Excel formula for logbook
Old August 29th 04, 09:49 AM
Ben Jackson
In article m,
Wizard of Draws wrote:
I also wanted to comment that, for my version of Excel at least, it was
required for me to rename the cell that contained the cutoff formula. For
some reason, just referencing the default cell name made the formula not
work.
When you copy formula cells in Excel the default is to treat the other
cells referenced as relative, so that if you make 'B1' reference 'A1'
and then copy it to 'B2' it will reference 'A2'. To stop that you can
either name the cell or use $A$1 (the $ for each of the row and column
nails them down).
I suggested renaming because it even works across sheets (in case you
wanted the summary on a separate sheet) and the syntax for referring
to values in other sheets is ugly.
Ben Jackson
http://www.ben.com/
Old August 30th 04, 12:55 AM
Wizard of Draws
On 8/29/04 4:49 AM, in article nMgYc.201395$8_6.135186@attbi_s04, "Ben
Jackson" wrote:
In article m,
work.
nails them down).
Actually, I forgot I knew this from working with a freebie spreadsheet long
ago. But I'm not sure it had a rename function.
Elegant is always preferable.
I like the hide column feature too. Thanks.
Jeff 'The Wizard of Draws' Bucchino
Cartoons with a Touch of Magic
http://www.wizardofdraws.com
http://www.cartoonclipart.com
Lasher Renegade Formula V racer Information Curtis Scholl Home Built 1 February 27th 20 05:12 PM
Using Excel or Access to keep track of students/records? BoDEAN Instrument Flight Rules 5 October 2nd 03 05:07 AM
Millionaire at 31... on the Internet. Listen to how he's doing it. ower Home Built 0 August 2nd 03 10:23 AM
