IFR use of handheld GPS
Old May 9th 06, 02:46 PM posted to rec.aviation.ifr
Default IFR use of handheld GPS
"Sam Spade" wrote in message
news:FO%7g.176005$bm6.51757@fed1read04...
In your usual evasive style I noticed you ignored my post about service
volumnes and VFR on top.
Based on your post, he evaded EVERYTHING (i.e., original post is totally
blank).
  #192
Old May 9th 06, 03:01 PM posted to rec.aviation.ifr
news:XSg7g.175495$bm6.14199@fed1read04...
And, we hope it is applied.
Application is not optional.
So long as no one forgets or makes a mistake.
  #193
Old May 9th 06, 03:48 PM posted to rec.aviation.ifr
"Steven P. McNicoll" wrote:
"Ron Lee" wrote in message
You have neither answered my questions nor done what I suggested. Why
not?
Your "questions" were actually one question. I answered them when I said
anything can malfunction. I'll do what you suggested after you send me
money to pay for the flight.
I'm left to conclude you cannot answer my question.
I'm left to conclude that you are not a pilot to entrust with anyone's
life. Do you need a reg to tell you not to fly into thunderstorms?
Do you need a reg to tell you not to fly into known icing conditions
with an aircraft not approved for it?
Do as you wish. Just don't take anyone with you should you fall prey
to Darwinism.
Ron Lee
  #194
Old May 9th 06, 04:09 PM posted to rec.aviation.ifr
life.
Upon what do you base that conclusion?
Nope. Do you?
Nope do you?
to Darwinism.
Do you see any similarity at all between flying into thunderstorms or flying
into known icing conditions with an aircraft not approved for it and
enroute IFR navigation by handheld GPS in US controlled airspace?
  #195
Old May 9th 06, 04:46 PM posted to rec.aviation.ifr
But those ordinary VOR receivers will do approximately nothing for
you, when flying direct to a faraway VOR they cannot pick up yet, thus
they are not "appropriate to the ground facilities to be used".
They're fully appropriate when I'm actually using them.
This rather Clintonian argument ("to be used" vs "I wish to use")
opens the door to kooky things like flying an ILS with a handheld GPS.
("Sure I have one on board, but the FARs don't say I have to USE it
...."), or ignoring monitoring instruments ("my engine oil temp may
have been at redline, but I don't have to LOOK at it").
A 91.13 citation would fit perfectly, should something go wrong.
- FChE
  #196
Old May 9th 06, 05:19 PM posted to rec.aviation.ifr
"Frank Ch. Eigler" wrote in message
Folks, take notice of the absurd lengths the true believers have to go to
justify their faith.
How would it open that door? Why would anyone attempt to fly an ILS with a
GPS of any kind instead of the LOC and GS receivers? I've already pointed
out that I'm in full compliance with FAR 91.205, I have navigational
equipment appropriate to all the ground facilities that may be used.
Actually, it wouldn't fit at all. FAR 91.13 applies to operation of an
aircraft in a careless or reckless manner so as to endanger the life or
property of another.
  #197
Old May 9th 06, 09:01 PM posted to rec.aviation.ifr
to Darwinism.
Ron Lee
So you now assume that navigating direct with a handheld GPS is
dangerous? Why is that? I can understand why people disagree whether
its "legal" or not, but safety? And pushing RAIM won't convince me.
I've seen almost as many IFR panel mount units give unreliable data or
drop out unexpectedly as I have seen that happen in handhelds. And
just a couple of days ago someone related the story in another thread
regarding his glideslope instrumentation going bad and causing the
autopilot, on a coupled ILS, to reach DH some two miles early. I'd
call that a safety issue.
  #199
Old May 10th 06, 12:13 AM posted to rec.aviation.ifr
Bob Noel wrote:
If you don't understand RAIM, then why bother asking about safety?
I didn't say I didn't understand RAIM. I just don't care. I am not
convinced that it is necessary for enroute navigation that can be
"safely" accomplished with 30-year old VOR receivers.
My question is how is using a handheld GPS while in radar contact
unsafe? Or more to the point, how is it less safe than using a
combination of radar vectors and VORs? Is "fly heading 320, direct XYZ
VOR when able" any safer?
Sure a panel-mount TSOed IFR approved GPS is supposed to tell you when
its got an inconsistent solution of your position, and therefore it is
more reliable than a handheld, but we're not comparing panel mounts
with handhelds. We're comparing ADF/VOR navigation with handheld GPS.
Peter
HANDHELD RADIO [email protected] Soaring 22 March 17th 16 03:16 PM
Navcom - handheld VS panel ? [email protected] Home Built 10 October 31st 05 08:08 PM
GPS Handheld Kai Glaesner Instrument Flight Rules 2 November 16th 04 04:01 PM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 03:33 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
