Good use for old radial egines?
Old May 16th 06, 12:52 AM posted to rec.aviation.piloting
Default Good use for old radial egines?
http://www.geocities.com/viewptmd/Radial.jpg
Old May 16th 06, 01:49 AM posted to rec.aviation.piloting
Is it a radial or a rotary?!!!!
Old May 16th 06, 01:56 AM posted to rec.aviation.piloting
Look fun, thanks.
Mo-
http://thekneeslider.com/
scroll down.
Old May 16th 06, 02:06 AM posted to rec.aviation.piloting
Most definitely a radial. A rotary is the Wangle (SP?) engine as in
the Mazda cars.
Monk
Old May 16th 06, 02:20 AM posted to rec.aviation.piloting
the Mazda cars
True, however in the context of a radial engine, a rotary
is like a radial except that the crank is bolted to
the aeroplane/motorcycle and the cylinders to the
propeller/whatever. This seemed more exciting
in a motorbike and therefore surely more
desireable?
I suspect that rotary engines preceeded radials
and I am pretty sure that for example the WW1
Sopwith Camel used a rotary.
Googling has turned up what may be a rotary engined
motorbike from a while back (1920s).
http://www.absoluteastronomy.com/enc.../me/megola.htm
http://www.cybermotorcycle.com/euro/brands/megola.htm
Unfortunately it appears to be safely ensconsed
within the front wheel. Not very exciting?
Well, steering may prove to be exciting?
Old May 16th 06, 02:23 AM posted to rec.aviation.piloting
"Flyingmonk" wrote in message
the Mazda cars.
Monk
Wankel engine
http://www.keveney.com/Wankel.html
I hate to think how much that bike weighs.
Old May 16th 06, 02:30 AM posted to rec.aviation.piloting
Wankel engine http://www.keveney.com/Wankel.html
Various manufactures (OK maybe 2) have made Wankel engined
bikes in production.
Norton
http://www.millville.org/workshops_f...ls/norton.html
They raced them seriously too IIRC.
I suspect that the Norton engine design may still be
in production. It used a novel rotor cooling
system where (IIRC) air was drawn through the inside
of the rotor. (Induction air? - surely not)
Suzuki
http://www.suzukicycles.org/RE5/RE5-Rotary.shtml
Sorry if this is too OT.
Old May 16th 06, 03:45 AM posted to rec.aviation.piloting
desireable?
I have heard, seen and read that some radials did have the shaft bolted
to the airframe. That would be really interesting to have on a bike
huh? I wonder who'll be the first to do that.
Monk
Old May 16th 06, 04:14 AM posted to rec.aviation.piloting
On 15 May 2006 19:45:39 -0700, "Flyingmonk" wrote in
. com:
... I have heard, seen and read that some radials did have the shaft bolted
to the airframe. ...
They were called "rotary engines." Very different from the Mazda rotary.
I simply could not believe my eyes the first time I saw one in the Curtiss
museum. I read the sign several times. I still thought someone must
have gotten it wrong.
The were used extensively in WW I by both sides.
Here is a magnificent page with an animated gif:
http://www.keveney.com/gnome.html
The only detail left off the page is the effect that the castor oil from
the total-loss lubricating system had on the pilots. It is said that
some landed off-field to deal with the consequent call of nature.
Most of the rotaries had no throttle. Some were on/off only.
Others could cut a few cylinders to reduce power.
I've seen some fly at Old Rhinebeck:
http://www.oldrhinebeck.org/
If I'm not mistaken, they're still flying a few vintage WW I engines,
not reconstructions.
You can hear the pilots blipping the on/off switch as they come
in for a landing.
Marty
Old May 16th 06, 04:33 AM posted to rec.aviation.piloting
bikes in production
Which of course is not even close to the true rotary engines of the early
1900s.
Wanted 5-cylinder B-75 Lawrence radial Chris Wertman Home Built 5 April 8th 10 02:11 AM
HAVE YOU HEARD THE GOOD NEWS! [email protected] Soaring 0 January 26th 05 07:08 PM
Good plans-built Light Sport Aircraft Rob Schneider Home Built 15 August 19th 04 05:50 PM
Free Volksplane to good home, located in Chino Hills CA Bryan Zinn Home Built 3 July 18th 04 02:55 AM
bulding a kitplane maybe Van's RV9A --- a good idea ????? Flightdeck Home Built 10 September 9th 03 07:20 PM
