Airbus to Expand Cockpit Automation
Old May 29th 06, 01:47 AM posted to rec.aviation.piloting
Default Airbus to Expand Cockpit Automation
"Thomas Borchert" wrote in message
Bob,
Anyone who can't see the potential problems with this should be required
to understand the many times automation is discussed in comp.risks.
And anyone who can't see the potential benefits should be required to read
the Ueberlingen accident investigation.
So who's more right?
The first poster.
Ueberlingen is a case where the Russian crew ignored the ACAS and in
following ATC instructions did exactly the opposite of the ACAS guidance.
If it were automated, the crew would have likely disconnected the A/P to
follow the ATC instructions. You also should recognize that if the Russian
crew had done nothing, they would have been safe (assuming the DHL crew
followed their guidance.)
ACAS exists to provide a last line of defense if ATC fails to provide safe
separation. Following ATC instructions against the advice of an ACAS alert
defeats the purpose of the system. That's the reason for the wording in 14
CFR Part 91.123. If safe separation is maintained, there won't be an ACAS
alert. The current system works well.
If you were to automate it, the benefits are marginal; a bit quicker
response, a bit more accurate flying of the maneuver. But normal pilot
reactions and performance is included in the design. OTOH, the ACAS is a
complex system. When there are faults, it can result in erroneous alerts.
Responding to these alerts may be more dangerous than doing nothing. In the
real world, when these occur, they are usually fairly obvious to a crew, so
they crew ignores it and writes it up for maintenance. Add flight controls
into the system and you just added a huge level of complexity and more
opportunities for bad results.
Gerry
  #32
Old May 29th 06, 10:51 AM posted to rec.aviation.piloting
Bob,
what's your point?
Are you familiar with the Ueberlingen case? Automation of the proposed
kind could have prevented it.
Thomas Borchert (EDDH)
  #33
Old May 29th 06, 01:55 PM posted to rec.aviation.piloting
"Skywise" wrote in message
"Matt Barrow" wrote in
"Matt Barrow" wrote in news:6v5eg.75$Q73.9093
@news.uswest.net:
"FLAV8R" wrote in
Wow! I feel like I'm reading some sort of SciFi horror story where
man (and
woman) are replaced by computers and man is doomed to be
eradicated. What next?! Cars that drive themselves? Oh wait!
Mercedes has already been
working on that one.
And my company is working to remove all its workforce and what it
can't remove it outsources to India.
David
You are obsolete! (from a Twilight Zone episode)
Better yet, "To Serve Man".
mmMMMMMmmmm....soilent green.
One man, sautéed in olive oil...
No MSG!!!!
Brian
Don't need it if man is fresh, not frozen!
Light or dark meat?
Red...and it tastes like chicken.
  #34
Old May 31st 06, 09:10 PM posted to rec.aviation.piloting
John wrote:
European jet maker Airbus is taking an unprecedented step to expand
cockpit automation: onboard computers that will automatically maneuver
jetliners to avoid midair collisions, without any pilot input.
Known for its pioneering use of computers and software to push the
automation envelope, this time Airbus has decided to cross a new
threshold in replacing pilot decisions with computer commands. For the
first time, flight crews of Airbus planes will be instructed and trained
to rely on autopilots in most cases to escape an impending crash with
another airborne aircraft. Currently, all commercial pilots are required
to instantly disconnect the autopilot when they get an alert of such an
emergency, and manually put their plane into a climb or descent to avoid
the other aircraft.
http://online.wsj.com/public/article... main_tff_top
or http://tinyurl.com/lnlky
Yep, evolution:
Scarebus
Scarierbus
Scariestbus
Whats the difference between an A320 and a chainsaw? About 100 trees
a minute. (see the A320 autoland video if you don't get it)
  #35
Old May 31st 06, 11:43 PM posted to rec.aviation.piloting
Or:
What's the difference between a Cri-Cri and an A320?
One's an airplane with lawnmower engines, the other a lawnmower with
airplane engines.
  #36
Old June 2nd 06, 03:29 AM posted to rec.aviation.piloting
"John" wrote in message
Bus wanted to do the same with TAWS. Fortunately, us stupid peelots know
just enough to figure out which circuit creakers to pull and reset to fix
their pioneering computers and software.
D. (likes Boeing more every flight)
  #37
Old June 3rd 06, 02:09 AM posted to rec.aviation.piloting
In article
I am still awaiting an explaination as to the propper procedure to
follow when the autopilot initiates an evasive manuever, immediatly
followed by the AirBus blue screen of death when the computers decide
it's time to recycle.
Information on A310 that lost it's rudder enroute to Canada from Cuba Corky Scott Piloting 3 March 27th 05 03:49 PM
Australia chooses Airbus tankers John Cook Military Aviation 0 April 16th 04 10:25 AM
Airbus 15 minutes of fame over? Buzzer Military Aviation 5 January 20th 04 04:42 AM
Airbus Charts Course for Military Contracts Otis Willie Military Aviation 0 November 24th 03 11:04 PM
Airbus Aiming at U.S. Military Market Otis Willie Military Aviation 0 September 21st 03 08:55 PM
