Vector altitude for ILS below GS intercept altitude?
Old May 20th 06, 06:22 PM posted to rec.aviation.ifr
Default Vector altitude for ILS below GS intercept altitude?
Probably not relevant at TPL, but are controllers allowed (or
required?) to assign altitiudes to VFR aircraft in Class B?
(I'd always assumed "yes" without giving it much thought.)
I often get vectors for practice BJC ILS29R approaches while VFR.
The vectors take me into DEN Class B. I'm invariably given altitudes
as well as headings, which I appreciate as I'm trying to practice IFR
proceures.
Tim.
On Sat, 20 May 2006 00:00:23 GMT, "Steven P. McNicoll"
Have you ever asked them why they assign altitudes to VFR aircraft?
Old May 20th 06, 07:13 PM posted to rec.aviation.ifr
If you're in the Bravo airspace they WILL assign you an altitude or
expect that you keep the one you are on. I've been assigned "wrong way"
VFR altitudes while in the Bravo airspace to fit in with their plans.
Once you exit the Bravo you are expected to fly proper VFR altitudes for
your direction.
proceures.
Tim.
Old May 20th 06, 07:37 PM posted to rec.aviation.ifr
"Tim Auckland" wrote in message
proceures.
ATC can assign altitudes to VFR aircraft wherever separation is provided to
VFR aircraft; Class B airspace, Class C airspace and the associated outer
area, and TRSAs.
Old May 20th 06, 07:41 PM posted to rec.aviation.ifr
"Robert Chambers" wrote in message
. com...
If you're in the Bravo airspace they WILL assign you an altitude or expect
that you keep the one you are on. I've been assigned "wrong way" VFR
altitudes while in the Bravo airspace to fit in with their plans. Once you
exit the Bravo you are expected to fly proper VFR altitudes for your
direction.
Once you exit Class B airspace ATC is supposed to tell you to resume
altitudes appropriate for the direction of flight.
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 12:39 AM
GPS Altitude with WAAS Phil Verghese Piloting 38 October 5th 03 12:39 AM
