In a previous article, (Hankal) said:
why would you get clearence over the phone? I alway get my clearence on the ground with tower or in the air without a tower. What am I missing? You're missing the situation where you're at an untowered airport, and the ceilings are so low and the nearest atc too far away that you can't get your clearance in the air without penetrating the class E. So you phone FSS and get a clearance with a void time, climb up high enough to be heard, and tag up with atc. -- Paul Tomblin http://xcski.com/blogs/pt/ There are three kinds of people: Those who can count & those who can't. |
The best headset is the one that fits you best, you are comfortable
wearing, and has features (to ANR or not to ANR) you want. |
Hankal,
Do use the headset for this or the intercom From his description, he is using the headset. You'd need a splitter cable to supply the audio from the MP3-player to both audio-in plugs on two headsets. -- Thomas Borchert (EDDH) |
The MP3 plugs directly into the headset battery compartment as does the cell
phone. Kobra "Hankal" wrote in message ... I love them. I like to plug my Rio MP3 player in and have music for the flight. They can be set up so that on the pilot's side when ATC talks the music cuts out. Do use the headset for this or the intercom |
I am based at a non-controlled airport. There is another uncontrolled
airport about 8 airmiles from me with a RCO but I cannot reach it on the ground. My other choice is to warm up the plane, get all ready, then shut down run in and call clearence delivery on the land line. The last time I called on the cell with all the ambient engine noise, but the controller's first question was "are you ready to go?" No void time to worry about. He knew I was fired up and waiting. At a towered airport you can do that and I have. Hankal wrote: I keep looking at upgrading, but these seem to work just fine. One reason to upgrade is to get the model that will accommodate a cell phone for those clearance deliverie why would you get clearence over the phone? I alway get my clearence on the ground with tower or in the air without a tower. What am I missing? Hank |
ceilings are so low and the nearest atc too far away that you can't get your clearance in the air without penetrating the class E. So you phone If the weather is that bad I do not launch. I did not get my IFR ticket to kill myself |
ceilings are so low and the nearest atc too far away that you can't get your clearance in the air without penetrating the class E. So you phone If the weather is that bad I do not launch. I did not get my IFR ticket to kill myself At a non-towered airport with an instrument approach, Class E will start at 700 AGL, which is often not high enough to contact ATC. Once in Class E you have to stay 500' below the clouds. So you won't depart IFR with a 1200' ceiling? |
"Hankal" wrote: I did not get my IFR ticket to kill myself What *did* you get it for? -- Dan C172RG at BFM |
On Wed, 21 Jul 2004 20:45:58 -0400, "Barry" wrote:
You're missing the situation where you're at an untowered airport, and the ceilings are so low and the nearest atc too far away that you can't get your clearance in the air without penetrating the class E. So you phone If the weather is that bad I do not launch. I did not get my IFR ticket to kill myself This is SOP where I got my ticket and I regularly get clearances this way when I file as it is the only way to leave home base. There are procedures to protect the airspace for you and I don't think the odds of killing yourself increase by departing an uncontrolled airport with a clearance having a void time vs a controlled airport. z |
| alarm tone in headset | [email protected] | Home Built | 4 | January 28th 05 01:28 AM |
| WANTED! David Clark Headset | [email protected] | Home Built | 0 | December 29th 04 06:20 PM |
| Helicopter headset plug - help needed | NewsGroups | Home Built | 4 | September 8th 04 06:21 PM |
| Peltor Headset Experience | Mark T. Mueller | Instrument Flight Rules | 7 | June 6th 04 08:40 PM |
| HEADSET | Administrator | Home Built | 0 | October 27th 03 06:43 PM |
