Starduster Too...experiences?
Old May 4th 06, 08:33 PM posted to rec.aviation.homebuilt
Default Starduster Too...experiences?
My quest to find "the ideal" homebuilt bipe continues.
Has anyone got any build experiences with the Starduster Too? It looks
pretty, but is "pretty" another word for "very difficult"?
I have seen the AS&S web site - nice - so have to ask...do most people buy
kits in stages and build from that or what? Or do they just buy a sheet of
plans? (Can't believe that). It seems most folk in the UK buy ready made
from the States! Eek!
Anyone know what the 'hole' size is like on the Starduster? I'm well over 6
feet tall and 200lb
David
Old May 4th 06, 09:56 PM posted to rec.aviation.homebuilt
"david" wrote in message
of plans? (Can't believe that). It seems most folk in the UK buy ready
made from the States! Eek!
6 feet tall and 200lb
David
Hole size is about the only question I can answer. I too am tall. 6'2", and
205, and I fit very well in either seat. My friend has just finished his
Starduster II(with a continental radial), and I got to taxi it last weekend,
it hasn't flown yet. The only problem I had was taxiing from the front seat.
There is a cross member just above the landing gear, that runs about 5"
behind the rudder pedals. With my feet on the pedals, my heel jammed the
cross member, and locked the rudder in position. It could be a problem, so
he'll probably disconnect the forward pedals when carrying pax.
Al
Old May 4th 06, 10:32 PM posted to rec.aviation.homebuilt
Thanks Al
D
"Al" wrote in message
buy kits in stages and build from that or what? Or do they just buy a
sheet of plans? (Can't believe that). It seems most folk in the UK buy
ready made from the States! Eek!
David
and 205, and I fit very well in either seat. My friend has just finished
his Starduster II(with a continental radial), and I got to taxi it last
weekend, it hasn't flown yet. The only problem I had was taxiing from the
front seat. There is a cross member just above the landing gear, that runs
about 5" behind the rudder pedals. With my feet on the pedals, my heel
jammed the cross member, and locked the rudder in position. It could be a
problem, so he'll probably disconnect the forward pedals when carrying
pax.
Al
Old May 5th 06, 12:07 AM posted to rec.aviation.homebuilt
feet tall and 200lb
David
I have the plans, but have not built it (yet) There are two books out
there on people's experience building and flying the starduster. One
is called "Building the Golduster"( an aerobatic version) by James
McKeehan, the other is called "Starduster" I think and is more of a
novel than a howto. Jimi at Desert Eagle had an early version
partially built for sale last year. Don't know if he sold it or not. It
was just the airframe. I used to follow the builders forum pretty
closely. Pretty in this case does add difficulty. The wings are far
from cookie cutter, so each rib is different I am pretty sure. I don't
have the plans with me. The plans by the way are beautifully done, or
at least the ones that I got were. The business has changed hands since
I bought mine. My plan was to tackle something simpler first. It is
an absolutely beautiful plane up close. A common complaint on the
builders site used to be that the resale value was on par or lower than
the build cost, which might explain why UK buyers go for the complete
airframes.
Charles
Old May 5th 06, 05:20 PM posted to rec.aviation.homebuilt
Don't overlook the Steen Skybolt. Fantastic aircraft and nice size.
Rich S.
Old May 5th 06, 09:07 PM posted to rec.aviation.homebuilt
"Rich S." wrote in
Rich S.
Anyone know a good biplane that would do well with a 110HP Corvair???
(about 235lbs FWF)
-- ET :-)
"A common mistake people make when trying to design something
completely foolproof is to underestimate the ingenuity of complete
fools."---- Douglas Adams
Old May 6th 06, 12:52 AM posted to rec.aviation.homebuilt
"ET" wrote in message
"Rich S." wrote in
Rich S.
(about 235lbs FWF)
I think I've seen a Hatz with a Corvair at OSH. It was good enough to get
there.
Tom
Old May 6th 06, 06:40 AM posted to rec.aviation.homebuilt
("ET" wrote)
(about 235lbs FWF)
When people use that term, does that mean the prop, too?
Montblack
Old May 6th 06, 03:27 PM posted to rec.aviation.homebuilt
"Montblack" wrote in
("ET" wrote)
(about 235lbs FWF)
Montblack
It depends on the person...grin But in this case, yes.
-- ET :-)
Old May 8th 06, 07:15 PM posted to rec.aviation.homebuilt
David
Didn't build it, so also can only answer the hole size question, at
6'4", 250 I have trouble with my left knee interfering with the mixture, so
can't quite get full left aileron. This is in the rear seat only. The
front seat is quite a bit roomier. Regarding the cross member problem
you mention, ours has aluminum sheet screwed to the floor, and wrapped
around the tube to prevent feet getting caught. It can be seen at
extreme right at:
http://www.xmission.com/~bifft/plane/bungee.jpg
(this picture was taken to show the worn bungee cord, just got those
replaced this weekend)
External pictures at:
http://www.xmission.com/~bifft/plane/index.htm
Brian Huffaker, DSWL )
RV-8A drilling roll bar
1/4 N23UT flying.
Experiences with the new LockMart FSS? john smith Piloting 11 July 26th 07 02:39 PM
Starduster Too for Aerobatics Jay Moreland Aerobatics 0 November 15th 04 06:16 AM
Stolp Starduster bill Home Built 2 August 30th 04 05:53 AM
Stolp Starduster 1 help needed bill Home Built 0 August 22nd 04 02:59 AM
Hispanic Hero Recalls Experiences Otis Willie Military Aviation 0 September 30th 03 11:02 PM
