A strange richness...
Old April 25th 06, 03:46 PM posted to rec.aviation.owning
Default A strange richness...
"BTIZ" wrote in message
news:1ti3g.8790$Qz.8436@fed1read11...
You "primed a few pumps", I take it this means throttle pumping
(accelerator pumps?) on an already hot engine? I'd guess you did over
prime and then flood the engine.. I am not sure of your engine but I
presume it is also an IO-540? Always follow the POH or manufactures
recommendations for your aircraft or configuration, the Aztruck may not
have the same throttle body or injectors that you have.
Quite! Pumping the throttle on a FI engine serves absolutely NO PURPOSE.
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Old April 25th 06, 03:54 PM posted to rec.aviation.owning
Matt,
There's a little confusion in this thread.
Jay's engine is a carbureted O-540, mine are IO-540's. You are correct, no
need to "pump" the throttle of a FI engine, no accelerator pump. I also
agree with the comment made about only pumping the throttle of a carbureted
engine while cranking.
Old April 25th 06, 05:52 PM posted to rec.aviation.owning
You "primed a few pumps", I take it this means throttle pumping (accelerator
pumps?) on an already hot engine? I'd guess you did over prime and then
flood the engine.. I am not sure of your engine but I presume it is also an
IO-540?
Nope. Pumped the primer a couple of times. (The little
Coleman-lantern-style-thingie)
The engine is a normally-aspirated O-540.
I obviously flooded it, but I don't quite understand how this can be
so, simply by starting with the mixture at idle/cut-off, rather than at
full rich.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old April 25th 06, 06:42 PM posted to rec.aviation.owning
My guess, and it's just a guess, is that you flooded the primed cylinders
while the remaining cylinders fired and operated normally, thus the
roughness.
As you advanced the mixture, the primed cylinders continued to be flooded
but the non-primed cylinders operated normally, albeit at a possibly rich
mixture.
As you retarded the mixture, the primed cylinders were then able to
completely burn the leaner mixture and clean themselves up.
"Jay Honeck" wrote in message
(accelerator
an
IO-540?
full rich.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old April 25th 06, 07:15 PM posted to rec.aviation.owning
I never use the primer when the engine is even just warm.
In fact, the O-540 on my Comanche cranks right up with no
priming even after several days of sitting. I usually only
need to prime on cold days, which isn't many in southern Georgia.
If it hasn't flown for a couple of weeks and won't fire up
after a few cranks then I might pump it once or twice.
Old April 25th 06, 10:19 PM posted to rec.aviation.owning
Starting the Continentals using the book procedures for big
Lycomings works fine.
BTW, the procedure Jay mentions is used for Dukes and
other big injected Lycs.
My experience is that when hot, more than "throttle cracked"
is good. Douches it out more easily if it floods
Bill Hale
Old April 25th 06, 10:23 PM posted to rec.aviation.owning
On 25 Apr 2006 14:19:47 -0700, "
My O-540 experience is, if you're going to start it hot, shut it down
with the mag switch and don't prime at all.
Don
Old April 25th 06, 10:30 PM posted to rec.aviation.owning
Are Aztec engines Continentals or Lycomings?
Continentals sometimes have a fuel return line.
I do not know if Lycomings do, also, but I have not seen one that does
on any of the aircraft I have flown.
Old April 26th 06, 02:13 AM posted to rec.aviation.owning
we only use the manual primer on cold days.. less than 40F and never on a
warm engine
I may have mistyped earlier when I referenced IO- vs O-, yes there is no
throttle pump on the IO-
BT
"ktbr" wrote in message
Old April 26th 06, 05:05 AM posted to rec.aviation.owning
roughness.
mixture.
This makes as much sense as anything -- thanks.
I probably shouldn't have used the primer at all, but it was in that
goofy, "in-between" length of time, where the engine wasn't really
still "hot" -- but it wasn't really "cold" either.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Strange Vibrations Al Gilson Owning 16 May 13th 05 08:55 PM
Strange engine event Paul Mennen Owning 33 July 9th 04 03:42 AM
Strange one about the 296 kage Piloting 0 June 13th 04 01:42 AM
Strange lost-comm situation Roy Smith Instrument Flight Rules 6 May 4th 04 03:11 AM
Really strange going-on with radios Roy Smith General Aviation 3 March 15th 04 12:52 PM
