Spotting Traffic
Old May 3rd 06, 07:25 PM posted to rec.aviation.piloting
Default Spotting Traffic
"john smith" wrote in message
How often do you spot traffic without guidance from ATC when you are out
flying"
Every flight.
How often do you spot traffic called out to you by ATC?
About the same. I suspect that means I don't see half of what's out there.
As long as it's the half that's aft of my CG and they see me, I guess it's
not a problem. :
-c
  #32
Old May 31st 06, 05:08 PM posted to rec.aviation.piloting
flying"
It does happen but not even 50% of the time. Yesterday I saw one
below me and 1-2 miles away before ATC told me about him. That is not
the norm.
Maybe 50-75% of the time. Just this morning there was an aircraft on
final to a parallel runway ( I was behind him) but I never saw him
until he was airborne after his T&G.
Ron Lee
  #33
Old May 31st 06, 07:37 PM posted to rec.aviation.piloting
On Tue, 02 May 2006 08:17:26 -0400, Peter R. wrote:
Ron Lee wrote:
That assumes that this system will be around a while. Seems like it or
something like it is not long for this world so buying equipment to use
it may not be worth it.
The authors of _Aviation Consumer_ seem to disagree but no matter; I don't
really expect Paul to take my suggestion seriously anyway.
Where did AC write that TIS will be around for a while? It seems like the
Next Big Thing for traffic is ADS-B.
We're bouncing this around for our club aircraft now. TIS has wider
coverage today, but we're concerned about its longevity.
If we'd a failed transponder, the incremental cost for a mode S
transponder would be small enough that we'd do it. But to throw out a
perfectly good mode C transponder for something that will be replaced in a
relatively short time seems inefficient.
- Andrew
  #34
Old May 31st 06, 08:31 PM posted to rec.aviation.piloting
The article was titled, "Airborne Traffic Alerting: TIS Still the One to
Beat," and a sidebar titled, "Why TIS is Still a Good Bet." These articles
were in the November 2005 (volume 35, Number 11) issue of _Aviation
Consumer_.
Send me a working email address for a return gift in the form of some
random words that, if viewed under certain lighting conditions,
approximately resemble these articles, if you are interested.
pjricc @ gmail . com
Peter
  #35
Old June 1st 06, 04:18 PM posted to rec.aviation.piloting
articles were in the November 2005 (volume 35, Number 11) issue of
_Aviation Consumer_.
Thanks. I found it:
http://www.aviationconsumer.com/issu...rt/5496-1.html
First, this mentions that ADS-B is far from deployment. But that's not
quite true, at least around here. We're located in northern NJ, which is
right at the northernmost tip of ADS-B deployment on the East Coast. So
we'd see *some* benefit from ADS-B pretty quickly.
However, there are other interesting points. There's a paragraph which
suggests, for example, that some TIS units will be "field upgradable" to
"be useable in the ADS-B traffic world". What might that mean?
The sidebar at:
http://www.aviationconsumer.com/news.../35-11-Why.pdf
discusses my concern regarding TIS: that it is a short-term solution to be
replaced by ADS-B. However, a check of:
http://www.aviationconsumer.com/news.../35-8-Mode.pdf
shows that none of the 23 airports to lose TIS in the short term are in my
immediate neighborhood (though some are w/in just a few hours flight).
Hmm.
- Andrew
  #36
Old June 1st 06, 08:07 PM posted to rec.aviation.piloting
snip
Hmm.
As someone who flies a lot in the Northeast and mid-Atlantic US, I am very
happy with what TIS is currently providing me.
Peter
  #37
Old June 1st 06, 09:48 PM posted to rec.aviation.piloting
That's not really in question. The issue is whether or not it is a good
investment given a working mode C transponder.
[If I had to replace a transponder, this would be easier grin.]
- Andrew
  #38
Old June 5th 06, 06:00 PM posted to rec.aviation.piloting
Yes, I realized after I sent up the post that you were more interested in
the future of TIS, rather than the present. Sorry 'bout that.
Peter
  #39
Old June 5th 06, 09:30 PM posted to rec.aviation.piloting
No worries. I (1) wanted to be clear that we're not in disagreement, and
(2) am still hoping for more insight into this.
It's not just about the future of TIS, though of course that is a factor.
But it is also a matter of the value of the investment in TIS even given a
limited lifespan.
I could reason, for example: one midair can ruin your whole day. Since
coverage for TIS is better *today* than ADS-B's TIS-B, and will remain so
for at least a while, a few thousand dollars is worth investing in this
dead end technology.
On the other hand, there's the "we've gotten along with those fancy gizmos
for years" reasoning.
On yet a third hand: Not everyone has "gotten along", as NTSB reports
clearly show.
Still, how far can one take that reasoning before flying itself becomes
and unacceptable risk?
- Andrew
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
