Different WAAS altitude readings
Old June 26th 04, 11:27 PM
Wyatt Emmerich
Default Different WAAS altitude readings
My Garmin 296 indicates 330 MSL at KHKS, which is correct. My Echo Flight
GPS indicates 140 MSL. Both are locked on to WAAS.
How can I have such a large discrepancy? Both units seem to be functioning
properly other than this.
Old June 26th 04, 11:51 PM
Bob Gardner
Can't address your problem, but AIM 1-1-20(a)(8) tells us not to use GPS
altitudes. Doesn't say anything about WAAS...yet.
Bob Gardner
"Wyatt Emmerich" wrote in message
Old June 27th 04, 12:15 AM
Wyatt Emmerich
Given this discrepancy, I understand why.
"Bob Gardner" wrote in message
Bob Gardner
Flight
functioning
Old June 27th 04, 12:23 AM
C J Campbell
1-1-20's title is "Wide Area Augmentation System (WAAS)." There is no
1-1-20(a)(8). 1-1-20(b) gives guidance and procedures for flying approaches
with vertical guidance from WAAS and says that some installations of WAAS
may be certified for precision approaches as having greater accuracy than
barometric altimeters.
Old June 27th 04, 12:29 AM
C J Campbell
As a follow-up to the previous post: the new instrument PTS that goes into
effect in October requires students to be familiar with precision,
non-precision, and approaches with vertical guidance. We need you to update
your book! At the very least, turn what is written in 1-1-20 into plain
English.
Old June 27th 04, 12:31 AM
C J Campbell
Your Echo Flight GPS is not functioning properly. My guess is that it is not
processing the WAAS signal. The difference between the two units should be
no more than 50 feet.
Old June 27th 04, 01:30 AM
Ron Rosenfeld
On Sat, 26 Jun 2004 22:27:34 GMT, "Wyatt Emmerich"
Actually, neither one may be accurate.
Depending on where you are on the field, I see charted elevations of
306-342'.
Airport elevations and GPS elevations are determined differently.
Actually, there are over twenty different standards for determining
altitudes. And how accurately a particular WAAS enabled GPS receiver
translates it's GPS altitude to "airplane" altitude can vary depending on
the software algorithms being used.
Although I would expect that TSO 146 certified GPS receivers would perform
the conversion in the same way, I would not have that expectation with
regard to portable, non-certified GPS receivers.
Old June 27th 04, 01:40 AM
Bob Gardner
I'm using the 2004 FAR-AIM as a convenience...guess I should have used my
Summit CD-ROM which is updated quarterly.
Bob
"C J Campbell" wrote in message
approaches
Old June 27th 04, 01:55 AM
Bob Gardner
I see that my reference should have been AIM 1-1-19(a)(8). Other than that,
the guidance remains the same.
I note the phrase "will be" sprinkled through the discussion of WAAS. Has
WAAS been approved for operational use? How many boxes have the
functionality described in 1-1-20?...I think the CX-80 does.
Bob Gardner
approaches
Old June 27th 04, 03:32 AM
John R. Copeland
Right now, the CNX-80 does not give vertical guidance, but that is
promised in software version 2.0, hopefully to be approved by Q3/2004.
That software v2.0 has been in flight test since Q4/2003.
I'm unaware of any box nearer than the CNX-80 to LPV capability.
---JRC---
"Bob Gardner" wrote in message =
I see that my reference should have been AIM 1-1-19(a)(8). Other than =
that,
=20
I note the phrase "will be" sprinkled through the discussion of WAAS. =
Has
=20
Bob Gardner
=20
"C J Campbell" wrote in =
message
Can't address your problem, but AIM 1-1-20(a)(8) tells us not to =
use GPS
1-1-20's title is "Wide Area Augmentation System (WAAS)." There is =
no
approaches
with vertical guidance from WAAS and says that some installations of =
WAAS
may be certified for precision approaches as having greater accuracy =
than
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 12:39 AM
Terminology of New WAAS, VNAV, LPV approach types Tarver Engineering Instrument Flight Rules 2 August 5th 03 03:50 AM
Big News -- WAAS GPS is Operational for IFR Lockheed employee Instrument Flight Rules 87 July 30th 03 02:08 AM
Garmin Behind the Curve on WAAS GPS VNAV Approaches Richard Kaplan Instrument Flight Rules 24 July 18th 03 01:43 PM
