Q about elevator balance
Old May 25th 06, 08:11 AM posted to rec.aviation.soaring
Default Q about elevator balance
I removed the elevator from the horizontal stab the other day for an
inspection of the pivot pins/bushes. The elevator has got a bunch of
weights attached to it, extending forward of the pivot location.
1. This is a humble question: does the elevator weight have a purpose
other than balance? Does it have any connection with flutter, or is
flutter more a function of excessive control mechanism backlash combined
with velocity?
2. For a serialized production glider, is the control surface balance
weight amount the same for each glider, or is it tuned for each
individual surface, making surfaces non-interchangeable between gliders?
I'm just trying to learn something on the topics of balance & flutter.
Ken
LAK-12
Old May 25th 06, 01:54 PM posted to rec.aviation.soaring
with velocity?
The weight is ALL about flutter. As a gross simplification, the
control surface CG acts like the aircraft CG, further aft de-stabilizes
the surface. The actual mechanisms are many and complicated.
There are control surface weight and moment limits set for each model,
these are in the repair manuals. When any repair work is done on a
control surface, the weight and moment must be checked to be within the
limits, or the aircraft is unsafe.
Todd Smith
3S
