Good use for old radial egines?
Old May 16th 06, 04:57 AM posted to rec.aviation.piloting
Default Good use for old radial egines?
I stand corrected. Thanks for that info and the links. Learn
something new every day. As Ms. Goody Two-Shoe Martha Stuart said,
It's a good thing.
Monk
Martin X. Moleski, SJ wrote:
On 15 May 2006 19:45:39 -0700, "Flyingmonk" wrote in
. com:
... I have heard, seen and read that some radials did have the shaft bolted
to the airframe. ...
They were called "rotary engines." Very different from the Mazda rotary.
I simply could not believe my eyes the first time I saw one in the Curtiss
museum. I read the sign several times. I still thought someone must
have gotten it wrong.
The were used extensively in WW I by both sides.
Here is a magnificent page with an animated gif:
http://www.keveney.com/gnome.html
The only detail left off the page is the effect that the castor oil from
the total-loss lubricating system had on the pilots. It is said that
some landed off-field to deal with the consequent call of nature.
Most of the rotaries had no throttle. Some were on/off only.
Others could cut a few cylinders to reduce power.
I've seen some fly at Old Rhinebeck:
http://www.oldrhinebeck.org/
If I'm not mistaken, they're still flying a few vintage WW I engines,
not reconstructions.
You can hear the pilots blipping the on/off switch as they come
in for a landing.
Marty
Wanted 5-cylinder B-75 Lawrence radial Chris Wertman Home Built 5 April 8th 10 02:11 AM
HAVE YOU HEARD THE GOOD NEWS! [email protected] Soaring 0 January 26th 05 07:08 PM
Good plans-built Light Sport Aircraft Rob Schneider Home Built 15 August 19th 04 05:50 PM
Free Volksplane to good home, located in Chino Hills CA Bryan Zinn Home Built 3 July 18th 04 02:55 AM
bulding a kitplane maybe Van's RV9A --- a good idea ????? Flightdeck Home Built 10 September 9th 03 07:20 PM
