Accuracy of GPS in Garmin 430/530
Old April 28th 06, 08:23 AM posted to rec.aviation.ifr
Default Accuracy of GPS in Garmin 430/530
says...
I just don't understand the issue about pilot overload. I'm asking for two
integers, and you don't need to look at them ever if you don't want to.
Will, I think you should look at this picture :
http://www.airliners.net/open.file?id=0286741
Then write back and tell us you really think we need some more numbers there,
to give us redundant information. The 430's in the picture already have RAIM,
and will warn the pilot if the information is below standard - Does this guy
look like he's starved for more numbers to stare at?
GF
  #82
Old April 28th 06, 02:08 PM posted to rec.aviation.ifr
GF
I suspect he too busy worrying about what to do it an engine fails in
that underpowered twin.
  #83
Old April 28th 06, 02:14 PM posted to rec.aviation.ifr
Steven,
You know, with all due respect, your "discussion style" is really weird
(annoying, too, if I may say so). How about giving answers instead of
only asking questions? If you think you know something, tell us instead
of smart-*ssing the group to death.
Thomas Borchert (EDDH)
  #84
Old April 28th 06, 07:46 PM posted to rec.aviation.ifr
In article Ato4g.174429$bm6.92343@fed1read04, says...
I'll let Mike Rappoport field that one, if he's with us!!
  #85
Old April 29th 06, 12:51 AM posted to rec.aviation.ifr
"Sam Spade" wrote in message
news:Kt74g.174361$bm6.134909@fed1read04...
They are as primary nav for IFR.
Cite the applicable regulation.
Part 23 (for the type of aircraft we're talking about). A good avionics
shop can direct you to related ACs.
We're not talking about a type of aircraft, we're talking about use of
handheld GPS. Part 23 is not applicable.
So, it does not satisfy Part 23, which requires that the avionics
manufacturer provide equipment (in this case) that is appropriate for IFR
operations.
Part 23 prescribes airworthiness standards for the issue of type
certificates, and changes to those certificates, for airplanes in the
normal, utility, acrobatic, and commuter categories. It has nothing to do
with uninstalled devices such as handheld GPS.
You can examine Part 23 he http://makeashorterlink.com/?D2FD2580D
Handhelds are typically not installed. But, once they are connected to an
external antenna and/or ship's power supply they are usually considered to
be installed.
Only by the irrational.
  #86
Old April 29th 06, 12:54 AM posted to rec.aviation.ifr
news:0984g.174363$bm6.171092@fed1read04...
Also, AIM 1-1-19:
d. General Requirements
1. Authorization to conduct any GPS operation under IFR requires that:
(a) GPS navigation equipment used must be approved in accordance with the
requirements specified in Technical Standard Order (TSO) TSO-C129, or
equivalent, and the installation must be done in accordance with Advisory
Circular AC 20-138, Airworthiness Approval of Global Positioning System
(GPS) Navigation Equipment for Use as a VFR and IFR Supplemental
Navigation System, or Advisory Circular AC 20-130A, Airworthiness Approval
of Navigation or Flight Management Systems Integrating Multiple Navigation
Sensors, or equivalent. Equipment approved in accordance with TSO-C115a
does not meet the requirements of TSO-C129. Visual flight rules (VFR) and
hand-held GPS systems are not authorized for IFR navigation, instrument
approaches, or as a principal instrument flight reference. During IFR
operations they may be considered only an aid to situational awareness.
(b) Aircraft using GPS navigation equipment under IFR must be equipped
with an approved and operational alternate means of navigation appropriate
to the flight. Active monitoring of alternative navigation equipment is
not required if the GPS receiver uses RAIM for integrity monitoring.
Active monitoring of an alternate means of navigation is required when the
RAIM capability of the GPS equipment is lost.
(c) Procedures must be established for use in the event that the loss of
RAIM capability is predicted to occur. In situations where this is
encountered, the flight must rely on other approved equipment, delay
departure, or cancel the flight.
(d) The GPS operation must be conducted in accordance with the
FAA-approved aircraft flight manual (AFM) or flight manual supplement.
