The situation:
The aircraft was originally certified without an electrical system. It's usually flown with a handheld radio powered by a battery. The battery is dead. The airport is non-towered. The wind is nearly 90 degrees crosswind. You haven't been able to fly in 4 weeks, and if you don't fly today, you won't be able to get in the air for at least another week. Would you fly? |
How busy is the field? How strong is the crosswind?
Mike Schumann "Robert Tenet" wrote in message ... The situation: The aircraft was originally certified without an electrical system. It's usually flown with a handheld radio powered by a battery. The battery is dead. The airport is non-towered. The wind is nearly 90 degrees crosswind. You haven't been able to fly in 4 weeks, and if you don't fly today, you won't be able to get in the air for at least another week. Would you fly? |
system. It's usually flown with a handheld radio powered by a battery. The battery is dead. The airport is non-towered. The wind is nearly 90 degrees crosswind. You haven't been able to fly in 4 weeks, and if you don't fly today, you won't be able to get in the air for at least another week. Would you fly? Not enough information. Radio out in and of itself at an uncontrolled field wouldn't stop me, but that would depend on the field too. There can be other NORDOs in the pattern, and the pattern could also be empty. Assuming my MK-1 eyeball is in good shape, that's what one uses primarily. What is the strength of the wind. 6 knots at 90 degrees in a nosewheel is different from 20 knots at 90 degrees in a tailwagger. Although it's been a month since my last flight, how proficient am I? Maybe quite proficient, maybe too rusty to solo on a calm day - it depends on experience, competence, and other things. Jose -- The price of freedom is... well... freedom. for Email, make the obvious change in the address. |
Robert Tenet wrote in
: The situation: The aircraft was originally certified without an electrical system. It's usually flown with a handheld radio powered by a battery. The battery is dead. The airport is non-towered. The wind is nearly 90 degrees crosswind. You haven't been able to fly in 4 weeks, and if you don't fly today, you won't be able to get in the air for at least another week. Would you fly? If the crosswind component was within my personal, and the aircraft's limits, yeah, why not? -- -- ET :-) "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams |
I would. But of course ATC won't be able to help you if your engine
stalls. ![]() -- Gene Seibel Tales of Flight - http://pad39a.com/gene/tales.html Because I fly, I envy no one. |
"Mike Schumann" wrote:
How busy is the field? How strong is the crosswind? One operation every 10-20 minutes. Crosswind strong, but easily within your capabilities. However, it is variable enough that after takeoff it might change the preferred T/O or landing direction. |
Only if I felt comfortable
Robert Tenet wrote: The situation: The aircraft was originally certified without an electrical system. It's usually flown with a handheld radio powered by a battery. The battery is dead. The airport is non-towered. The wind is nearly 90 degrees crosswind. You haven't been able to fly in 4 weeks, and if you don't fly today, you won't be able to get in the air for at least another week. Would you fly? |
"Jose" wrote in message . .. The aircraft was originally certified without an electrical system. It's usually flown with a handheld radio powered by a battery. The battery is dead. The airport is non-towered. The wind is nearly 90 degrees crosswind. You haven't been able to fly in 4 weeks, and if you don't fly today, you won't be able to get in the air for at least another week. Would you fly? Not enough information. Radio out in and of itself at an uncontrolled field wouldn't stop me, but that would depend on the field too. There can be other NORDOs in the pattern, and the pattern could also be empty. Assuming my MK-1 eyeball is in good shape, that's what one uses primarily. What is the strength of the wind. 6 knots at 90 degrees in a nosewheel is different from 20 knots at 90 degrees in a tailwagger. Although it's been a month since my last flight, how proficient am I? Maybe quite proficient, maybe too rusty to solo on a calm day - it depends on experience, competence, and other things. Jose -- The price of freedom is... well... freedom. for Email, make the obvious change in the address. Thankfully the plane also has a Mode S transponder and fish finder that is installed and working as well as a G1000 panel! I'll fly it. --------------------------------------------- DW |
Robert Tenet wrote: Would you fly? probably. -- Bob Noel Looking for a sig the lawyers will hate |
Do not feed the trolls.
| Thread Tools | |
| Display Modes | |
| MX385 Radio removal | Marty from Florida | Owning | 3 | May 24th 13 09:26 AM |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 06:39 PM |
| 1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 11:57 PM |
| Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 04:30 AM |
