Okay, one of the club's planes has an autopilot installled, that I have
never been able to make operate. Get up to level cruise, turn it on and wait. All I get is a blinking 'TRIM UP' light, never get the 'READY' light. Is it hosed, or am I missing a step? -- Hello, my name is Mike, and I am an airplane addict... |
![]() "Michael Ware" wrote: Okay, one of the club's planes has an autopilot installled, that I have never been able to make operate. Get up to level cruise, turn it on and wait. All I get is a blinking 'TRIM UP' light, never get the 'READY' light. Is it hosed, or am I missing a step? Switch it to "Test" first. It will do its test sequence, ending with a bunch of lights on, including the "Trim Up" light, IIRC. Then, switch it to "On." The green "Rdy" light will illuminate. If you now press the "On" button, the "Push Hdg/Sts"activates in wing leveler mode. Press the "Push Hdg/Sts" button and the autopilot will steer to the course set on the heading bug. Once the bank axis is active, the altitude hold function is available. -- Dan C172RG at BFM |
"Dan Luke" wrote: "Michael Ware" wrote: Okay, one of the club's planes has an autopilot installled, that I have never been able to make operate. Get up to level cruise, turn it on and wait. All I get is a blinking 'TRIM UP' light, never get the 'READY' light. Is it hosed, or am I missing a step? Switch it to "Test" first. It will do its test sequence, ending with a bunch of lights on, including the "Trim Up" light, IIRC. Then, switch it to "On." The green "Rdy" light will illuminate. If you now press the "On" button, the "Push Hdg/Sts"activates in wing leveler mode. Press the "Push Hdg/Sts" button and the autopilot will steer to the course set on the heading bug. Once the bank axis is active, the altitude hold function is available. There is a delay of one or two minutes before the altitude hold will engage. Be patient. |
![]() "Dan Luke" wrote in message ... "Michael Ware" wrote: Okay, one of the club's planes has an autopilot installled, that I have never been able to make operate. Get up to level cruise, turn it on and wait. All I get is a blinking 'TRIM UP' light, never get the 'READY' light. Is it hosed, or am I missing a step? Switch it to "Test" first. It will do its test sequence, ending with a bunch of lights on, including the "Trim Up" light, IIRC. Then, switch it to "On." The green "Rdy" light will illuminate. If you now press the "On" button, the "Push Hdg/Sts"activates in wing leveler mode. Press the "Push Hdg/Sts" button and the autopilot will steer to the course set on the heading bug. Once the bank axis is active, the altitude hold function is available. -- Dan C172RG at BFM Thanks, Dan. I love the 296, BTW. Very useful. |
![]() "john smith" wrote in message ... In article , "Dan Luke" wrote: "Michael Ware" wrote: Okay, one of the club's planes has an autopilot installled, that I have never been able to make operate. Get up to level cruise, turn it on and wait. All I get is a blinking 'TRIM UP' light, never get the 'READY' light. Is it hosed, or am I missing a step? Switch it to "Test" first. It will do its test sequence, ending with a bunch of lights on, including the "Trim Up" light, IIRC. Then, switch it to "On." The green "Rdy" light will illuminate. If you now press the "On" button, the "Push Hdg/Sts"activates in wing leveler mode. Press the "Push Hdg/Sts" button and the autopilot will steer to the course set on the heading bug. Once the bank axis is active, the altitude hold function is available. There is a delay of one or two minutes before the altitude hold will engage. Be patient. OK thanks guys. Had it out visiting relatives last weekend. Not much fun openening/folding sectionals with one hand. Mike |
On Fri, 02 Jun 2006 23:33:40 GMT, "Michael Ware"
wrote: Okay, one of the club's planes has an autopilot installled, that I have never been able to make operate. Get up to level cruise, turn it on and wait. All I get is a blinking 'TRIM UP' light, never get the 'READY' light. Is it hosed, or am I missing a step? The a/c should have an AFM supplement explaining how to test the a/p during PREFLIGHT. If you cannot locate it, you can always download the POH from http://www.s-tec.com/pdf/sys4050poh.PDF Once you have read the manual, and gone through the pre-flight test procedure, you should be able to figure out whether the problem lies in the autopilot, or the operator. Under normal circumstances, the 'READY' light should have been on prior to takeoff. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
On Fri, 2 Jun 2006 19:12:29 -0500, "Dan Luke"
wrote: "Michael Ware" wrote: Okay, one of the club's planes has an autopilot installled, that I have never been able to make operate. Get up to level cruise, turn it on and wait. All I get is a blinking 'TRIM UP' light, never get the 'READY' light. Is it hosed, or am I missing a step? Switch it to "Test" first. It will do its test sequence, ending with a bunch of lights on, including the "Trim Up" light, IIRC. Then, switch it to "On." The green "Rdy" light will illuminate. If you now press the "On" button, the "Push Hdg/Sts"activates in wing leveler mode. Press the "Push Hdg/Sts" button and the autopilot will steer to the course set on the heading bug. Once the bank axis is active, the altitude hold function is available. Mine must be broke. I can turn on alt hold with out the heading being active. It doesn't care which sequence I use other than it takes a minute or so before the altitude hold works after turning the AP on. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() "Roger" wrote: Once the bank axis is active, the altitude hold function is available. Mine must be broke. I can turn on alt hold with out the heading being active. It doesn't care which sequence I use other than it takes a minute or so before the altitude hold works after turning the AP on. When you press the "On/Off" button, the roll axis is active (you can control the turn rate by twisting the knob). The altitude hold function is then available. -- Dan C172RG at BFM |
Michael,
the manual is available for download at S-TEC's site. There are two on switches on this autopilot. One is on the control unit itself, it activates basic operation in wing leveller mode, indicated by "STB" for STABILIZE. However, there should be a 3-position AP master switch somewhere on the panel. That switch has OFF/ON/TEST as positions. You need to put it through test mode first, preferably on the ground. After testing, leave that switch in ON (with the ready light on), otherwise you'll have to do the test again. The test includes engagement of the clutches, which can be irritating when done in flight. -- Thomas Borchert (EDDH) |
Roger,
I can turn on alt hold with out the heading being active. That's by design. If HDG mode is off, but you have the autopilot switched on, STB will be showing in the display, which stands for STABILIZE, otherwise known as wing leveling. Of course, you can hold ALT in that mode. -- Thomas Borchert (EDDH) |
