Accuracy of GPS in Garmin 430/530
Old May 7th 06, 05:29 PM posted to rec.aviation.ifr
Default Accuracy of GPS in Garmin 430/530
"Sam Spade" wrote in message
news:N1H4g.174532$bm6.101296@fed1read04...
You need to get a better grasp on your employer's policy and
implementation programs. Headquarters has made it abundantly clear that
GPS cannot be used for primary IFR navigation unless the device complies
with TSO 129, 145, or 146 (or is a certified FMS/LNAV integrated
platform).
Please cite the FAR in which that has been made clear.
Then, the avionics manufactors of 129, 145, or 146 boxes must
prove compliance before they receive certification. And, then the device
has to be installed in an approved manner to satisfy Part 23.
We're talking about handheld GPS.
The AIM material I cited reflects that policy.
When that policy is promulgated in an FAR it will become legally binding.
  #102
Old May 7th 06, 05:39 PM posted to rec.aviation.ifr
news:hWG4g.174529$bm6.47479@fed1read04...
In your view of the world, lots of FSDO inspectors are irrational.
I don't know if lots of them are, but I do know that those I have
communicated with on this subject tend to be.
I won't go into the view that FSDO inspectors have of ATC personnel.
Well, I knew one that didn't like them at all. Of course, his view was of
someone that went to FSDO after washing out of ATC. I've heard of other
FSDO types that went there after washing out of ATC, I've never heard of
anyone washing out of FSDO and moving up to ATC.
As to all the point/counterpoint about handhelds and Part 23, we agree
that a "non-installed" handheld is not subject to any provision of Part
23. What you fail to understand is that, unless a particular item of
avionics that is to be used for primary IFR navigation is so certified, it
cannot be used for primary IFR navigation.
Please cite the applicable FAR.
Further, if it is certified
for primary IFR navigation, it then has to be installed in compliance with
Part 23. A handheld doesn't quite make the program.
And, please, don't tell me to prove it. Your resource is any G/A
maintenance inspector at your local, friendly FAA FSDO.
I've already directed this question at a number of FSDOs. None of them
could cite the applicable FAR. The reason none of them could cite an
applicable FAR is there is none and thus use of a handheld GPS for IFR
enroute use in US controlled airspace is perfectly legal.
  #103
Old May 7th 06, 05:41 PM posted to rec.aviation.ifr
"Ron Lee" wrote in message
Steven, since you are so sure of yourself please go make an IFR flight
in VFR conditions with an FAA type who can bust you for doing bad
things.
Please define "bad things".
Then while on an IFR flight plan resort to only using your
handheld and dare him to cite you.
What do you think he'd cite me with?
  #104
Old May 7th 06, 10:41 PM posted to rec.aviation.ifr
Just do it Steven and report back to us.
Ron Lee
things.
  #105
Old May 8th 06, 02:56 PM posted to rec.aviation.ifr
In other words, you haven't the slightest idea about what I could be cited
with.
  #106
Old May 8th 06, 06:15 PM posted to rec.aviation.ifr
with.
No, in other words, you rant and rave about something and you won't
actually go do it. Prove to us unenlightened souls that you are
right.
Ron Lee
  #107
Old May 8th 06, 06:22 PM posted to rec.aviation.ifr
right.
I'll make the flight if you're willing to pay for it. If not you can either
accept a FSDO review of a hypothetical flight or remain an unenlightened
soul.
  #108
Old May 22nd 06, 07:27 AM posted to rec.aviation.ifr
FAA Order 8360.38a says the equipment must comply with TSO C129. FAA Orders
are incorporated into CFR 14.
I think a pilot using a handheld GPS (not complying with TSO C129) under IFR
would be cited with:
91.13 - Careless and Reckless
91.205(d)(2) - appropriate navigation equipment
  #109
Old May 26th 06, 08:33 PM posted to rec.aviation.ifr
"Cox" wrote in message
news:uRccg.31356$fG3.21351@dukeread09...
Orders are incorporated into CFR 14.
Title 1 CFR Part 51 provides for the incorporation of publications by
reference. One such example in the FARs is the incorporation of FAA Order
7400.9N, Airspace Designations and Reporting Points, in FAR 71.1. Please
cite the FAR that incorporates FAA Order 8360.38A by reference.
IFR would be cited with:
FAR 91.13(a) prohibits the operation of an aircraft in a careless or
reckless manner so as to endanger the life or property of another. Use of a
handheld GPS under IFR in US controlled airspace does not endanger any life
or any property.
FAR 91.205(d)(2) requires a two-way radio communications system and
navigational equipment appropriate to the ground facilities to be used. It
does not prohibit the use of any equipment beyond what is required to be
installed.
  #110
Old May 26th 06, 09:43 PM posted to rec.aviation.ifr
That would be automatic in any enforcement case of this type.
Garmin backing away from additional GDL-69 features for 430/530 products? Andrew Gideon Owning 2 September 9th 05 11:36 PM
Inexpensive Garmin 430/530 question vlado Owning 2 May 19th 05 03:21 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
WAAS and Garmin 430/530 DoodyButch Owning 23 October 13th 03 04:06 AM
Garmin 430/530 Questions Steve Coleman Instrument Flight Rules 16 August 28th 03 09:04 PM
