Cambridge Utilities Available
Old June 7th 06, 10:17 PM posted to rec.aviation.soaring
Default Cambridge Utilities Available
Hi,
There have been a few issues with 302 flight log security failures this
year. Some of the failures can be avoided by making sure your 302 is
running the latest firmware (2.63) and by using the latest version of the
Cambridge 300 Utility (2.57) to download your flight logs to a PDA or PC.
Unfortunately, Cambridge has been unable to update the web page on which
they have their utilities. I have therefore made them available on my web
site he
http://www.cumulus-soaring.com/cai_downloads.htm
The 302 firmware file (version 2.63) has not changed in several years, but
the 300 Utility was updated only a few months ago to version 2.57 for PDAs
and version 2.56 for PCs.
The firmware version in the 302 is displayed at power-up on the LCD display
on the 302.
If you find that the 300 Utility shows that your flight log does not pass
the validity checks after download - please try again several times. That
will most likely solve the problem. If it does not solve the problem then
contact Gary Kammerer at Cambridge at662) 280-7610. It is almost always
possible to get a valid flight log out of the 302 - assuming that the 302
shows that it is properly sealed.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
Old June 7th 06, 11:15 PM posted to rec.aviation.soaring
Paul
Any plans to upgrade the firmware on the 302 or is it going ok and they only
will if there is a problem / bug?
I am using it in tandem with a 303 screen and a PDA running SeeYou Mobile
and its going fine. I guess most users would do something similar using CU
mobile. Strepla Pocket or Winpilot. Seeyou does regular updates fixing bugs
and adding features etc but Cambridge seems to be content as it is. Of
course I have no idea how upgradeable the 302/303 is and if SeeYou want to
supply the trick bits then I guess Cambridge have to do nothing.
Old June 8th 06, 12:19 AM posted to rec.aviation.soaring
Errr, would you care to explain that one?
Tony V
Old June 8th 06, 12:43 AM posted to rec.aviation.soaring
Paul,
My Ipaq has the utility file version 2.5.6.0 running,
so I downloaded the 'new' file.
The 'new' file, named '300 Utility iPAQ 257.exe' opens
up showing it is version '2.5.6.1'
Is version 2.5.6.1 supposedly the same as version 2.5.7?
What's up?
Thanks,
Ray Lovinggood
Carrboro, North Carolina
At 21:18 07 June 2006, Paul Remde wrote:
Hi,
failures this
sure your 302 is
available on my web
site he
on the LCD display
on the 302.
log does not pass
several times. That
It is almost always
Good Soaring,
Paul Remde
Old June 8th 06, 01:20 AM posted to rec.aviation.soaring
Ray Lovinggood wrote:
Paul,
My Ipaq has the utility file version 2.5.6.0 running, so I downloaded
the 'new' file.
The 'new' file, named '300 Utility iPAQ 257.exe' opens up showing it
From Paul's website:
Note: This is version 2.57 but the home screen in the software
incorrectly shows that it is version 2.5.6.1.
So, I think you now have 2.57.
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
Old June 8th 06, 01:58 AM posted to rec.aviation.soaring
Paul and Eric:
Duh.
Make note to self: R.T.F.S.
Thanks,
Ray Lovinggood
Carrboro, North Carolina, USA
Paul,
so I downloaded
the 'new' file.
up showing it
2.5.7?
the software
Change 'netto' to 'net' to email me directly
www.motorglider.org - Download 'A Guide to Self-launching
Sailplane
Operation'
Old June 8th 06, 02:25 PM posted to rec.aviation.soaring
Hi Paul,
That is a tough question to answer. If you have any issues with the 302
firmware then let us know so we can try to get them addressed.
Paul Remde
"Paul Buchanan" wrote in message
Paul
only
bugs
Old June 8th 06, 02:26 PM posted to rec.aviation.soaring
Hi Tony,
I'm not certain of the details.
Paul Remde
"Tony Verhulst" wrote in message
Tony V
Old June 8th 06, 02:27 PM posted to rec.aviation.soaring
Hi Roy,
I mention that minor bug in version 2.5.7 on my web site next to the link to
the file you downloaded.
Good Soaring,
Paul Remde
"Ray Lovinggood" wrote in
message ...
Paul,
What's up?
Thanks,
Ray Lovinggood
Hi,
failures this
sure your 302 is
available on my web
site he
on the LCD display
on the 302.
log does not pass
several times. That
It is almost always
Good Soaring,
Paul Remde
Another Cambridge 302 logger bug [email protected] Soaring 8 July 19th 05 04:05 PM
Commercial - Updated Cambridge 302A Paul Remde Soaring 2 December 16th 04 07:35 PM
Cambridge Instruments Ian McPhee Soaring 2 June 18th 04 10:14 AM
Cambridge Aero Explorer Fix Guy Byars Soaring 8 May 19th 04 03:04 AM
Updated IGC approval documents for Cambridge GNSS flight recorders Ian Strachan Soaring 0 August 27th 03 05:28 PM
