Legality of a flight
Old May 30th 06, 05:51 PM posted to rec.aviation.piloting
Default Legality of a flight
All true, but there is no specific "Angel Flight" exemption.
Sorry, didn't mean to imply that there was a special exemption. Angel
Flight is specially recognized by the FAA. If you tried to start the
same organization today the FAA would require a 135 certificate since
it fails the "common cause" test for 135 operation. The FAA has
threatened to shut down Angel Flight in the past but they do a good job
of showing successful missions on "Good Morning America" and the like.
The FAA chooses to ignore Angel Flight.
Our flights are purely part91 flights with no "compensation" going to
either the pilot or the organization in return for the flight (neither
the patient nor the hospital is ever billed a dime).
True, it passes the compensation test but if failes the "common cause"
test. Anytime you publicly offer to transport someone from one place to
another that you would not have otherwise gone it, its generally
considered part 135. AOPA has a good publication on the several tests
the FAA uses to determine part 135.
-Robert
Old May 30th 06, 08:35 PM posted to rec.aviation.piloting
"Robert M. Gary" wrote in
ups.com:
-Robert
The FAA does not "ignore" Angel Flight. There is a specific order in the
Air Transportation Inspector's handbook (FAA Order 8400.10) addressing the
status of Angel Flight and similar organizations regarding this issue.
The Air Care Alliance web site has a copy of FAA Order 8400.10, Vol. 4,
Chap. 5, Section 1, Para 1345 (http://www.aircarall.org/tax.htm) which
specifically tells inspectors that they should NOT treat the tax
decuctiblity of Angel Flight or similar groups (referred to as "life
flights") as "compensation for hire" for the purposes of enforcement of FAR
61.118 or FAR part 135.
The following have been copied from the above referenced web site.
The April 23, 1993 letter from the FAA Acting Chief COunsel to the Air Care
Alliance and Angel Flight of Texas:
Apr 23, 1993
"As a matter of policy, taking into consideration the fact that Congress
has specifically provided for the tax deductibility of some costs of
charitable acts, we will not treat charitable deduction of such costs,
standing alone, as constituting "compensation or hire" for the purpose of
enforcing [Paragraph] 61.118 or Part 135. If taking a charitable tax
deduction for transporting persons or property is coupled with any
reimbursement of expenses, or other compensation of any kind, then this
policy does not apply."
[Signed] John H. Cassady FAA Acting Chief Counsel
FAA Order 8400.10, Vol. 4, Chap. 5, Sect. 1, Para 1345 12/20/94
1345. FAA POLICY REGARDING "COMPENSATION OR HIRE" CONSIDERATIONS
FOR CHARITABLE FLIGHTS OR LIFE FLIGHTS. Various organizations and pilots
are conducting flights that are characterized as "volunteer," "charity," or
"humanitarian." These flights are referred to by numerous generic names,
including "lifeline flights," "life flights," "mercy flights," and "angel
flights." These types of flights will be referred to as "life flights" in
this section.
A. Purposes for Life Flights. The types of organizations and pilots
involved with or conducting life flights vary greatly. The most common
purpose of life flights is to transport ill or injured persons who cannot
financially afford commercial transport to appropriate medical treatment
facilities, or to transport blood or human organs. Other "compassionate
flights" include transporting a child to visit with a dying relative, or
transporting a dying patient to return to the city of the patient's birth.
B. FAA Policy. The FAA's policy supports "truly humanitarian efforts" to
provide life flights to needy persons (including "compassionate flights").
This also includes flights involving the transfer of blood and human
organs. Since Congress has specifically provided for the tax deductibility
of some costs of charitable acts, the FAA will not treat charitable
deductions of such costs, standing alone, as constituting "compensation or
hire" for the purpose of enforcement of FAR 61.118 or FAR Part 135.
Inspectors should not treat the tax deductibility of costs as constituting
"compensation or hire" when the flights are conducted for humanitarian
purposes.
Marty Shapiro
Silicon Rallye Inc.
(remove SPAMNOT to email me)
Old May 30th 06, 10:15 PM posted to rec.aviation.piloting
"Mike Schumann" wrote in message
news:9jPeg.9452
The way I read the FARs, the private pilot needs to have 200 hours unless
he has a commercial rating. In addition, you need to go thru the AOPA
waver to avoid having to take the drug test.
Can somebody elaborate on this? I'm looking at the form right now, and it
says:
"Under FAA Exemption No. 7112D, the event sponsor must provide the AOPA
member-pilot with a statement indicating that neither the event sponsor nor
any participating pilot operating under this exemption has operated more
than four similar events during the calendar year."
So, if I read this correctly, IF YOU'RE AN AOPA member, you can fill out the
form and be exempted so long as the charity organization doesn't conduct
these sorts of flights more than four times a year. I presume that the
AOPA has some arrangement with the FAA that it extends to its members, and
that the four-event maximum is to prevent bogus "charity" airlines.
Am I correct and, if so, WTH does drug testing have to do with any of it?
-c
Old May 30th 06, 10:58 PM posted to rec.aviation.piloting
You posted some stuff regarding tax deduction and the FAAs decision
that that is not "compensation". However, the FAA chooses to ignore the
fact that Angel Flight would normally be considered part 135 because
there is no common purpose of flight. When I was serving as the area
Angel Flight check pilot instructor it was made clear to us that we
were on non-solid ground and unsafe flight could easily get the entire
organization shut down.
-Robert
Old May 31st 06, 12:22 AM posted to rec.aviation.piloting
ups.com:
-Robert
The FAA Order not only exempted Angel Flight pilots from FAR 61.118 (now
61.113), but also from FAR 135. This was not an issue when I received my
Angel Flight checkout and orientation.
Marty Shapiro
Silicon Rallye Inc.
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 06:31 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
