I'm trying to rev up CE v2 to show airspace for the CCSC meet.
I can load and see the CCSC TPs with no problem ... however, I can/t get SUA to show up on the map. I am using the conus.txt open-air file supplied by the TP exchange (thanks, John L.) So, I only have two files identified for CE ... the CCSC TPS and ConUS SUA ... I am in simulator mode ... I have gone to the airspace tab and set all the airspace types to 'show'. I have also has the IPAQ hooked to my flight computer, but getting GPS info does not seem to help either, so I am cautiously assuming that being in simulation mode is not the problem. BTW, the airspace list seems to show all the airspace in the US starting with SFC ... i.e. those furtherst away seem to be listed first, although the distance field to all seems to be zero . Then, depending on what I do (I change something but haven't yet been able to isolate the causal change/sequence) the airspace list will show nothing. Feel free to send me suggestions ... related to the problem ... :-) ... or even test files ... thx. KK |
Im facing a similar problem with XCsoar, although for some reason it is
not even accepting my SoCal.tpl file as input. I think that in SIMULATION mode it puts your GPS location as some spot that is not in the vicinity of your topo/map coverage area and hence you see no airspace markings since you do not have airspace coverage there in your uploads. Try hooking up to your GPS and PDA in FLY mode and let it get a fix for you within your map boundaries. Im a GPS/PDA newbie so by no means is that a definitive answer....just thought I'd relate my own experiences. Ray Ken Kochanski (KK) wrote: I'm trying to rev up CE v2 to show airspace for the CCSC meet. I can load and see the CCSC TPs with no problem ... however, I can/t get SUA to show up on the map. I am using the conus.txt open-air file supplied by the TP exchange (thanks, John L.) So, I only have two files identified for CE ... the CCSC TPS and ConUS SUA ... I am in simulator mode ... I have gone to the airspace tab and set all the airspace types to 'show'. I have also has the IPAQ hooked to my flight computer, but getting GPS info does not seem to help either, so I am cautiously assuming that being in simulation mode is not the problem. BTW, the airspace list seems to show all the airspace in the US starting with SFC ... i.e. those furtherst away seem to be listed first, although the distance field to all seems to be zero . Then, depending on what I do (I change something but haven't yet been able to isolate the causal change/sequence) the airspace list will show nothing. Feel free to send me suggestions ... related to the problem ... :-) ... or even test files ... thx. KK |
| New release FlywithCE 2.0 | Tim Mara | Soaring | 0 | March 4th 06 04:48 PM |
| New Version FlywithCE Navigator PDA Software | Tim Mara | Soaring | 4 | January 25th 06 11:47 PM |
| flyWithCE news release - April 2004 | Uros Podlogar | Soaring | 0 | April 7th 04 08:27 PM |
| ANN: flyWithCE news release - February 2004 | Uros Podlogar | Soaring | 0 | February 15th 04 01:50 PM |
| Commercial - flyWithCE Software | Kevin Christner | Soaring | 1 | August 7th 03 11:54 PM |
