#31
![]() "john smith" wrote in message How often do you spot traffic without guidance from ATC when you are out flying" Every flight. How often do you spot traffic called out to you by ATC? About the same. I suspect that means I don't see half of what's out there. As long as it's the half that's aft of my CG and they see me, I guess it's not a problem. : -c |
#32
john smith wrote:
How often do you spot traffic without guidance from ATC when you are out flying" It does happen but not even 50% of the time. Yesterday I saw one below me and 1-2 miles away before ATC told me about him. That is not the norm. How often do you spot traffic called out to you by ATC? Maybe 50-75% of the time. Just this morning there was an aircraft on final to a parallel runway ( I was behind him) but I never saw him until he was airborne after his T&G. Ron Lee |
#33
On Tue, 02 May 2006 08:17:26 -0400, Peter R. wrote:
Ron Lee wrote: That assumes that this system will be around a while. Seems like it or something like it is not long for this world so buying equipment to use it may not be worth it. The authors of _Aviation Consumer_ seem to disagree but no matter; I don't really expect Paul to take my suggestion seriously anyway. Where did AC write that TIS will be around for a while? It seems like the Next Big Thing for traffic is ADS-B. We're bouncing this around for our club aircraft now. TIS has wider coverage today, but we're concerned about its longevity. If we'd a failed transponder, the incremental cost for a mode S transponder would be small enough that we'd do it. But to throw out a perfectly good mode C transponder for something that will be replaced in a relatively short time seems inefficient. - Andrew |
#34
Andrew Gideon wrote:
Where did AC write that TIS will be around for a while? It seems like the Next Big Thing for traffic is ADS-B. The article was titled, "Airborne Traffic Alerting: TIS Still the One to Beat," and a sidebar titled, "Why TIS is Still a Good Bet." These articles were in the November 2005 (volume 35, Number 11) issue of _Aviation Consumer_. Send me a working email address for a return gift in the form of some random words that, if viewed under certain lighting conditions, approximately resemble these articles, if you are interested. pjricc @ gmail . com -- Peter |
#35
On Wed, 31 May 2006 15:31:36 -0400, Peter R. wrote:
The article was titled, "Airborne Traffic Alerting: TIS Still the One to Beat," and a sidebar titled, "Why TIS is Still a Good Bet." These articles were in the November 2005 (volume 35, Number 11) issue of _Aviation Consumer_. Thanks. I found it: http://www.aviationconsumer.com/issu...rt/5496-1.html First, this mentions that ADS-B is far from deployment. But that's not quite true, at least around here. We're located in northern NJ, which is right at the northernmost tip of ADS-B deployment on the East Coast. So we'd see *some* benefit from ADS-B pretty quickly. However, there are other interesting points. There's a paragraph which suggests, for example, that some TIS units will be "field upgradable" to "be useable in the ADS-B traffic world". What might that mean? The sidebar at: http://www.aviationconsumer.com/news.../35-11-Why.pdf discusses my concern regarding TIS: that it is a short-term solution to be replaced by ADS-B. However, a check of: http://www.aviationconsumer.com/news.../35-8-Mode.pdf shows that none of the 23 airports to lose TIS in the short term are in my immediate neighborhood (though some are w/in just a few hours flight). Hmm. - Andrew |
#36
snip discusses my concern regarding TIS: that it is a short-term solution to be replaced by ADS-B. However, a check of: http://www.aviationconsumer.com/news.../35-8-Mode.pdf shows that none of the 23 airports to lose TIS in the short term are in my immediate neighborhood (though some are w/in just a few hours flight). Hmm. As someone who flies a lot in the Northeast and mid-Atlantic US, I am very happy with what TIS is currently providing me. -- Peter |
#37
On Thu, 01 Jun 2006 15:07:37 -0400, Peter R. wrote:
As someone who flies a lot in the Northeast and mid-Atlantic US, I am very happy with what TIS is currently providing me. That's not really in question. The issue is whether or not it is a good investment given a working mode C transponder. [If I had to replace a transponder, this would be easier grin.] - Andrew |
#38
That's not really in question. The issue is whether or not it is a good investment given a working mode C transponder. Yes, I realized after I sent up the post that you were more interested in the future of TIS, rather than the present. Sorry 'bout that. -- Peter |
#39
On Mon, 05 Jun 2006 13:00:25 -0400, Peter R. wrote:
Andrew Gideon wrote: That's not really in question. The issue is whether or not it is a good investment given a working mode C transponder. Yes, I realized after I sent up the post that you were more interested in the future of TIS, rather than the present. Sorry 'bout that. No worries. I (1) wanted to be clear that we're not in disagreement, and (2) am still hoping for more insight into this. It's not just about the future of TIS, though of course that is a factor. But it is also a matter of the value of the investment in TIS even given a limited lifespan. I could reason, for example: one midair can ruin your whole day. Since coverage for TIS is better *today* than ADS-B's TIS-B, and will remain so for at least a while, a few thousand dollars is worth investing in this dead end technology. On the other hand, there's the "we've gotten along with those fancy gizmos for years" reasoning. On yet a third hand: Not everyone has "gotten along", as NTSB reports clearly show. Still, how far can one take that reasoning before flying itself becomes and unacceptable risk? - Andrew |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
