Bubble injection behind the step on seaplanes
Old May 19th 06, 09:29 PM posted to rec.aviation.homebuilt
Default Bubble injection behind the step on seaplanes
I have been reading up on seaplanes (Seaplane Operations, by Cesare Baj
and Dale DeRemer) and one frequently repeated fact is that it is very
hard to get a seaplane up on the step on glassy water, because the lack
of bubbles under the float/hull causes the heel of the float/hull to
adhere to the water surface.
This seems like an easily solved problem -- inject bubbles behind the
step. Clearly if it were that easy it would be common practice. What
am I missing?
Here is my hull profile at the step:
To Heel -- Step -- To Bow
_____________________
O| /
x|______________________/
When moving at speed through the water, it seems that at point O there
should be a circulating eddy or turbulence, and at point x there should
be significant suction, yes? So if we attach at point x a hose, whose
one endpoint is at x and the other is above waterline, without any
further mechanics the low pressure at x should be sucking air through
the hose and introducing a trail of bubbles, slipping past the
turbulence at O and running along the undersurface of the heel. If we
put in a bunch of such hoses, or one long hose running along the back of
the step with a bunch of holes spaced along it, we should get a lot of
bubbles. Yes?
What am I missing?
~Adam
Old May 19th 06, 10:50 PM posted to rec.aviation.homebuilt
It's not a bad idea. You would have to build one and see if it works.
For all things seaplane go to www.seaplanes.org. They know a lot on
there.
Old May 19th 06, 11:08 PM posted to rec.aviation.homebuilt
Yep! The concept works. The basic idea is at least 100 years old.
Some racing speed boats use this.
JP
"Adam Aulick" kirjoitti
I have been reading up on seaplanes (Seaplane Operations, by Cesare Baj and
Dale DeRemer) and one frequently repeated fact is that it is very hard to
get a seaplane up on the step on glassy water, because the lack of bubbles
under the float/hull causes the heel of the float/hull to adhere to the
water surface.
step. Clearly if it were that easy it would be common practice. What am
I missing?
O| /
should be a circulating eddy or turbulence, and at point x there should be
significant suction, yes? So if we attach at point x a hose, whose one
endpoint is at x and the other is above waterline, without any further
mechanics the low pressure at x should be sucking air through the hose and
introducing a trail of bubbles, slipping past the turbulence at O and
running along the undersurface of the heel. If we put in a bunch of such
hoses, or one long hose running along the back of the step with a bunch of
holes spaced along it, we should get a lot of bubbles. Yes?
What am I missing?
~Adam
Old May 20th 06, 02:46 AM posted to rec.aviation.homebuilt
am I missing?
O| /
bubbles. Yes?
Look at the hull of any Lake Amphipian.
Old May 20th 06, 02:48 AM posted to rec.aviation.homebuilt
" What am I missing?
~Adam
Simplicity......
You need to look at pictures of any large seaplanes to see how they get the
step
"energized". The Shin Meiwa, for example, uses fences along the fuse side
to force a high volume of air into the step area. A fairly simple thing to
do
and you don't need to make hull penetrations to make it happen......
Have a great day
Scott
Old May 20th 06, 06:10 PM posted to rec.aviation.homebuilt
Indeed.
The lapstrake construction of the Viking longboats carried bubbles
down from the bow under the hull.
People sailing modern replicas report a sort of 'surge' and an
associated loss of rudder authority that corresponds to reaching
a certain critical speed.
FF
Old May 20th 06, 07:38 PM posted to rec.aviation.homebuilt
There is a picture about the subject ("Super Ventilated Positive Lift" in
this case)
http://www.fountainpowerboats.com/te...ain/racing.htm
JP
"JP" kirjoitti
JP
money Codeman Home Built 0 June 16th 05 06:13 AM
So I invested my US$6°°.....GUESS WHAT!!!... less than ten days later, I received money [email protected] Owning 1 January 16th 05 06:48 AM
Jet Seaplanes??? Roy Smith General Aviation 7 August 23rd 04 11:29 AM
Re; What do you think? Kelsibutt Naval Aviation 0 September 29th 03 06:55 AM
