STAR questions Chicago Midway
Old June 12th 06, 09:35 PM posted to rec.aviation.ifr
Default STAR questions Chicago Midway
Protected airspace at O'Hare (for instrument approach and MAPs')
Al
"TMcDonald" wrote in message
news:ybWdnVGLQd3jERbZnZ2dnUVZ_vqdnZ2d@wideopenwest .com...
This may be moot by now but don't worry, you're most likely to get the MDW
4 DP
I've been flying out of MDW for six years and have never been assigned the
Cicero departure procedure. I always get the MDW 4 and an assigned heading
depending on direction of flight -- they don't want you wandering into
ORD's airspace.
Interestingly you'll probably never get the ILS to 13C either - although
you may get the ILS4R circle to 13C. The only approach you'll get to a
RW22 is a visual or ILS 31C circle to 22.
Tom McDonald
ATP/A&P/IA
www.aviatortom.com
"akiley" wrote in message
Hi all. I might attempt a flight from Ann Arbor KARB, to Chicago
Midway KMDW in a few days.
I have a question about the Midway Cicero two departure. There is an
"obstacle" and a "vectors" version of this DP. Lets say I get that DP
as part of my clearance, with a departure on runway 4R. The obstacle
DP say "North bound departures assigned headings 360 degrees clockwise
thru 080 degrees fly runway heading to 1.2 DME, turn right, climb on
heading 100 degrees until leaving 2400, thence via tower assigned
hdg/vector to assigned route." The victors DP say the same except no
mention of the DME.
I'm curious how this works and how tower would likely issue my takeoff
clearance. But what if my assigned heading is 150 degrees. I guess I
ignore the part of the DP that wants a turn to 100 degrees. But for
obstacle clearance I do runway heading till 1.2 DME before tuning to
150 degrees.
If my assigned heading is 040 degrees, I would fly rwy hdg till 1.2
DME, turn right to 100 degrees until leaving 2400, then turn back to
040 unless I get to 2400 feet before 1.2 DME??
Lastly, how would tower likely phrase my initial instruction? Seems
this would be a good candidate for putting NO DP in the comments
section of my flight plan! ... Aaron
Old June 14th 06, 09:45 AM posted to rec.aviation.ifr
But even the MDW 4 SID has the dogleg if the takeoff is from runways 4
and the assigned heading is northbound. Are you saying that they never
assign northbound headings, or never assign runways 4L/R for takeoff?
The bit about ORD in your message implies one of those.
Midway Airport in Chicago Briefly Closed Today... Jay Honeck Piloting 0 February 24th 06 07:00 PM
New Flight School At Chicago Midway Airport AIR ADVENTURE82 Piloting 1 January 16th 04 12:24 AM
New Flight School At Chicago Midway Airport AIR ADVENTURE82 Aviation Marketplace 0 January 15th 04 11:53 PM
New Flight School At Chicago Midway Airport AIR ADVENTURE82 Naval Aviation 0 January 15th 04 11:52 PM
New Flight School At Chicago Midway Airport AIR ADVENTURE82 General Aviation 0 January 15th 04 11:52 PM
