measuring flap angles for rigging
Old April 24th 06, 06:07 AM posted to rec.aviation.homebuilt
Default measuring flap angles for rigging
What tool or methods do you use to measure flap angles to a datum?
Old April 25th 06, 11:51 AM posted to rec.aviation.homebuilt
A "Smart level" is a tool of choice. It gives you digital read out and is
accurate to 1/10th of a degree.
J.P.
go down to the best hardware store you can find and locate a
carpenter's compound square set. it is the one with the square, the
ruler and the angle doohicky all in one.(two bits that slide along the
ruler) the angle thing has a bubble in it for reference to horizontal.
you discard all the bits except for that bubble angle measurer. it is
more than sufficiently accurate for doing control surfaces.
Stealth Pilot
Old April 25th 06, 11:46 PM posted to rec.aviation.homebuilt
In article , Jean-Paul Roy says...
I keep hearing about a "smart level" where does one purchase it?
Thanks
Chuck S
NewsGuy.Com 30Gb $9.95 Carry Forward and On Demand Bandwidth
Old April 26th 06, 01:38 AM posted to rec.aviation.homebuilt
"ChuckSlusrczyk" wrote in message
says...
I have one, and it is invaluable.
Building supply stores, magazines or internet outlets.
http://md-smart-tool.com/
Jim in NC
Old April 26th 06, 01:09 PM posted to rec.aviation.homebuilt
In article , Morgans says...
says...
Thanks Jim I ordered it this AM.
See ya
Chuck S
Old April 27th 06, 01:56 AM posted to rec.aviation.homebuilt
Make sure you perform the calibration instructions each time you use
it. They are great when properly calibrated.
Old April 27th 06, 01:57 AM posted to rec.aviation.homebuilt
Old April 27th 06, 02:12 AM posted to rec.aviation.homebuilt
Old April 27th 06, 04:01 AM posted to rec.aviation.homebuilt
"BobR" wrote in message
I see that you like to do things with triple redundancy, like these three
posts! g
Seriously, I have not found the need to calibrate mine, other than at
battery change, or a hard fall. Accuracy is still excellent.
I was worried about the accuracy, if it was not calibrated each time, so I
did some testing. I shimmed a piece of square tube so it was perfect, and
verified it by reversing ends of the level. I then calibrated it, and
checked it again.
I could see *no* difference in the readings.
If the 2 foot level is being used on a long structure that may be slightly
"non-straight" then it would be a good idea to get a long piece of aluminum
angle, or rectangular tube, and fasten the 2 foot level to that, then use it
on your long structure.
Jim in NC
Negative flaps for better low speed aileron control? [email protected] Soaring 41 August 25th 05 06:01 AM
Stuck cowl flap cable Jim Burns Owning 7 March 24th 05 02:07 PM
Flap Hinge Moment Calc Bo Home Built 2 February 2nd 05 10:26 AM
Flap angles DeltaDeltaDelta Piloting 34 May 18th 04 12:09 AM
