I've been watching this discussion in the sci.geo.satellit-nav newsgroup,
and my reaction to your friend's ideas is "What an idiot." Bob Gardner "David W" wrote in message oups.com... Hello to all, Do most modern aircraft rely on the GPS for navigation, and to what extent do they rely on it? And is it true that such aircraft's navigation systems use maps 'optimised' for GPS? And finally, if I may, what level of positional accuracy must aircraft relying on GPS for navigation work with at typical altitudes (presumably 20,000 to 40,000 ft)? Are we talking tens of metres, or over a hundred metres? Thanks very much in advance. Regards, David, England. |
Bob Gardner wrote:
I've been watching this discussion in the sci.geo.satellit-nav newsgroup, and my reaction to your friend's ideas is "What an idiot." My post to that group requesting advice and comment was way too long; I imagine it made for quite tedious reading, which I don't think helped my case as much as it might have done. But I'm happy with the replies (in that group and certainly here), overall :-) My opponent, even though he evidently knows next-to-nothing about the GPS, or GPS survey, is trying to discredit a set of GPS coordinates that has cost me time, energy and lots of money to obtain (obtained with diligence and after a sufficient number of hours of research (in my opinion)). And he thinks I should use theodolites and trig points instead of GPS. Thanks to all that have replied. Regards, David, England. |
To address the question of optimized maps for aviation use, if that indeed
is relevant to this discussion, he should go to an outlet that sells aviation maps and ask for a GPS-optimized map. I think that he will be surprised. Bob Gardner "David W" wrote in message oups.com... Bob Gardner wrote: I've been watching this discussion in the sci.geo.satellit-nav newsgroup, and my reaction to your friend's ideas is "What an idiot." My post to that group requesting advice and comment was way too long; I imagine it made for quite tedious reading, which I don't think helped my case as much as it might have done. But I'm happy with the replies (in that group and certainly here), overall :-) My opponent, even though he evidently knows next-to-nothing about the GPS, or GPS survey, is trying to discredit a set of GPS coordinates that has cost me time, energy and lots of money to obtain (obtained with diligence and after a sufficient number of hours of research (in my opinion)). And he thinks I should use theodolites and trig points instead of GPS. Thanks to all that have replied. Regards, David, England. |
![]() "David W" wrote My opponent, even though he evidently knows next-to-nothing about the GPS, or GPS survey, is trying to discredit a set of GPS coordinates that has cost me time, energy and lots of money to obtain (obtained with diligence and after a sufficient number of hours of research (in my opinion)). And he thinks I should use theodolites and trig points instead of GPS. Ask him how modern surveyors locate points on property. Hint. GPS. -- Jim in NC |
In article 0o_ig.19660$8q.17433@dukeread08, "Mark Manes"
wrote: You need at least 3 satellites in view to get an accurate 3D position. 4 satellites unless you already know GPS time or know your altitude. -- Bob Noel Looking for a sig the lawyers will hate |
Somebody with whom I am having a 'debate' has asserted
that there is an altitude-dependent error component The distance to a station using DME is "slant range", the distance to that same station using GPS is a projection, so some slight error is introduced there. It is possible that your friend is mis-interpreting or mis-applying this tidbit. "Aircraft ... are using a map optimised to the GPS system and this is the key point which seems to be passing you by." There are several geoids in use, and the choice of geoid may introduce position errors. A geoid is a surface of equal gravitational potential (a "mean sea level") and is an idealized surface - the real earth has bumps and wiggles which are modeled imperfectly (or not at all) in some models. Your friend may also be mis-applying this tidbit. Jose -- The price of freedom is... well... freedom. for Email, make the obvious change in the address. |
David,
GPS is optimised for sea level, Blanchefort [a mountaintop ruined castle] is 467 metres above sea level, couple this with a slant range to a satellite of several thousand miles and the curvature of the earth and you have error. At least up to 100 metres..." That's just plain BS. Just one example: The space shuttle uses GPS for navigation. That should be plenty high to convince the poster otherwise. -- Thomas Borchert (EDDH) |
Mark,
You need at least 3 satellites in view to get an accurate 3D position. 4. You need to correct for receiver clock error. -- Thomas Borchert (EDDH) |
Thomas Borchert wrote:
That's just plain BS. Just one example: The space shuttle uses GPS for navigation. That should be plenty high to convince the poster otherwise. Would an ordinary GPS receiver (say, my $99 eTrex) work on the shuttle? I can see how the basic principles are the same, but I'm guessing my eTrex wouldn't be happy with the speeds the shuttle is doing. |
Roy,
I can see how the basic principles are the same, but I'm guessing my eTrex wouldn't be happy with the speeds the shuttle is doing. Many cheaper GPS receiver do indeed have a speed limit. Is it given in the specs for the eTrex? -- Thomas Borchert (EDDH) |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
ADF/VOR navigation question | John Bell | Simulators | 0 | December 23rd 03 04:30 PM |
