IFR Flight Plan question
Old August 11th 04, 05:46 AM
Snowbird
Default IFR Flight Plan question
"Bob Gardner" wrote in message ...
Afterthoughts. If you had descended below radar coverage, the correct ATC
transmission would have been "Radar contact lost," not "Radar service
terminated," and you would have still been IFR. A controller cannot
unilaterally terminate your IFR status.
Bob, FWIW, we hear "radar service terminated" all the time whilst
on IFR flight plans, and we are still IFR. All it means (around here)
is that radar separation, traffic advisories, etc are no longer being
provided, and we must follow the non-radar provisions (make position
reports etc). "Radar contact lost" to me might mean he's not picking
up my transponder at the moment, but expects to see other traffic at
my altitude or to pick me up again shortly ie I can still expect some
radar services. Again, FWIW.
From reading the original post, my guess is that there was an ambiguous
situation because the pilot filed an IFR flight plan to one destination,
then continued doing approaches at other airports. If he didn't ask to
amend his flight plan to a different destination or file a new IFR flight
plan, the controller may have been treating the continuation of his
flight to other airports as VFR.
A good caution to us all to clarify our status when there's reason to
believe it might be unclear.
Cheers,
Sydney
Old August 11th 04, 08:24 AM
Max T, CFI
There are two different approach control sectors that border on LVK. From the
SCK area, you undoubtedly were on 123.85. If you wanted to fly the missed approach
at LVK and told them that before they handed you off to the tower, they would
have coordinated with the sector that would handle you on the missed (I think it's
135.4 or 134.5--can't remember as both freqs are used here in the Bay area).
I tried to do just that with a student this morning as we came from SCK to LVK.
The controller on 123.85 said he was unable to get the next controller to accept us
for the missed, so we would have to land at LVK, and pick up a new clearance on the ground.
We were in the same position as you--we had filed to SCK, and not any further.
Max T, CFI
Ron Garrison wrote in message ...
Yesterday during a practice flight with a CFII something unexpected
happened, and after reviewing the FARs and the AIM I still haven't been able
to figure it out. At the time I was IFR rated and current, but my currency
was about to expire.
The plan for the flight was to fly from Hayward, CA (HWD) out to Stockton
(SCK), Tracy (TCY) and Livermore (LVK) and then back to HWD for some
practice approaches. The forecast for the duration of the flight (based on
the OAK and SCK TAF) was for HWD to be 1000' OVC and all of the other
airports to be 10 miles and clear, and the forecast turned out to be
accurate. I filed IFR from HWD to SCK, with no alternate and a notation in
the remarks section that I wanted multiple approaches. After flying 3
approaches into SCK, I requested an approach into TCY, including the full
published missed procedure including a hold. Following the hold I requested
an approach into LVK. As I was handed off to the LVK tower NORCAL approach
informed me that radar services were terminated, which I assumed was because
I was dropping below radar coverage. After reaching the MAP at LVK, the
tower instructed me to squawk VFR. After leaving the LVK Class D, I
requested a pop-up clearance back into HWD.
Now for the question. At what point during this flight did I cease to be
operating under an IFR flight plan? I had assumed that since I had not
requested to cancel IFR at any point that I was still on an IFR flight plan
the entire time. This is certainly what I would expect if, for example, all
of the airports in question were below VFR minimums and the approaches had
been "real" missed approaches, in other words I had gotten down to the DH or
MDA, had not met the requirements to descend lower and elected to divert to
an alternate.
Ron Garrison
Old August 11th 04, 01:04 PM
Barry
plan the entire time.
Per the Pilot/Controller Glossary, as soon as you shot the approach
at Stockton. If I read your post correctly, SCK was your clearance limit.
It seems to me that it depends on whether or not he landed at Stockton, not
just did an approach. The AIM 5-1-13 says:
e. If operating on an IFR flight plan to an airport with a functioning control
tower, the flight plan is automatically closed upon landing.
There must be something about this in the 7110.65, but I can't find it.
Old August 11th 04, 06:13 PM
Ron Garrison
"Max T, CFI" wrote in message
news:JYiSc.106867$8_6.104469@attbi_s04...
missed approach
would
think it's
area).
LVK.
accept us
further.
Max T, CFI
That clarifies a lot of things. For the first 4 approaches, I had been
talking to approach on 123.85, and informed them prior to getting handed off
to the tower that I intended to go missed. At LVK I forgot to tell them
that. It still raises a question though with regard to Bob Gardners' comment
earlier about SCK being my clearance limit. If I have the time and fuel and
ATC says things aren't to busy, I will occasionally take an approach in IMC
down to minimums, fly the missed and then go back for a second approach to a
full landing. For example, at MRY with a 500' ceiling, fly the NDB approach,
not find the runway, go back and land using the ILS. Suppose that had been
the case at SCK, but the weather had deteriorated so much below the forecast
that I really couldn't land. I wouldn't have known that until after I was
handed off to the tower and thus approach would not be expecting a missed
approach. It sounds like the flight plan status depends on the approach
controllers perception of the weather at an airport, which is unnerving to
say the least.
Ron Garrison
Old August 11th 04, 10:26 PM
Julian Scarfe
I was wrong, because I didn't take time to really read your post. Per the
Pilot/Controller Glassary, as soon as you shot the approach at Stockton.
If
"I filed IFR from HWD to SCK, with no alternate and a notation in the
remarks section that I wanted multiple approaches"
After flying 3
full
Wouldn't you regard the acceptance of his request as an amendment to the
clearance? Perhaps it depends on the phraseology used.
Julian Scarfe
Old August 13th 04, 01:55 AM
Matt Young
Never been told "round robin" by controller before, but my instructor
and I have filed for such a trip. FSM (Fort Smith, AR) in both
departure and destination, route including the airports we intend to do
approaches at - ie FSM V13 RZC XNA (NW AR Regional Airport) RZC H34
(Huntsville, AR) WESTY FSM
Then for comments we put approach at XNA, H34, FSM
Fort Smith clearance delivery happily tells us
"Skyhawk 669RA is cleared to Fort Smith airport as filed..."
John Clonts wrote:
"SFM" wrote in message
I am not so sure he was still on his flight plan. Since he only filed to
SCK
once he left there they probably closed his IFR Flight plan and had him on
a
VFR one. When he requested the change to leave SCK and go to TCY he should
have used the phrase "I would like to ammend my flight plan to go to TCY".
It is a confusing situation that the pilot created what would have been
best solution would have been to file all the flight plans, upon finishing
up at each ariport pick up his new clearence to the next stop. Thsi is
what
ATC likes us to do in the midwest.
I was in Austin Saturday and called clearance delivery and requested a local
IFR clearance to do some approaches at some surrounding airports. They said
"will you be returning to Austin?". I said yes. They said "N7NZ cleared to
Austin via round-robin, climb and maintain 3000, departure freq
x.xx....etc".
I had heard of that before but this was the first I'd actually heard it
literally, from ATC.
Cheers,
John Clonts
Temple, Texas
N7NZ
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Aerobatics 28 January 2nd 09 03:26 PM
NAS and associated computer system Newps Instrument Flight Rules 8 August 12th 04 06:12 AM
Canadian IFR/VFR Flight Plan gwengler Instrument Flight Rules 4 August 11th 04 04:55 AM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 06:54 PM
IFR flight plan filing question Tune2828 Instrument Flight Rules 2 July 23rd 03 04:33 AM
