#11
![]() "Icebound" wrote: [...] The MAPs that don't specify a hold... seem to (always?) put you in at altitude and into a position suitable for a second approach. Somebody needs to confirm whether that is on purpose so that you can begin the second approach immediately??? (in the absence of instructions to the contrary, of course) It may be just a coincidence. Recall that being cleared for the approach does not authorize multiple tries (in case one doesn't break out), just one. The default procedure, as exemplified in the lost-comm (or too-low-for-radio) rules, is to head off to one's alternate. The MAP has to be a point whence one can do that, so it has en-route-level obstacle clearance just like an initial fix. - FChE |
![]() "Frank Ch. Eigler" wrote in message ... ... Recall that being cleared for the approach does not authorize multiple tries (in case one doesn't break out), just one. The default procedure, as exemplified in the lost-comm (or too-low-for-radio) rules, is to head off to one's alternate. The MAP has to be a point whence one can do that, so it has en-route-level obstacle clearance just like an initial fix. Okay, so do I have this right: In Canadian procedure, after a missed approach, I proceed as per the MAP on the plate. If I reach the end of the procedure without hearing from the controller (or being able to reach him), I do not hold (unless a hold is explicitly indicated), but I just proceed to my alternate. Otherwise, I WILL hear from the controller... for a new approach clearance, or other instructions. ? ? ? ? |
![]() "Icebound" writes: [...] Okay, so do I have this right: In Canadian procedure, after a missed approach, I proceed as per the MAP on the plate. If I reach the end of the procedure without hearing from the controller (or being able to reach him), I do not hold (unless a hold is explicitly indicated), but I just proceed to my alternate. [...] Different Canadian procedure manuals vary in their specificity regarding this situation. Our AIP RAC 9.26 says that a hold is implied at the end of the missed approach procedure, unless other clearance is issued. I found no clear indication of this in our Instrument Procedures Manual, nor the Air Regulations proper. Anyway, in case one cannot get hold of a new clearance, the challenge becomes picking a point at which one deems communication to have been lost, to authorize exiting the hold and divert to an alternate. This suggests that the US & Canadian systems are alike in these areas after all. - FChE |
![]() "Frank Ch. Eigler" wrote in message ... "Icebound" writes: [...] Okay, so do I have this right: In Canadian procedure, after a missed approach, I proceed as per the MAP on the plate. If I reach the end of the procedure without hearing from the controller (or being able to reach him), I do not hold (unless a hold is explicitly indicated), but I just proceed to my alternate. [...] Different Canadian procedure manuals vary in their specificity regarding this situation. Our AIP RAC 9.26 says that a hold is implied at the end of the missed approach procedure, unless other clearance is issued. That's interesting, because then why would some plates specify the hold explicitly and others (most others) do not? And what track would you hold on? Or do they only specify the hold explicitly when it has to be on a specific track, and otherwise it is safe to choose your own track? I found no clear indication of this in our Instrument Procedures Manual, nor the Air Regulations proper. Anyway, in case one cannot get hold of a new clearance, the challenge becomes picking a point at which one deems communication to have been lost, to authorize exiting the hold and divert to an alternate. This suggests that the US & Canadian systems are alike in these areas after all. - FChE |
![]() "Frank Ch. Eigler" wrote in message ... "Icebound" writes: [...] Okay, so do I have this right: In Canadian procedure, after a missed approach, I proceed as per the MAP on the plate. If I reach the end of the procedure without hearing from the controller (or being able to reach him), I do not hold (unless a hold is explicitly indicated), but I just proceed to my alternate. [...] Different Canadian procedure manuals vary in their specificity regarding this situation. Our AIP RAC 9.26 says that a hold is implied at the end of the missed approach procedure, unless other clearance is issued. That's interesting, because then why is the hold explicitly specified on some plates but not onothers (not on *most* others)? And on what track should the "implied" hold be executed? Or is it that the "implied" hold will be safe on any track of your choosing, and that the plates show an explicit hold only when there is a requirement for execution on some *specific* track??? I found no clear indication of this in our Instrument Procedures Manual, nor the Air Regulations proper. Anyway, in case one cannot get hold of a new clearance, the challenge becomes picking a point at which one deems communication to have been lost, to authorize exiting the hold and divert to an alternate. This suggests that the US & Canadian systems are alike in these areas after all. - FChE |
