O2 Flowmeter Management
Old May 6th 06, 02:20 AM posted to rec.aviation.soaring
Default O2 Flowmeter Management
How does the general soaring poplulation manage their oxygen flowmeter and
tubing?
I have a Standard Jantar and would like to mount the flowmeter in the
cockpit somewhere that I can reach (the panel would be too far) and not
have to grab and hold it verticle to read/adjust.
Any ideas would be appreciated.
Thanks,
Dave
Old May 6th 06, 05:18 AM posted to rec.aviation.soaring
tubing?
Thanks,
Dave
Dave
I don't know what brand of flowmeter you have but if it is an Aerox
brand, a plastic clip for holding a pen can be purchased at most office
supply stores. Velcro this to a convenient spot and pop the site tube
into the clip.
Paul
Old May 6th 06, 04:56 PM posted to rec.aviation.soaring
Dave,
I prefer the Mountain High holster system. Set the flow in the range
you are flying, then you can use the pneumatic switch to turn the flow
on and off. It tends to save the over stress on the needle valve using
it as an on/off as well as flow control. The holster has straps so it
can be Velcroed to a side panel or around your leg. I very seldom
change mine in flight. Set it for the range of flight and use the
on/off valve if I get low.
Tim
Old May 7th 06, 03:33 PM posted to rec.aviation.soaring
Hi Tim
I am curious what kind of pneumatic switch you are using?
Thanks
Brian
TTaylor at cc.usu.edu wrote:
Dave,
Tim
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Air Safety at risk by Unqualified FAA Management Peterpan Instrument Flight Rules 4 February 24th 05 02:00 PM
Power management on a O-300 Victor Piloting 0 July 9th 04 02:09 AM
Boeing Scaling Back its Air Traffic Management Business Larry Dighera Piloting 9 March 13th 04 03:36 PM
Air Force announces acquisition management reorganization Otis Willie Military Aviation 0 August 21st 03 10:16 PM
