Notes on NACO Obstacle Departure Procedures
Old July 15th 04, 07:18 PM
John Clonts
Default Notes on NACO Obstacle Departure Procedures
What's with these notes about all the obstacles? If I can fly the
take-off minimums and/or fly the ODP (if specified, not in the example
below), does such keep me clear of the noted obstacles? (I think the
answer is yes, but then-- what's the point?) Or do I have to do all
this pythagorea in my head?
Thanks,
John Clonts
Temple, Texas
N7NZ
Example:
KILLEEN, TX
KILLEEN MUNI
TAKE-OFF MINIMUMS: Rwy 19, 1300-2 or std. with a
min. climb of 250' per NM to 2500.
NOTE: Rwy 1, multiple poles, 317' to 759' from departure
end of runway, 484' to 384' left of centerline, 48' AGL/
865' MSL. Tree, 973' from departure end of runway, 100'
left of centerline, 49' AGL/876' MSL. Building, 486' from
departure end of runway, 10' right of centerline, 30'
AGL/854' MSL. Antenna, 351' from departure end of
runway, 277' right of runway, 28' AGL/852' MSL.
Rwy 19, pole, 288' from departure end of runway, 558'
right of centerline, 43' AGL/880' MSL. Building, 102'
from departure end of runway, 411' right of centerline,
22' AGL/856' MSL. Road, 231' from departure end of
runway, 498' right of centerline, 30' AGL/867' MSL.
Pole, 256' from departure end of runway, 497' left of
runway, 36' AGL/873' MSL. Building, 275' from
departure end of runway, 442' left of runway, 36' AGL/
859' MSL. Building, 298' from departure end of runway,
83' left of runway, 36' AGL/857' MSL.
Old July 15th 04, 10:20 PM
Barry
Here's an explanation from the FAA's Instrument Procedures Handbook
(http://av-info.faa.gov/terps/IPH.htm):
Obstacles that are located within 1 NM of the DER [departure end of the
runway] and penetrate the 40:1 OCS [obstacle clearance surface] are referred
to as “low, close-in obstacles.” The standard ROC [required obstacle
clearance] of 48 feet per NM to clear these obstacles would require a climb
gradient greater than 200 feet per NM for a very short distance, only until
the aircraft was 200 feet above the DER. To eliminate publishing an excessive
climb gradient, the obstacle AGL/MSL height and location relative to the DER
is noted in the Take-off Minimums and (OBSTACLE) Departure Procedures section
of a given TPP booklet. The purpose of this note is to identify the obstacle
and alert the pilot to the height and location of the obstacle so they can be
avoided.
ADF Required Ted Timmons Instrument Flight Rules 30 April 6th 04 04:27 AM
Requirement to fly departure procedures [email protected] Instrument Flight Rules 77 October 15th 03 06:39 PM
