilities. Most of the time
the arc didn't line you up with the runway centerline unless the
facility just happened to be perfectly abeam the airport.
John
more bitching about the IFR written - CDI left/right versus north/south/etc G. Sylvester Instrument Flight Rules 58 January 12th 05 02:32 AM
GPS 430 or 480? Hankal Instrument Flight Rules 35 November 3rd 04 10:23 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Busy day for MilComms Monitoring - Wed, 7 Apr 2004 AllanStern Military Aviation 7 May 11th 04 07:29 AM
Lost comms after radar vector Mike Ciholas Instrument Flight Rules 119 January 31st 04 11:39 PM
