Finally: The right-sized Thielert
Old May 18th 06, 02:09 AM posted to rec.aviation.owning
Default Finally: The right-sized Thielert
On Wed, 17 May 2006 17:42:17 -0700, "BTIZ"
Jet A is more expensive out our local pumps than 100LL but about 80cents.
BT
How much is home heating oil?
Don
Old May 18th 06, 02:17 AM posted to rec.aviation.owning
"BTIZ" wrote in message
news:JpPag.1293$rS6.170@fed1read11...
BT
Fairly common in areas where the "jet-setters" congregate, like Jackson
Hole, Squaw Valley, Aspen...
Old May 18th 06, 04:03 AM posted to rec.aviation.owning
On 17-May-2006, "soxinbox" wrote:
I wonder whether its constant speed or constant pitch. I also wonder how
much useful load it eats up.
I believe that the Thielert engines tend to be a bit lighter than gasoline
engines of comparable power. Useful load probably won't change that much
but PAYLOAD should get a nice bump up because the diesel's lower SFC means
less fuel will be needed for a given mission, even taking into account that
diesel fuel (which is essentially the same as Jet-A) is slightly heavier (in
lbs/gal) than gasoline.
I strongly suspect that any modern piston aircraft engine over 200 hp will
be configurable for a constant speed prop. However, FADEC might take
control of RPMs out of the pilot's hands
-Elliott Drucker
Old May 18th 06, 10:02 PM posted to rec.aviation.owning
Soxinbox,
Speed. But you as a pilot don't get to select it. There's just one
single lever for "noise control": Forward means more noise, pull back
and it gets quieter. That lever doesn't even have any mechanical
connection to the engine, only an electrical link to the engine control
units.
Oh, and the reaction to this information says a lot about how much a
pilot really wants innovation in aviation.
Thomas Borchert (EDDH)
Old May 29th 06, 04:06 AM posted to rec.aviation.owning
"Ronnie" writes:
I thought the fuel for these aviation diesel engine
was Jet A. Is the data below for Jet A or for
diesel fuel?
How does Jet A compare to gasoline?
Jet A == kerosene.
Gasoline is 6.25 lbs/gallon {at ~70F}
Kero is 6.84 lbs/gallon...
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old May 29th 06, 06:26 AM posted to rec.aviation.owning
"Thomas Borchert" wrote in message
Nope. It says how much a pilot wants to trust a small computer and its
software and engine actuators.
John Severyn @KLVK
Old May 29th 06, 10:51 AM posted to rec.aviation.owning
J.,
instead of a small mechanical linkage and its hardware?
Old May 29th 06, 12:18 PM posted to rec.aviation.owning
Hardware failure modes are much better understood.
What's the reliability of software?
Bob Noel
Looking for a sig the
lawyers will hate
Old May 29th 06, 02:56 PM posted to rec.aviation.owning
Bob,
Says who? Numbers, please.
Not sure I understand the question.
FlightAware web site -- finally free flight tracking Chip Hermes Instrument Flight Rules 24 September 15th 05 02:34 AM
FlightAware web site -- finally free flight tracking Chip Hermes Piloting 23 September 15th 05 02:34 AM
It's finally running! Corky Scott Home Built 19 April 29th 05 04:53 PM
Finally got my X-country in.. PJ Hunt Rotorcraft 0 December 18th 04 10:50 AM
Finally flying new Skyhawks! Scott Schluer Piloting 11 February 24th 04 10:02 PM
