#11
![]() "Robin Birch" wrote in message ... Although I have not had the problem with instruments I have had it with PDAs in the cockpit. Personally I don't think that polarised sunglasses are the things to use when flying because of the possibility of seeing the stress lines and so on in the canopy and the possibility of interference with LCD displays. I much prefer tinted specs for this reason. Robin It sounds like you're stressing out . . . could this be the source of the stress lines? (g) bumper |
Robin Birch wrote:
Although I have not had the problem with instruments I have had it with PDAs in the cockpit. Personally I don't think that polarised sunglasses are the things to use when flying because of the possibility of seeing the stress lines and so on in the canopy and the possibility of interference with LCD displays. I much prefer tinted specs for this reason. I agree with your assessment that polarised glasses are not a good idea in the cockpit. They take away glare, and it is exactly that glare that might draw your attention to that other glider comming right at you. André |
![]() André Somers wrote: Robin Birch wrote: Although I have not had the problem with instruments I have had it with PDAs in the cockpit. Personally I don't think that polarised sunglasses are the things to use when flying because of the possibility of seeing the stress lines and so on in the canopy and the possibility of interference with LCD displays. I much prefer tinted specs for this reason. I agree with your assessment that polarised glasses are not a good idea in the cockpit. They take away glare, and it is exactly that glare that might draw your attention to that other glider comming right at you. André |
I have to agree with the previous posters. Polarized sunglasses are
intended to cut surface glare, so they are great if you are a boater. But unless you plan to land on water, they are of little benefit to a pilot. In addition to interfering with LCD displays, they show colored bands in the curved plexiglass, which can be distracting. Also, polarized glasses are usually grey, and an orange tint is much better at cutting UV for seeing through haze and picking up detail in clouds. I know you wear prescription glasses, so you may want to get another prescription pair of orange tinted non-polarized glasses for flying. You may also prefer them for driving as well. If you spend time near the water, the polarized pair will be better for that. André Somers wrote: Robin Birch wrote: Although I have not had the problem with instruments I have had it with PDAs in the cockpit. Personally I don't think that polarised sunglasses are the things to use when flying because of the possibility of seeing the stress lines and so on in the canopy and the possibility of interference with LCD displays. I much prefer tinted specs for this reason. I agree with your assessment that polarised glasses are not a good idea in the cockpit. They take away glare, and it is exactly that glare that might draw your attention to that other glider comming right at you. André |
There actually is a good FAA publication on Sunglasses at:
http://www.faa.gov/pilots/safety/pil...sunglasses.pdf "POLARIZATION. Polarized lenses are not recommended for use in the aviation environment. While useful for blocking reflected light from horizontal surfaces such as water or snow, polarization can reduce or eliminate the visibility of instruments that incorporate anti-glare filters. Polarized lenses may also interfere with visibility through an aircraft windscreen by enhancing striations in laminated materials and mask the sparkle of light that reflects off shiny surfaces such as another aircraft's wing or windscreen, which can reduce the time a pilot has to react in a "see-and-avoid" traffic situation." |
Instrument Checkride passed (Long) | Paul Folbrecht | Instrument Flight Rules | 10 | February 11th 05 02:41 AM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
PC flight simulators | Bjřrnar Bolsřy | Military Aviation | 178 | December 14th 03 12:14 PM |
