GPS navigation
Old June 11th 06, 09:38 AM posted to rec.aviation.piloting
Default GPS navigation
Hello to all,
Do most modern aircraft rely on the GPS for navigation, and to what
extent do they rely on it?
And is it true that such aircraft's navigation systems use maps
'optimised' for GPS?
And finally, if I may, what level of positional accuracy must aircraft
relying on GPS for navigation work with at typical altitudes
(presumably 20,000 to 40,000 ft)? Are we talking tens of metres, or
over a hundred metres?
Thanks very much in advance.
Regards,
David,
England.
Old June 11th 06, 01:34 PM posted to rec.aviation.piloting
"David W" wrote:
Hello to all,
What kind of modern aircraft are you talking
about--bizjets...airliners...military?
What does 'optimised' for GPS mean?
Tens of meters or less.
What's behind your questions; what are you trying to get at? If you posted
that, you might get more suitable answers.
Dan
C172RG at BFM
Old June 11th 06, 01:45 PM posted to rec.aviation.piloting
In article .com,
define "modern"
No.
Currently, the accuracies required are over hundreds of meters.
The tightest restrictions on aircraft operations are currently those
in RNP-4 RNAV airspace. The aircraft must be laterally within
4 nmi of intended course 95% of the time, and have an unannunciated
loss of containment (i.e., break 8 nmi) with a probability of 10-5
per flight hour.
GPS accuracies in the tens of meters are only currently required for
approaches.
Bob Noel
Looking for a sig the
lawyers will hate
Old June 11th 06, 01:59 PM posted to rec.aviation.piloting
If you mean "do most modern pilots rely on GPS for navigation?", the answer
is probably "yes". Modern aircraft do still come with a variety of
navigational equipment, but everything in the new panels is centered around
GPS.
Not sure what you mean -- but most GPS' have built-in moving maps that
display your position relative to the "real" world, as depicted on the map.
GPS positioning is accurate to within 10 meters, often less. That's way
more accurate than any aircraft operating in the flight levels needs.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old June 11th 06, 06:32 PM posted to rec.aviation.piloting
"David W" wrote in message
Hello to all,
Regards,
David,
England.
As far as what lateral positional accuracy is AVAILABLE using GPS, about
thirty meters, about 3 meters utilizing WAAS.
Hello, my name is Mike, and I am an airplane addict...
Old June 11th 06, 06:55 PM posted to rec.aviation.piloting
Hi Dan,
Sorry, my questions could have been better posed.
I had primarily airliners and military aircraft in mind, but I didn't
state it (as would have been helpful).
I'm not sure. Somebody with whom I am having a 'debate' has asserted
that there is an altitude-dependent error component (if I may call it
that) on positions determined by GPS (and I presume that this alleged
error component affects the horizontal component of a 3D position, as
well as vertical (altitude) component). In his own words:
"GPS is optimised for sea level, Blanchefort [a mountaintop ruined
castle] is 467 metres above sea level, couple this with a slant range
to a satellite of several thousand miles and the curvature of the earth
and you have error. At least up to 100 metres..."
I personally can find no evidence which supports his claim that a) GPS
is optimised for sea level, or b) GPS coordinates obtained at a few
hundred metres above (mean)
sea level are affected by his alleged altitude-induced error.
I replied (verbatim quote - please excuse the sarcastic tone!):
"This is really bad news. Modern aircraft - many of which rely heavily
on GPS for navigation - are in big trouble then, aren't they? I mean,
if the error at just 467 metres above MSL is ''at least up to 100
metres'', then surely it must be several kilometres by the time we get
up to altitudes like 30,000 ft., right?"
His reply (with some non-essentials removed):
"Aircraft ... are using a map optimised to the GPS system and this is
the key point which seems to be passing you by."
I hope that that is sufficiently answered above. I didn't want to
burden this group with extensive background information and endless
quotes from this slightly silly debate!
Regards,
David,
England.
Old June 11th 06, 07:33 PM posted to rec.aviation.piloting
It is theoretically true that altitude can affect the geometry of the GPS
receiver and satellites being received in such a way as to increase error.
