Highwing side-by-side aerobat?
Old May 20th 06, 11:44 PM posted to rec.aviation.homebuilt
Default Highwing side-by-side aerobat?
Is there a homebuilt design comparable to a Cessna 150 Aerobat? How
about a Wagabond - is it good for spins and simple aerobatics?
Old May 21st 06, 12:57 AM posted to rec.aviation.homebuilt
The Sorrell Hyperbipe is side by side, plus it is high wing AND low wing at
the same time!!!
Geoff
Old May 21st 06, 02:19 AM posted to rec.aviation.homebuilt
You can definitely build a Wagabond as a clip-wing. Even better, you could
put a clipped Taylorcraft wing on it, which would allow more speed and
better inverted flight.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 02:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
Side window install Jim Burns Owning 3 August 11th 05 03:59 PM
FS: Piper Side Window (New) JimC Aviation Marketplace 0 August 10th 03 12:19 PM
