A-6 crash after launch?
Old May 27th 06, 05:30 AM posted to rec.aviation.military.naval
Default A-6 crash after launch?
I was watching a documentary called "Top Gun" on the Military Channel.
They had some footage of some cat launches gone wrong. In one an A-6 took
off the waist catapult of a carrier and started losing altitude almost
immediately. Then something really big fell off the plane, it started to
roll, and the pilots ejected at very low altitude.
Any idea what happened there? I remember hearing about some aircraft launch
where the fuel in an external tank acted like a ram and caused some heavy
damage, but I'm not sure if these are the same events.
In another shot, a large prop plane, possibly an S-2F, took off the waist
catapult of a smaller Essex class carrier and immediately slammed into a
wave. Again, does anybody have any details?
D
Old May 27th 06, 05:41 AM posted to rec.aviation.military.naval
I saw the video of the plane punching through the wave while I was in
API. I got the impression that the video made the wave look more
catastrophic than in actually was. Don't think it caused any damage to
the aircraft just some super stunned pilots.
Old May 27th 06, 11:37 AM posted to rec.aviation.military.naval
If I am remembering right the A-6 got a cold cat and the pilot jettisoned
the centerline droptank trying to gain alt.
"spamno" wrote in message
news:MPQdg.127$xO5.54@trnddc03...
"DDAY" wrote in message
. net...
took
Without seeing it I can only speculate; cold cat? Wrong aircraft weight
dialed in? FODed a motor? Control problem?
As far as the "something really big fell off the plane" was that the
canopy?
Drop tanks? Turtleback?
That's why drop tanks are either completely full or completely empty. They
*should be* full on take off and the aircrew *always* checks fuel quantity
to be sure.
Old May 27th 06, 12:58 PM posted to rec.aviation.military.naval
. net...
Probably engine failure on the stroke. Possibly wrong weight setting on the
cat. The older catapults would use a given steam pressure to achieve a
particular end-speed for a particular gross weight. These would malfunction
on rare occasions. The newer cats use a rotary valve that allows full
pressure (600psi IIRC) for a particular duration and are just about fool
proof (unless its set for the wrong weight).
A fully-loaded A-6 didn't have very good single-engine fly away capability.
The "something" was probably all the underwing stores. Pilot pushed the
emergency jettison and the pylons were cleaned off.
launch
Pitching deck, poor cat shot timing, and heavy seas. The aircraft made it.
The aircrew needed fresh skivvies.
R / John
Old May 27th 06, 02:53 PM posted to rec.aviation.military.naval
took
the cat. The older catapults would use a given steam pressure to achieve
a particular end-speed for a particular gross weight. These would
malfunction on rare occasions. The newer cats use a rotary valve that
allows full pressure (600psi IIRC) for a particular duration and are just
about fool proof (unless its set for the wrong weight).
capability. The "something" was probably all the underwing stores. Pilot
pushed the emergency jettison and the pylons were cleaned off.
If it's the event I'm thinking of, I heard an interview from the pilot. I
don't remember the cause of the problem, but it was either insufficient cat
stroke, or more likely, an engine problem (because I don't remember him
blaming the cat/crew). After the shot, the pilot noticed that they weren't
going anywhere (not a good thing), and tried to hack it. Folks on deck were
screaming to eject. The drop tanks were punched off late, then the B/N
ejected, then the pilot ejected. The pilot hit the water at almost a 90
degree angle but made it. The B/N didn't. The pilot went on to transition
to the F-14 after that cruise (one of the A-6s last).
Old May 27th 06, 04:38 PM posted to rec.aviation.military.naval
"TV" wrote in message
took
to
achieve
just
Pilot
cat
weren't
were
transition
If it was one of the A-6s last cruises that would put it in the mid nineties
time frame. Any idea what boat?
Old May 27th 06, 05:10 PM posted to rec.aviation.military.naval
In article , "TV"
I'll have to rewatch it. I don't think it was in slow-motion, but the plane
goes off the deck slowly and then just seems to hang there. It's clear that
it's way below speed. Then, after an eternity, something long and thick
falls off the plane, which must have been a drop tank. The plane then
started a right bank and that's when they ejected, both hitting the water
before their chutes could fully deploy.
I got the sense from looking at it that the pilot waited too long, that he
was trying to keep the plane in the air despite a severe lack of speed. But
that's based upon my ignorant impression. I wasn't in the plane looking at
the gauges, and so maybe he thought that he could recover from the situation
and belatedly realized that he couldn't. It was scary to watch.
D
Old May 27th 06, 05:13 PM posted to rec.aviation.military.naval
In article , "John Carrier"
Yeah, I figured it was the stores, although I only saw one big thing falling
from one side of the plane.
The plane wasn't fully loaded, at least that much was evident. In fact, it
looked clean, which is why the big thing falling off was so odd.
D
Old May 27th 06, 07:06 PM posted to rec.aviation.military.naval
There were several incidents such as this during the A-6's long career, but I cannot find any that meet the criteria of (a) pilot survived, B/N didn't, and (b) late during the A-6's service life.
Morgan & Morgan's excellent book, INTRUDER: THE OPERATIONAL HISTORY OF GRUMMAN'S A-6, has an appendix of all operational A-6 losses. (There's a separate appendix for combat losses.) In that appendix there is only one instance of a carrier launch loss where the pilot survived and the B/N was lost:
BuNo 151825 / KA-6D, VA-75, 10/11/74, Mediterranean, off CV-60. Flaps/slats retracted on launch.
On the other hand there are several carrier launch losses where the fatality accrued to the left side of the cockpit. Within this group, only one occurred late in the Intruder's operational career:
BuNo 155708 / A-6E, VA-176, 01/19/91, Mediterranean, off CV-59. (No cause listed.)
With some more information, I can likely narrow things down or identify the actual event. With that, some other intrepid soul can fathom the depths of the Naval Safety Center records for the cause.
Mike Kanze
"The real accomplishment of 'The Da Vinci Code' is that Dan Brown has proven that the theory of conspiracy theories is totally elastic, it has no limits."
- Daniel Henninger, WALL STREET JOURNAL - 5/19/06
"spamno" wrote in message news:6o_dg.177$xO5.28@trnddc03...
took
to
achieve
just
Pilot
cat
weren't
were
transition
Old May 27th 06, 08:56 PM posted to rec.aviation.military.naval
Default A-6 crash after launch? OBTW
One of the peculiarities of the A-6 was its lack of a command ejection
system. There was some kind of reverse (perverse) logic in the community
that had sufficient following to keep it that way (IIRC) for the life of the
aircraft.
R / John
VQ-1's P4M-1Q crash off China - 1956 Mike Naval Aviation 0 May 6th 06 11:13 PM
Yet another A36 crash H.P. Piloting 10 April 23rd 05 05:58 PM
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
