VOR/DME Approach Question
Old August 26th 04, 07:35 PM
Ron Rosenfeld
On Thu, 26 Aug 2004 14:10:56 GMT, "Chip Jones"
Ron, that sounds basically good to me. I would "chunk" that information so
it didn't all go out in the same transmission. My stab at it:
"Fly heading 270 to intecept the HCH060R, direct MINES when able."
Followed by:
"Maintain 5000 until MINES, cleared VOR/DME approach Rockwood, report
procedure turn inbound."
With the PT language there is no doubt that I didn't vector to final.
Yes, it's probably more difficult for the pilot to screw things up when you
"chunk" it.
And when he got to MINES, absent a further clearance (radio congestion or
whatever) there'd be no question that he should go into the hold, until
cleared for the approach.
--ron
  #42
Old August 27th 04, 12:10 AM
J Haggerty
I didn't find any written authority that directly authorizes this. It
would be more a compilation of bits and pieces from several regulations.
Unfortunately, there's not much out there in the books that relates
directly to GPS overlay procedures.
Example; FAAH 7110.65 Para 4-8-1 b. "For aircraft operating on
unpublished routes, issue the approach clearance only after the aircraft
is:
3. Established on a heading or **course** that will intercept the
initial segment at the initial approach fix, or intermediate segment at
the intermediate fix when no initial approach fix is published, for a
GPS or RNAV instrument approach procedure at an angle not greater than
90 degrees. Angles greater than 90 degrees may be used when a hold in
lieu of procedure turn pattern is depicted at the fix for the instrument
approach procedure. (See FIG 4-8-2.)"
EXAMPLE- Aircraft 1 can be cleared direct to CENTR. The intercept
angle at that IAF is 90 degrees or less. The minimum altitude for IFR
operations (14 CFR Section 91.177) along the flight path to the IAF is
3,000 feet. "Cleared direct CENTR, maintain at or above three thousand
until CENTR, cleared R-NAV Runway One Eight approach."
In this example, they are talking about RNAV procedures, but the UH-60
was navigating to the IAF using the GPS. If he didn't have GPS, he would
not have been on an unpublished non-radar route to the IAF and this
paragraph would not apply.
On the procedure in question, the only purpose of the "hold in lieu of
PT" is to allow an aircraft on the feeder from HCH to complete a course
reversal so that he can align himself with the final approach course. It
is not used to get a lower altitude and consequent descent gradient as
it might be on some course reversal procedures. The UH-60 was already
aligned within the parameters of the TERPS criteria (90 degrees). If the
route that the UH-60 flew just magically appeared as a published route
on this procedure, it would be required to be published as NoPT.
JPH
Ron Rosenfeld wrote:
On Wed, 25 Aug 2004 22:36:41 -0500, J Haggerty
then it would be up to ATC to indicate that the course reversal
was not necessary by stating that to the pilot.
By what authority can ATC do this, on this particular approach?
Chip has already indicated that ATC could not issue vectors to final for
this approach; and I am not aware of any authority given ATC to modify
published SIAP's by eliminating required course reversals, absent VTF or
timed approaches.
  #43
Old August 27th 04, 05:17 AM
Ron Rosenfeld
On Thu, 26 Aug 2004 18:10:00 -0500, J Haggerty
Then I don't understand you making up new rules.
is:
I think what you are proposing is potentially dangerous. The fact of the
matter is that there is no published route. There also is no TAA.
Are we supposed to believe that ATC is now able to apply all of the
appropriate TERPS criteria "on the fly" in off route areas, and also have
the authority to legally and safely allow pilots to circumvent the
published regulations and SIAP?
I think that more than a compilation of bits and pieces from several
regulations is required to justify this conclusion.
Not all obstacles are on our charts. At my local airport, the controlling
obstacle for the GPS and/or NDB 15 approach appears on no aviation charts
at all.
It may be that a TAA could be established around MINES, and then this
discussion would be moot. But with a TAA, we pilots know that the area has
been surveyed.
It may also be that local pilots who are familiar with the area can safely
(although not legally, in my opinion) circumvent the published approach.
I just don't think you have shown that ATC has the authority to make that
circumvention legal. And I don't buy the "bits and pieces".
--ron
  #44
Old August 27th 04, 01:16 PM
Not necessarily. Intercept angle is one of two criterion for publishing "NoPT."
The other is descent gradient.
  #45
Old August 27th 04, 03:29 PM
Chip Jones
"J Haggerty" wrote in message
news:65uXc.61810$wo.23863@okepread06...
I agree the books are spotty for GPS overlay procedures.
is:
[snipped]
Good points. However, FAAO 7110.65, paragraph 5-9-1 is the controlling
paragraph relating to radar vectors to FAC for Center controllers. 5-9-1d
says:
"d. EN ROUTE. The following provisions are required before an aircraft may
be vectored to the final approach course:
1. The approach gate and a line (solid or broken), depicting the final
approach course starting at or passing through the approach gate and
extending away from the airport, be displayed on the radar scope; for a
precision approach, the line length shall extend at least the maximum range
of the localizer; for a nonprecision approach, the line length shall extend
at least 10NM outside the approach gate; and
2. The maximum range selected on the radar display is 150 NM; or
3. An adjacent radar display is set at 125 NM or less, configured for the
approach in use, and is utilized for the vector to the final approach
course.
