Best Glide / Rate of Descent
Old May 9th 06, 09:29 PM posted to rec.aviation.piloting
Default Best Glide / Rate of Descent
With the throttle at idle, and plane trimmed for best glide, what is
your plane's descent rate (in fpm)?
I tried this with my Cherokee 180 and found the resulting descent to
be somewhere between 900 and 1000fpm. (This was measured on the VSI,
not via altimeter plus stopwatch, so it is prone to error).
Varying the glide airspeed 5 or 10 mile an hour did not make a big
change in the descent rat, probably 50fpm or so.
Anyone tried the same?
Old May 9th 06, 10:13 PM posted to rec.aviation.piloting
With an MD-80 use Gross Weight plus 100 kts. If you weighed 120,000#, fly
220 knots for best glide ratio.
Darrell R. Schmidt
B-58 Hustler History: (see below)
http://members.cox.net/dschmidt1/
"Nathan Young" wrote in message
Old May 9th 06, 10:19 PM posted to rec.aviation.piloting
Having crashed both, I can definitively state that a C-210 sinks at roughly 700
fpm cleaned up and a Piper Lance comes down at 1100 fpm in the same situation.
While the extra cabin space is nice, the Cherokees are definitely lead sleds
when it comes to power off descents.
Mortimer Schnerd, RN
VE
Old May 9th 06, 10:23 PM posted to rec.aviation.piloting
Did you read Barry Schiff's article on this subject in the May AOPA PILOT?
Bob Gardner
Old May 10th 06, 01:03 AM posted to rec.aviation.piloting
note that: i) the best glide *speed* as indicated in your POH is
given at gross weight; i.e., sticking to this *speed* all alone
with less than full tanks, etc., i.e., lighter, will not work
as well as advertised; and ii) best glide speed does NOT give you
minimum sink.
--Sylvain
Old May 10th 06, 02:37 AM posted to rec.aviation.piloting
Nathan Young opined
I got about the same results with a 172.
-ash
Cthulhu in 2005!
Why wait for nature?
Old May 10th 06, 03:03 AM posted to rec.aviation.piloting
On Tue, 9 May 2006 14:23:16 -0700, "Bob Gardner"
Yep, that's what reminded me that I wanted to post my findings. ( I
had flown the test descents about two weeks ago).
-Nathan
Old May 10th 06, 03:50 AM posted to rec.aviation.piloting
COZY MKIV, gross weight (2155 lb), about 115 mph (100 Kts), I'll get
about 650 fpm. At min. sink (maybe 95 mph), it'll be about 550 - 600
fpm. At lower weights (maybe 1800 lb), BG will be at 100 mph and 550
fpm, with min sink (around 90 mph) about 450 fpm.
IOW, BG gives an L/D of about 16 with the engine at idle. If the engine
was off (and the prop stopped), the L/D is about 13 - 14. There's a lot
of idle thrust, even at 1000 RPM.
Marc J. Zeitlin
http://www.cozybuilders.org/
Copyright (c) 2006
Old May 10th 06, 04:46 AM posted to rec.aviation.piloting
Best Glide 50 kts, Sink Rate 133 ft/min, Glide Ratio 38:1
http://www.soaridaho.com/Schreder/HP-16/N16VP.html
Brian
Old May 10th 06, 08:20 AM posted to rec.aviation.piloting
best glide 60 KIAS, wind 60 on the nose, sink rate 700 fpm.
Path is nearly vertical in this extreme example. If you
have to glide to a landing spot, pick some place downwind,
if you have to glide into the wind, you need to increase
speed, even if it increases sink rate. Your numbers will
vary, but keep the principle in mind.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Brian" wrote in message
| Brian
ASW19b best descent rate on approach (full airbrakes) Robert Sharpe Soaring 1 April 30th 05 11:41 AM
BRS and descent rate Roger Long Piloting 21 May 7th 04 05:34 PM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
Minimum rate of climb or descent Aaron Kahn Instrument Flight Rules 3 July 25th 03 03:22 PM