implied at the end of the missed approach procedure, unless other clearance is issued. I found no clear indication of this in our Instrument Procedures Manual, nor the Air Regulations proper. OK, that would make sense. There has to be a concept of a clearance limit and some sort of a default action to take there. When commencing an IAP, the limit is the MAP, *not* the alternate airport, I would think. Not all these situations are lost-comm, either, the controller could just be busy for a while, giving someone a long clearance, missed the call on a congested frequency, etc. It can take just a few minutes to execute a simple missed in a faster airplane. An expectation to start right back up into the enroute structure without the benefit of little breathing room to sort things out would be highly inpractical, IMHO. |
I think there may be a general misunderstanding in this thread. You
have to distinguish between two different scenarios. 1) Approaches in controlled or uncontrolled airspace WITH communication to ATC; and 2) Approaches in uncontrolled airspace WITHOUT communication to ATC. Both scenarios assume uncontrolled airports, i.e. no tower, radio or RCO (remote controlled outlet) on the field (in those cases there's always someone to talk to and get missed approach instructions or instructions after the missed is commenced). 1) You are at one time on the way to the airport high enough to talk to ATC. ATC clears you for *AN* approach (this is the correct phraseology; which approach you do is up to you). YOU ensure terrain and obstacle clearance from then on using the information on the approach plate both for the actual approach and for the missed (e.g. YOU decide if you need a shuttle hold etc.). The missed will get you back in contact with ATC. Your clearance limit is the last fix in the missed approach instruction. You WILL be able to talk to ATC by then; otherwise follow lost comm. procedure. It's the same in the US: At or before the missed hold you will talk to ATC or go lost comm., only that there is very rarely a missed hold in Canada (and then only for terrain in mountainous areas). 2) This may be a concept unknown in the US: In Canada, you can do a complete IFR flight in IMC or VMC without ever talking to ATC or without ever getting a clearance, including take off, cruise, approach and missed. All that's required is that you are in uncontrolled airspace, squawk 1000 in low airspace, ensure terrain and obstacle clearance, talk to the required MFs (mandatory frequencies) and broadcast all your intentions on 126.7. In this case, you do what you have to do and on the missed, go wherever you can land. Should you have to enter controlled airspace, contact ATC and get a clearance. You can NOT enter controlled airspace without a clearance if you are not VFR. That's it - no more, no less. On the missed, you either talk to ATC (or you follow lost comm. procedures) or you are uncontrolled and on your own. Gerd |
As another poster said correctly (that's what I kinda meant by lost
comm. procedures) refer to AIP RAC 9.26 where there is a whole list of holding options if you don't get hold of ATC before reaching the missed approach holding fix. But - as in the US - you cannot hold forever and then it's off to the lost comm. procedures. Gerd |
That's it - no more, no less. On the missed, you either talk to ATC (or you follow lost comm. procedures) or you are uncontrolled and on your own. That is a good point (many people who learned to fly IFR in the lower 48 and southern Canada don't think of it that way, but the airspace system is designed to allow instrument flight from takeoff to touchdown without ever talking to anybody). But I think the discussion was not largely misunderstood, the basic question was what is the clearance limit at the end of an IAP in *controlled* airspace, and besides Frank's reference to the AIP, this has gone unanswered. Is it the MAP, at which point you enter either a published or standard holding pattern, or the alternate airport ? Sorry, not to nit-pick, but this is a real scenario - I just missed an approach, got busy reconfiguring the airplane and I am reaching the "climb-to" altitude 0.5nm from the MAP with its *depicted* racetrack pattern at 120 knots. The frequency is congested and I can't get a word in. What should I do in Canada ? |
Canadian Aviation Expo - Europa will be attending | Pete | Home Built | 0 | June 17th 04 01:10 PM |
FAA's Instrument Procedures Handbook | Barry | Instrument Flight Rules | 3 | June 5th 04 07:31 PM |
Q about lost comms on weird clearance | Paul Tomblin | Instrument Flight Rules | 34 | February 2nd 04 09:11 PM |
Requirement to fly departure procedures | [email protected] | Instrument Flight Rules | 77 | October 15th 03 06:39 PM |
Holding Pattern Entries | Dan Luke | Instrument Flight Rules | 17 | July 11th 03 05:18 AM |