However, the orbital altitude (10,988 nautical miles) is so much higher than
flight altitudes (usually up to 9 or 10 nautical miles at the very most, and
for commercial airliners 6 nautical miles give or take is more typical),
it's hard to imagine any significant error being caused by that.
Even in the most extreme case, an airplane is only going to climb high
enough to change the distance to the satellite by 0.05-0.10%. And this
assumes the satellite is directly overhead; when it's not, the distances are
even greater and altitude even less significant.
It's important to note: the GPS system doesn't actually care about
elevation. It cares about distances and calculates a 3D position based on
measured distances (simplistically stated, anyway). If altitude was a
significant problem, then so would any variation in distance from the
receiver to the satellite, and the change in that distance due to the
relative angle in the sky of the satellite is MUCH greater than any change
in elevation possible by an airplane. If altitude caused a problem, the GPS
would be incredibly unreliable all the time, since the satellites are rarely
directly overhead.
Not that your debate partner will see this. He'll just say something about
the system being "optimised" for the effects of satellite orbits on the
distance between receiver and satellite. But it's true, nonetheless.
In his own words:
I still don't know what it means for GPS to be "optimised for sea level".
It would be entertaining (though probably not educational) to learn what the
guy believes was done to "optimise" GPS for sea level.
Certainly is boggles the mind to think that elevation gain results in a
1-to-5 error ratio (that is, 1 unit of error for every 5 units of elevation
gain). That's a remarkably fragile system he's describing, and it certainly
doesn't apply to GPS as it exists today.
More BS. "A map optimised to the GPS system"? Again, even pondering what
this could mean is bewildering. Is he saying that, while there's some large
error, it's always a known error and so can be compensated for with the map
system? Why wouldn't a GPS receiver simply be designed instead to use this
known error and correct the calculated position based on that?
Of course, that's all theoretical. In reality, there's no "known error"
(not in the sense that one knows exactly the magnitude AND direction of the
error), and no reason to "optimise" the map "to the GPS system". You get
the same map on the ground as you do aloft, and the GPS simply plots your
position on the map.
It's true that there are different mapping systems in use, but they have to
do with how one projects the geometrically perfect information from GPS onto
the geometrically imperfect planet we live on.
Yes, I'd agree it's at least "slightly silly". I usually just put
people who write stuff that ridiculous into my killfile.
Pete
Old June 11th 06, 08:06 PM posted to rec.aviation.piloting
"David W" wrote:
[snip]
Nonsense. Your opponent in the debate is a ninny.
[snip]
Utter twaddle. There are no such maps.
posted
No problem. You came to the right place after your opponent introduced his
bogus aviation arguments.
Dan
C172RG at BFM
Old June 11th 06, 08:43 PM posted to rec.aviation.piloting
Nonesense. Aircraft that are equipped with GPS use the same charts that
non-GPS aircraft use.
The FAA has a pretty good introduction to GPS as use in aviation in the
Airman's Information Manual. The section you want is
http://www.faa.gov/ATpubs/AIM/Chap1/aim0101.html#1-1-19. If that doesn't
get you direct to the right paragraph, search for "1-1-19. Global
Positioning System (GPS)".
Old June 11th 06, 08:44 PM posted to rec.aviation.piloting
There is really no slant range in GPS Navagation. It is Triangulation &
Timing.
You need at least 3 satellites in view to get an accurate 3D position.
Distance is
determined by accurate timing of how long it takes an encoded signal to
reach
the GPS reciever. Thus with known distances from 3 satellites you can
calculate or triangulate (within the tolerance) the exact position of the
GPS reciever. This position
includes altitude, although altitude in my experience seems to be less
accurate. But for all I know the GPS altitude may be more accurate than
altitude read from my altimeter, which is
corrected for non standard pressure. Hope this short explanation helps
Mark
posted
Regards,
David,
England.
ADF/VOR navigation question John Bell Simulators 0 December 23rd 03 04:30 PM