Flight crew members must be thoroughly familiar with the particular GPS
equipment installed in the aircraft, the receiver operation manual, and
the AFM or flight manual supplement. Unlike ILS and VOR, the basic
operation, receiver presentation to the pilot, and some capabilities of
the equipment can vary greatly. Due to these differences, operation of
different brands, or even models of the same brand, of GPS receiver under
IFR should not be attempted without thorough study of the operation of
that particular receiver and installation. Most receivers have a built-in
simulator mode which will allow the pilot to become familiar with
operation prior to attempting operation in the aircraft. Using the
equipment in flight under VFR conditions prior to attempting IFR operation
will allow further familiarization.
(e) Aircraft navigating by IFR approved GPS are considered to be area
navigation (RNAV) aircraft and have special equipment suffixes. File the
appropriate equipment suffix in accordance with TBL 5-1-2, on the ATC
flight plan. If GPS avionics become inoperative, the pilot should advise
ATC and amend the equipment suffix.
(f) Prior to any GPS IFR operation, the pilot must review appropriate
NOTAMs and aeronautical information. (See GPS NOTAMs/Aeronautical
Information.)
(g) Air carrier and commercial operators must meet the appropriate
provisions of their approved operations specifications.
AIM Preface, see subparagraph d.:
Flight Information Publication Policy
The following is in essence, the statement issued by the FAA
Administrator and published in the December 10, 1964, issue of the Federal
Register, concerning the FAA policy as pertaining to the type of information
that will be published as NOTAMs and in the Aeronautical Information Manual.
a. It is a pilot's inherent responsibility to be alert at all times
for and in anticipation of all circumstances, situations, and conditions
affecting the safe operation of the aircraft. For example, a pilot should
expect to find air traffic at any time or place. At or near both civil and
military airports and in the vicinity of known training areas, a pilot
should expect concentrated air traffic and realize concentrations of air
traffic are not limited to these places.
b. It is the general practice of the agency to advertise by NOTAM or
other flight information publications such information it may deem
appropriate; information which the agency may from time to time make
available to pilots is solely for the purpose of assisting them in executing
their regulatory responsibilities. Such information serves the aviation
community as a whole and not pilots individually.
c. The fact that the agency under one particular situation or another
may or may not furnish information does not serve as a precedent of the
agency's responsibility to the aviation community; neither does it give
assurance that other information of the same or similar nature will be
advertised, nor, does it guarantee that any and all information known to the
agency will be advertised.
d. This publication, while not regulatory, provides information which
reflects examples of operating techniques and procedures which may be
requirements in other federal publications or regulations. It is made
available solely to assist pilots in executing their responsibilities
required by other publications.
Consistent with the foregoing, it shall be the policy of the Federal
Aviation Administration to furnish information only when, in the opinion of
the agency, a unique situation should be advertised and not to furnish
routine information such as concentrations of air traffic, either civil or
military. The Aeronautical Information Manual will not contain informative
items concerning everyday circumstances that pilots should, either by good
practices or regulation, expect to encounter or avoid.
  #87
"John R. Copeland" wrote in message
Must we say once again that the AIM is not regulatory?
I doubt it would do any good.
  #88
Old April 29th 06, 12:56 AM posted to rec.aviation.ifr
news:ZK94g.174370$bm6.21952@fed1read04...
Keep in mind the FAA does not do a perfect job of keeping the AIM current.
And, of course, it is not regulatory, but it is sometimes directive and a
focal point to provide information to pilots.
If you knew the AIM was not regulatory why did you cite AIM para 1-1-19?
  #89
Old April 29th 06, 12:57 AM posted to rec.aviation.ifr
"ted" wrote in message
ink.net...
Oh, Steven!!!
You had the PERFECT chance to reply: "Google is your friend"
but you didn't take it. Rats.
Because Google is not Bob's friend!
  #90
"Bob Noel" wrote in message
yeah. that's good. Is that where you get your definition
of "night", "pilot-in-command", etc?
The dictionary has fine definitions of those words.
Garmin backing away from additional GDL-69 features for 430/530 products? Andrew Gideon Owning 2 September 9th 05 11:36 PM
Inexpensive Garmin 430/530 question vlado Owning 2 May 19th 05 03:21 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
WAAS and Garmin 430/530 DoodyButch Owning 23 October 13th 03 04:06 AM
Garmin 430/530 Questions Steve Coleman Instrument Flight Rules 16 August 28th 03 09:04 PM
