Land Rover in C-130 commercial
Old May 20th 06, 02:10 AM posted to rec.aviation.piloting
Default Land Rover in C-130 commercial
This is an artificial limit that manufacturers design into their GPS units
to force you to pay a premium for a device that can be used in an aircraft.
Mike Schumann
"Jim Macklin" wrote in message
news:Wksbg.22187$ZW3.9577@dukeread04...
I have no doubt that they did drive a car into a C130. I
just question whether they went to the trouble to have the
GPS in the car actually work while in the cargo bay.
As for the speed limit on the GPS, I presume it is the rate
at which the computer can identify new positions and the CPU
can calculate, it is just a cheap $125 hand held.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Kingfish" wrote in message
| It is simulated, phony, ...
| I dunno, the documentary of the filming of the commercial
seemed legit.
| My recent hand held non-aviation GPS has a limit of 951
mph.
| What is the limit due to? Is there a refresh rate for a
GPS receiver?
| Is it a RAIM thing?
Old May 20th 06, 02:21 AM posted to rec.aviation.piloting
"Mike Schumann" wrote in message
nk.net...
aircraft.
That may have been true in the past. I recall marine units that had a very
low limit.
However, I have a handheld hiking unit that has a plenty high limit (don't
know what it is, but it works fine in the plane and even will show me my
speed in knots), and that explanation certainly doesn't seem relevant to the
951 mph limit mentioned previously in this thread (unless the market they
want to exclude are military and Concorde pilots).
Old May 20th 06, 04:17 AM posted to rec.aviation.piloting
While I acknowledge your emoticon, your post doesn't make any sense.
The special effects folks have nothing to do with the writers of the
ad. I made no mention about the realism of what I was seeing but rather
I questioned the whole premise of the ad campaign. Actually, the
commercial as I remember it had very little--if any--special effects.
Old May 21st 06, 03:57 AM posted to rec.aviation.piloting
In non aviation GPSs, at least the older ones, there really is a limitation
on speed. These units receive the signals from satellites one at a time. You
have to receive 4 satellites in order to calculate a 3 dimensional position.
If you are traveling extremely fast, than the signals from each satellite
are received at different physical positions. This makes it hard for the GPS
to resolve your position. Now here is the clincher : The speed at which the
GPS unit can switch between satellites determines the top speed at which the
GPS unit will work.
Aviation GPS units have simultaneous receive channels so that they can
receive up to 7 ( usually ) simultaneous signals. This eliminates the speed
restriction ( unless you are traveling close to the speed of light). I think
the simultaneous receive channels is starting to be used in higher end
non-aviation GPSs, perhaps like the one in the Land Rover.
In response to another posters comments about the reception inside the
plane: Most auto GPSs do have external antennae ports. It is just as hard to
get a signal through the top of a Land rover as it is a C130. My handheld
hiking GPS also has an antenna port.
That doesn't make any sense. You can measure your position every 30
seconds and still get an accurate speed measurement.
Whatever the reason for an upper bound on the displayed speed, it has
nothing to do with the rate at which the computer in the GPS can do
anything, whether identifying new positions, calculating, etc.
Pete
Old May 21st 06, 04:52 AM posted to rec.aviation.piloting
limitation on speed. These units receive the signals from satellites one
at a time. You have to receive 4 satellites in order to calculate a 3
dimensional position. If you are traveling extremely fast, than the
signals from each satellite are received at different physical positions.
This makes it hard for the GPS to resolve your position.
My son has a Palm Pilot V that has the GPS receiver plugged into the
expansion port. On a737, I was able to hold it up to a window, and get
altitude and speed locks, no problem, showing 540 MPH.
Jim in NC
Old May 21st 06, 05:20 AM posted to rec.aviation.piloting
"Marco Leon" wrote in message
......Considering Rover's target market is
probably a bit more intelligent than most,
Not necessarily true. Rover's target market merely likes to be told that
they're more intelligent.
Old May 21st 06, 05:32 AM posted to rec.aviation.piloting
GPS unit will work.
They do now. The first couple generations of aviation GPS's had those
receivers. The one I had was the Garmin 90. When I went to the Garmin
Pilot III it could simultaneously receive 12 sats. They all do that
now. What's funny is to look into the consumer GPS market, especially
bluetooth GPS's designed for use with a PDA or similar. The most
expensive models can track 30 satellites at a time.
Old May 21st 06, 05:52 AM posted to rec.aviation.piloting
"soxinbox" wrote in message
limitation on speed. [...]
You are right about the older satellites. However, that explanation is
irrelevant for the GPS being discussed here. Also, I don't see why the
limitation you're talking about would manifest itself as an upper bound on
the speed display; it would simply result in no position information at all
above a certain speed.
Pete
Old May 21st 06, 05:57 AM posted to rec.aviation.piloting
"Satellites", "receivers", same diff.
Old May 21st 06, 07:21 AM posted to rec.aviation.piloting
Kingfish wrote:
After seeing this commercial and viewing the documentary on the Land
Rover website, I still can't figure out how they got the GPS unit in
the truck to work while inside the plane. The doc. showed a guy
sticking something to the plane's windows that might be an antenna, but
I doubt a dash-mounted GPS in a car would have an external antenna
input? Also they said the speed of the plane might be an issue for the
GPS. Can't figure that part out either.
I have a very old GPS that has a speed limit of 105 I think....
something in the low 100's ... I know me and a friend exceeded it in his
BMW 3 series. However, pretty much any modern GPS has a speed limit in
the 900 to 1000 mph range. I would think that an in dash GPS very well
may have a remote antenna. Inside the dash could be a much worse
location than on top of the dash. I would bet the antenna is directly
under the plastic dash cover up as high as it can be in the center of
the window or it could be up on the top somewhere. Either way wouldn't
surprise me. Except for the Etrex and tiny units like that, I think all
the bigger Garmin units all have an external antenna jack.
I still think the TV ad is stupid. You can do the same thing with a sub
$100 hand held GPS or a 300 year old sextant (they did have sextants
back in 1706 didn't they?), a $5 watch and some charts.
Chris W
KE5GIX
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
One stop wish list for any gift,
from anywhere, for any occasion!
http://thewishzone.com
Commercial rating? Paul Tomblin Piloting 43 March 10th 06 12:19 AM
Commercial rating: Am I wrong here? gatt Piloting 12 November 21st 05 12:35 AM
NEW & UNOPENED: Gleim Commercial Pilot Knowledge Test (book AND Commercial Pilot Test Software) Cecil Chapman Products 2 November 13th 04 03:56 AM
What to study for commercial written exam? Dave Piloting 0 August 9th 04 03:56 PM