4. If unable to comply with subparas 1, 2, or 3 above, issue the clearance
in accordance with para 4-8-1 Approach Clearance."
In the case of every non-precision approach in my airspace, including RKW,
the FAC is not displayed on the radar scope. We fail the test at provision
#1. The weenie language that applies to this particular approach into RKW
clearly forbids the controller from vectoring to FAC. Even if the pilot can
fly this approach without the course reversal, it looks like Center ATC
can't clear him to do so. Too bad those DME arc's disappeared...
Thanks for the input, I've learned a lot.
Chip, ZTL
  #46
Old August 27th 04, 04:01 PM
Doug
Well, you have come up with a reason to do the hold, currency. I
wouldn't do it your way. If I am under an IFR flight plan, I pretty
much just do what the controller tells me to do (so long as it is
safe). I don't do any special requests. Why gum up the airspace? But
then, I get my currency while operating VFR, so it never comes up
much. There is enough confusion between pilots and ATC as it is
without adding training requests to IFR flight plans. Although I guess
if he's in a good mood and not busy, he'd probably go along with it.
Anyway, those mandatory procdure turns when you are already on the
approach course never made any sense to me. Rules that don't make
sense, shouldn't be there. This is because when we don't know the rule
(and who does know them all), we do it the sensible way. All law
should be based on common sense.
"SeeAndAvoid" wrote in message hlink.net...
"Doug" wrote...
As a pilot I see ABSOLUTELY no COMMON SENSE in having to
make a course reversal if I don't have to loose altitude and am on the
final approach course (or even within a few degrees of final approach
course) outside of the FAF. I mean, why do it? It takes time, burns
fuel, and increases risk.
I can. FAR 61.57c, IFR currency requirements. In the case of this
approach, the course reversal is a hold. I dont know for sure but
I bet that was the intent with this pilot, get credit for the hold AND
the approach. As a pilot there were times I wanted to do something
like this only for currency, but the controller couldnt understand
why I WANTED to hold at, usually, the missed approach point.
But I always would say "request the approach with a turn in holding
at XXXX" or something like that to make it real clear, not this
"full approach" stuff.
As a controller when I'm running approaches I'll get the request
for a hold that seems to have no reason behind it, then I remember
this currency requirement. Problem is there's not enough pilot
controllers, and even less that are IFR rated or current.
Chris
Steve Bosell for President 2004
"Vote for me or I'll sue you"
www.philhendrieshow.com
  #47
Old August 29th 04, 04:15 AM
J Haggerty
The route flown by the UH-60 was using Center's IFR altitude at 5000.
Descent gradient was not a problem, as the IAF altitude was also 5000.
  #48
Old August 29th 04, 05:03 AM
J Haggerty
Ron,
If you read the paragraph, you'll note that the requirement is that the
aircraft be on a route or vector to an IAF. It's not unusual for an
aircraft to be cleared direct to a fix even though there's not a
published route. ATC would be required to ensure the aircraft was at a
suitable altitude for IFR operations on this route, but the navigation
would be provided by the pilot, in this case using GPS.
The paragraph I quoted actually gives the authority for ATC to give an
approach clearance by clearing him direct to MINES at 5000. If the
intercept angle was greater than 90 degrees, then a hold-in-lieu of PT
would have to be published, and on this procedure there is one
published, but it's not needed in the example because a course reversal
is not needed. Note that we're talking about a holding pattern in lieu
of a PT, and not an actual PT. An aircraft flying the VOR from the
feeder fix would be required to complete the hold-in-lieu for course
reversal.
Stand-alone RNAV procedures are published either with a TAA or without a
TAA. If there was a TAA, then the controller would not have to provide
the 5000 altitude restriction if the aircraft was within the TAA area,
because he would be on a published portion of the approach and could use
Para 4-8-1 b subpara 1 and 2 as directed by 4-8-1 e instead of 4-8 b
subpara 3. The situation I'm talking about is using subpara 3. The
aircraft was using a route rather than vectors, so the rules regarding
vectors do not apply.
I didn't make up para 4-8-1 b.
is:
The paragraph is talking about **unpublished** routes. TAA's use a
different paragraph of the 7110.65.
No, they use the criteria contained in the paragraph shown.
at all.
True, but TRACONS and CENTERS have to have their charts approved by AVN
and they have to ensure the same IFR altitudes as the feeder routes and
TAA's. The TAA's and feeder routes don't normally depict obstacles either.
been surveyed.
Overlay procedures do not have TAA's. The GPS portion is treated just as
the paragraph above explains.
--ron
JPH
where to ask question about approach? J Haggerty Instrument Flight Rules 1 August 17th 04 06:30 AM
Canadian holding procedures Derrick Early Instrument Flight Rules 24 July 22nd 04 04:03 PM
Approach Question- Published Missed Can't be flown? Brad Z Instrument Flight Rules 8 May 6th 04 04:19 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 11:13 AM
Established on the approach - Checkride question endre Instrument Flight Rules 59 October 6th 03 04:36 PM
