For Morgans ...Rotax (x 2)
Old April 28th 06, 12:04 AM posted to rec.aviation.homebuilt
Default For Morgans ...Rotax (x 2)
Ian Mitchell wrote:
Snip "relevent fact"
Don't confuse the issue with facts, they don't want to change an earnestly
held pre-concieved notion.
Ian
Maybe, so.
I don't get very excited about ugly airplanes...
Now a Pulsar with wing mounted twin 582's?
I'm fool enough to think that'd be sweet.
Richard
Old April 28th 06, 12:41 AM posted to rec.aviation.homebuilt
("Morgans" wrote)
First of all, let me say, "you are really cruel."
[snip]
You just love throwing salt into open wounds, dont't you? Shame on you!
I had to hurry up, before that sucker closed up! g
http://home.att.net/~dannysoar/BelGeddes.htm
Rotax, Rotax, Rotax, Rotax, Rotax, Rotax, Rotax, Rotax, Rotax, Rotax...
Montblack-hearted-fiend, er, I mean, um ...friend. Me friend.
Old April 28th 06, 07:19 AM posted to rec.aviation.homebuilt
.. The problem with conventional 4 stroke
aircraft engines has been weight, and the need to put them into a bigger
heavier airframe. I'm very encouraged by the developement of engines like
the HKS and Warner, as they appear to offer a nice blend of light
weight/power/reliability.
Ian
Published performance specs for the HKS:
56HP @5800RPM 4.2gph/.45bsfc.
This will require a volumetric efficiency of 110%. Not bad for an
engine running at 75% throttle. In fact, not very likely.
Published performance specs for the Verner:
63HP(75%) @3750RPM. 2.7gph/.25bsfc Much more reasonable 55% volumetric
efficiency with 75% power, but absolutely astonishing fuel efficiency.
In fact, not very likely fuel efficiency.
Both engines achieve their light weight by running at high rpm with
small displacement, and by using Nikasil aluminum cylinders. Which is
to say, they are race car engines.
Would you rather have a C-85 with 2000 hours TT or a Verner with 600
hours TT? Or a 2 stroke with cast iron cylinders?
I would appreciate it if someone would check my numbers and see if they
come up with similar results.
John Kimmel
remove x
"He's dead, Jim."
Light weight low cost four stroke engines, good Rotax replacements. Bushleague Piloting 1 October 13th 05 04:49 AM
Engine sound of Rotax 912 JK Home Built 12 May 22nd 05 02:47 PM
Rotax 582 Firewall Forward Package For Sale Bushmaster Guy Home Built 0 November 22nd 04 06:33 AM
Questions Rotax Engines Mark Smith Home Built 2 August 13th 04 11:01 PM
RV-9A's wing with Rotax 914? Shin Gou Home Built 26 March 7th 04 08:56 PM
