I have landed because of mechanical failures maybe once every 300
hours. I had a vacuum pump fail (VMC, I'm happy to say), an alternator (In the clouds but soft IMC), a magnito failure that took out a bank of spark plugs (probably IFR, I don't remember for sure) -- things like that. Nothing really awful, but every one caused me to land a couple of hours short of my destination. Most of these happend in my own M20J which was (at least I think it was) well maintained. What about those of you with 500 plus hours: what has your experience been like? Am I just unlucky, or typical? |
I've only had 4 or 5 mechanicals in 2800 hours. Being VFR only, there
have been more more instances of not making it to my destination because of weather. -- Gene Seibel Hangar 131 - http://pad39a.com/gene/plane.html Because I fly, I envy no one. |
been like? Am I just unlucky, or typical? In my 1300+ hours, I have only encountered two situations, both were decisions to not take off. The first was a 182Q with the oil pressure gauge needle pegged full right following startup. The second was a Turbo Arrow IV with a bad mag found during runup. |
On a short cross-country in a C-150 I pulled the cabin heat on and loaded
the cockpit with gasoline fumes. I immediately closed the heater vent but the fumes didn't go away. Leaving a window opened at least brought in some fresh air. Made a precautionary landing about half-way to my destination. When I did the GUMP list I felt the carpet soaked with fuel. Turns out the fuel shut-off valve packing was dribbling gasoline into the cabin. When I opened the cabin heat vent, the air movement stirred up the fumes that were collecting below my knees. By the way, just to stir up a previous thread -- when I declared my intentions to make a precautionary landing (without declaring an emergency) the tower rolled the equipment. The only flak I caught was from the fire chief for taxiing the airplane off the runway to the apron. In hindsight, I probably should have stopped and ran -- like he said. |
I didn't actually land, but one time at the beginning of a long 6 hour
trek back home in a 172SP I did encounter an engine sputter. It was really just a momentary dip in RPM, but out of the ordinary enough for me to worry. I was climbing through maybe 2000 feet AGL when it happened, so I decided just for safety sake to continue the climb, but turned around direct back to the field. Checked the mixture, fuel selector, nothing seemed out of the ordinary, and RPMs didn't fluctuate at all again, so decided to return back to original enroute course. Trip ended without it happening again. -- Guy |
"Tony" wrote: I have landed because of mechanical failures maybe once every 300 hours. I had a vacuum pump fail (VMC, I'm happy to say), an alternator (In the clouds but soft IMC), a magnito failure that took out a bank of spark plugs (probably IFR, I don't remember for sure) -- things like that. Nothing really awful, but every one caused me to land a couple of hours short of my destination. Most of these happend in my own M20J which was (at least I think it was) well maintained. What about those of you with 500 plus hours: what has your experience been like? Am I just unlucky, or typical? Twice in 1100 hours: one failed voltage regulator in IMC, one engine vibration in VMC (prop put on wrong way round during annual). -- Dan C172RG at BFM |
You landed short of your destination because a vac pump failed in VMC??
-Robert |
Got 20 min away from the airport, heard something knocking, turned
around and went home. Decided that if I had to land someplace other than the airport, I'd rather be going towards the airport and following the interstate rather than continuing on, when I knew that my airport was considerably closer than the next one towards my destination. Mag cover had come loose and was rattling. Coming home from NM to Denver (night) following I-25. All of a sudden I couldn't see the lights of Denver (just south of COS with clear vis). Called COS and requested vectors, landed, borrowed the crew car and drove home (about an hour). Came back the next morning, dropped the crew car and flew home. Finished runup, got cleared for takeoff. Rolling down the runway, called the tower and stated I was cancelling takeoff. (You can do that real easy at an airport that doesn't have lots of traffic.) Serious shimmy on nose wheel, so much so that I felt that there would be a possible danger when landing later on. There have been numerous occasions when I decided I didn't like the weather, despite DUATS and FSS. About 90% of the time, I'm right. The other 10%? So what? 9-1 odds are really good! |
"Tony" wrote in message
oups.com... [...] What about those of you with 500 plus hours: what has your experience been like? Am I just unlucky, or typical? Probably similar. Like Robert, I wonder why you felt it necessary to make a precautionary landing when your vacuum pump failed in VMC. Were you flying under IFR? I was VFR the one vacuum pump failure I experienced, and I not only completed that flight, but made another one to take the airplane to the shop to have it repaired ("placarded" inop). As far as other mechanical problems/precautionary landings go... I did have a magneto failure. I didn't find out until my next flight. The only symptom was slightly higher fuel flow for the same power setting. So, no precautionary landing there, but there would have been had I any idea what was actually going on. My most dramatic (as in nerve-wracking) precautionary landing happened right after a takeoff. During my first turn in the pattern, I felt/heard an unusual noise combined with a slight drop in power. I immediately told the tower I needed to land and, while keeping an eye on the runway, nervously made my way around the pattern. Everything turned out okay, but it took awhile to figure out what was actually going on. In fact, it turned out to be two completely unrelated problems. The first, more serious, was a p-lead that was wearing against a corner, cutting through the insulation and shorting it out. That didn't get diagnosed for a few months, until it had worn enough to actually show up during the run-up. The other problem, that was actually causing the unusual noise I had noticed, only recently got resolved. After a few years of complaining about it, and having the airplane inspected thoroughly numerous times in search of any problems, my mechanics finally discovered two engine mounts that had been installed backwards. That had misaligned the engine just enough that, under just the right conditions, some additional engine vibration made it through the airframe, causing the noise I was feeling and hearing. I don't know whether those two problems really count as two events, since they only resulted in the one landing. I'm not even sure that either one on its own would have scared me enough to get me to land; for sure, the combination got my instant attention. There have been other mechanical issues that, thankfully, were caught during inspections of the airplane (mostly preflights) and which could have easily turned into unplanned landings. All told, I'd say that 300 hours per might be a *little* on the high side for *landings*, but it's a pretty good track record if you're counting ALL mechanical issues that might have forced a landing, whether you did make an early one or not. In either case, I doubt it's far from the average. You'd have to have a lot more mechanical problems than that to warrant being called "unlucky". Pete |
That is what the regs call for!
"Robert M. Gary" wrote in message oups.com... | You landed short of your destination because a vac pump failed in VMC?? | | -Robert | |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| NY Go Kart Endurance Racing - Arrive & Drive - No Experience Needed | OVRPNY | Owning | 1 | May 19th 05 05:56 PM |
| NY Go Kart Endurance Racing - Arrive & Drive - No Experience Needed | OVRPNY | Piloting | 0 | May 19th 05 03:01 AM |
| An eye opening experience... | Sam | Piloting | 4 | April 22nd 04 03:07 PM |
| I just bought X-Plane and want to share my experience | Bruce Shankle | Home Built | 2 | July 21st 03 06:48 PM |
