AUTOPILOT PROS & CONS
Old May 5th 06, 04:58 AM posted to rec.aviation.ifr
Default AUTOPILOT PROS & CONS
I got my IFR rating 7 months ago. I use the KAP140 autopilot a lot. From
climb-out to MDA/DA. I find it really helps in my management of the plane
and the IFR flight. I am interested in comments regarding the pros and cons
of a heavy use/reliance on the autopilot.
Old May 5th 06, 05:15 AM posted to rec.aviation.ifr
I never use it. I don't feel like I'm flying if I don't have my hand on
the yoke. I don't fly IFR enough that I want to risk losing the
proficiency I have, and although it has been said that one is safer with
the autopilot on, I believe one =becomes= less safe relying on it.
Jose
The price of freedom is... well... freedom.
Old May 5th 06, 05:48 AM posted to rec.aviation.ifr
An autopilot is very useful as long as it is used properly.
In VMC, use the autopilot to fly the departure, allowing you
more time to scan for traffic. This is very important in
night VMC. Use the autopilot at cruise to let you rest and
while checking on weather. Use the autopilot for some of
your approaches so you are proficient in the management of
the system. But hand fly enough so you are 100% proficient
because the autopilot can fail.
If you had a live copilot, you would share legs, treat the
A/P the same, use it as an aid not a crutch. Be sure to
read the entire POH supplement and know all the limitations
and failure modes.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"STICKMONKE" wrote in message
the pros and cons
Old May 5th 06, 10:13 AM posted to rec.aviation.ifr
Stickmonke,
As one data point: In Germany, single pilot IFR flying requires the
aircraft to have at least a two-axis autopilot (that is, including
altitude hold).
Thomas Borchert (EDDH)
Old May 5th 06, 10:35 AM posted to rec.aviation.ifr
I have always used an autopilot if it's available for cruise flight only. I
hand fly all climb outs and approaches. As a matter of fact, since nothing I
have access to these days has an autopilot, I hand fly the entire flight. G
Mortimer Schnerd, RN
VE
Old May 5th 06, 10:42 AM posted to rec.aviation.ifr
With a panel mount IFR GPS, you can easily fail to do a traffic watch or
perhaps properly control the airplane when not using an autopilot.
Old May 5th 06, 01:17 PM posted to rec.aviation.ifr
altitude hold).
But is the pilot required to use it? :-)
Bob Noel
Looking for a sig the
lawyers will hate
Old May 5th 06, 01:39 PM posted to rec.aviation.ifr
Bob,
Well, if you don't, "ve haf wais off makink yu!" ;-)
Old May 5th 06, 01:52 PM posted to rec.aviation.ifr
"Mortimer Schnerd, RN" wrote in message
cons
I hand fly all climb outs and approaches. As a matter of fact, since
nothing I have access to these days has an autopilot, I hand fly the
entire flight. G
Cessna and most other "heavy metal" manufacturers, as well as such
publications as "Professional Pilot" recommend use of the autopilot
immediately after takeoff to enhance scanning for traffic. Since the
overwhelming majority of mid-air's occur in the airport area and during
climb out and descent, that makes good sense.
Old May 5th 06, 01:53 PM posted to rec.aviation.ifr
"Sam Spade" wrote in message
news:Q5F6g.175210$bm6.21298@fed1read04...
Why would a panel mount GPS make much difference, compared to a hand held,
or VOR/airways vector?
Experimental Catagory: Pros and Cons? [email protected] Soaring 18 April 16th 06 10:56 PM
Long Tow Rope Pros & Cons chris Soaring 7 December 10th 03 02:30 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
