I had to open my LX20 last night to replace both the 9v NiCd which
wasn't holding a charge with a 9v NiMh, and the small watch battery which was dead. I reassembled it, connected it to the charger, and hit the ON button. It starts beeping and displays the message "Secret Key Not Valid!" I followed the Memory Init routine from the manual, and put in a new password in the Setup menu, but after I turn it off/on, the error returns. What do I need to do now? Thanks, Ken |
I suspect you send it back and have it resealed. Sounds like you broke
the tamper seal in the device. It *may* still be usable as an insecure FR, but forget badges or records. -Tom |
5Z wrote:
I suspect you send it back and have it resealed. Sounds like you broke the tamper seal in the device. It *may* still be usable as an insecure FR, but forget badges or records. Tom is correct, you broke the electronic seal. It needs to go back to the factory or an authorized agent. Send an email to LX Navigation to find out what your options are... Marc |
Marc Ramsey wrote: 5Z wrote: I suspect you send it back and have it resealed. Sounds like you broke the tamper seal in the device. It *may* still be usable as an insecure FR, but forget badges or records. Tom is correct, you broke the electronic seal. It needs to go back to the factory or an authorized agent. Send an email to LX Navigation to find out what your options are... Marc The 9v NiCd was no longer holding a charge, so the only way the LX-20 would operate was on external power. Upon investigation I see that when I opened the case to also replace the original nearly 10 year old lithium watch battery which supplies power to save settings (name, glider, units, etc), a micro switch opened. Whether you're replacing the lithium battery because it is old or because it has died, you still have to open the case, which opens the micro switch and invalidates the security code. Actually, it's probably better that this happened now, instead of in flight, in the middle of the soaring season. I still have time to get this resolved. The 9v and the lithium battery lasted for nearly 10 years, so they were due for replacement. What's the reasoning behind hiding the LX-20 lithium battery such that it can't be replaced without opening the micro switch? I hear that there's a DOS application from Filser which resets the security code, and that this is an issue for a number of secure flight recorders. That is, there are other units which have a small battery that when removed for replacement, cause the same problem. How do other manufacturers handle this? I note that my home central heating/cooling display uses a pair of lithiums in parallel, so you can replace them one at a time without losing the stored program. Ken |
Ken Ward wrote:
I hear that there's a DOS application from Filser which resets the security code, and that this is an issue for a number of secure flight recorders. If such a DOS program is being provided to those who are not factory authorized agents, I would like to hear about it. This would be a definite violation of the terms under which the unit is approved. If the case is opened, or the security seal is otherwise broken, the unit *must* go back to the factory or a designated agent for resealing. The internal hardware *must* be inspected for possible tampering. Any other approach would make it trivially easy to subvert the entire system. That is, there are other units which have a small battery that when removed for replacement, cause the same problem. How do other manufacturers handle this? The usual approach to allow replacement of the lithium cell, is to apply external power during the replacement. To my knowledge, only the GPS-NAV allows for replacement of the cell, without opening the case (and without unsealing the unit). For all other approved flight recorders using lithium cell (some use long lived rechargeable cells), when it dies, the seal is lost, and it's time for a trip to the factory. Marc |
Marc Ramsey wrote:
5Z wrote: I suspect you send it back and have it resealed. Sounds like you broke the tamper seal in the device. It *may* still be usable as an insecure FR, but forget badges or records. Tom is correct, you broke the electronic seal. It needs to go back to the factory or an authorized agent. Send an email to LX Navigation to find out what your options are... Marc If the LX20 loses power to the VRAM, or the tamper seal triggers it becomes unusable. It will not boot bast the Secret key not valid message and will not initialise the GPS, let alone display tasks, and record flights. Very secure. The 9V battery is reasonably easy to replace as long as you keep the external power on while you replace the battery. One little philips screw on the external casing, lever it out of the hole carefully and replace with equivalent. If the power is interrupted, and the lithium battery is no longer up to the job - almost guaranteed after 10 years - you are in trouble. If for any reason you get the dreaded "Secret Key Not Valid" disease your LX20 is in need of recussitation by a certified person. This only takes 20 minutes with a notebook, and the data cables, and the appropriate software and tools. Hint, charge it once a month even if you are not using it, they seem to "hibernate" rather than switch off completely, and there is always a slow drain on the battery. Email - Crtomir Rojnik and company will be able to help, but shipping it may not be cheap or convenient. Let's not go into how I got to learn all this... -- Bruce Greeff Std Cirrus #57 I'm no-T at the address above. |
Hi,
I'm working on getting approval from LX to fix the unit here in the USA as an agent for LX. If I don't get approved then Ed Hollestelle at Solaire Canada can definitely do it. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Bruce" wrote in message ... Marc Ramsey wrote: 5Z wrote: I suspect you send it back and have it resealed. Sounds like you broke the tamper seal in the device. It *may* still be usable as an insecure FR, but forget badges or records. Tom is correct, you broke the electronic seal. It needs to go back to the factory or an authorized agent. Send an email to LX Navigation to find out what your options are... Marc If the LX20 loses power to the VRAM, or the tamper seal triggers it becomes unusable. It will not boot bast the Secret key not valid message and will not initialise the GPS, let alone display tasks, and record flights. Very secure. The 9V battery is reasonably easy to replace as long as you keep the external power on while you replace the battery. One little philips screw on the external casing, lever it out of the hole carefully and replace with equivalent. If the power is interrupted, and the lithium battery is no longer up to the job - almost guaranteed after 10 years - you are in trouble. If for any reason you get the dreaded "Secret Key Not Valid" disease your LX20 is in need of recussitation by a certified person. This only takes 20 minutes with a notebook, and the data cables, and the appropriate software and tools. Hint, charge it once a month even if you are not using it, they seem to "hibernate" rather than switch off completely, and there is always a slow drain on the battery. Email - Crtomir Rojnik and company will be able to help, but shipping it may not be cheap or convenient. Let's not go into how I got to learn all this... -- Bruce Greeff Std Cirrus #57 I'm no-T at the address above. |
| Thread Tools | |
| Display Modes | |
| LX20 + Ipaq wiring | Bruce | Soaring | 2 | February 4th 06 11:40 PM |
| Cleaning bugs - the real secret | Maule Driver | Owning | 11 | January 18th 05 11:38 PM |
| GOP SECRET MEETINGS | Cribsheet | Piloting | 0 | October 5th 04 12:41 AM |
| Britain Reveals Secret Weapon - Chicken Powered Nuclear Bomb ! | Ian | Military Aviation | 0 | April 2nd 04 04:18 PM |
| Air Force launches rocket with secret military payload from Cape Canaveral | Otis Willie | Military Aviation | 0 | September 9th 03 10:07 PM |
