Learning from an owner annual
Old June 13th 06, 02:45 AM posted to rec.aviation.piloting,rec.aviation.owning
Default Learning from an owner annual
Jay Honeck wrote:
So next year do the bulk of the annual on the 31st of March and screw in the
last nutplate on the 1st of April, when the signing takes place. Following
year 30th of April and the 1st of May. Now your annual is due in May. Or
June. Or July. Whatever fires your rocket.
We had actually started down that road, and realized that we were
moving our annual dangerously close to the sancrosanct Oshkosh Month of
July. We also didn't want to lose and of our precious warm weather
flying to an extended annual inspection.
The thought of missing OSH because of something stupid like waiting for
a part has caused us to actually move the annual UP a month this year,
just to get it safely back into the bad flying weather of March.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
But Jay, you miss the fun of test flying the airplane the night before
you leave for OSH!! Of course a nice little test flight not show you are
DUMPING fuel into the engine compartment (damn stuff vaporizes and you
can't see it on a hot engine). Made our shortest leg to OSH award.
Found and A&P and the problem, were on our way in half an hour. I HATE
annual before big trip stuff.
Annual now due in April. Might go to March next year, but it's warmer
in VA!
Margy
  #82
Old June 13th 06, 02:47 AM posted to rec.aviation.piloting,rec.aviation.owning
Jay Honeck wrote:
The thought of missing OSH because of something stupid like waiting for a
part has caused us to actually move the annual UP a month this year, just
One word: Courtesy van!
We drove into OSH from 1984 through 1998. Nothing against it, but it's
just not the same as flying and camping in the middle of 12,000 other
aircraft campers.
THAT is OSH, to me, now. The airshows and stuff are still fun, but the
North 40 is what grass-roots aviation is all about. So, we try to
make sure that Atlas is in tip-top shape every July, for that long, 90
minute flight back to Wittman Field...
Jay Honeck
Iowa City, IA
Pathfinder N56993
And we couldn't party in the parking lot
  #83
Old June 14th 06, 05:03 PM posted to rec.aviation.piloting,rec.aviation.owning
You've never tail-gated before?
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #84
Old June 15th 06, 12:28 AM posted to rec.aviation.piloting,rec.aviation.owning
at OSH? NEVER
  #85
Old June 15th 06, 02:40 AM posted to rec.aviation.piloting,rec.aviation.owning
Shouldn't that be tail-Gator'ed?
  #86
Old July 4th 06, 08:48 PM posted to rec.aviation.owning,rec.aviation.piloting
Default Stuck Screws, was: Learning from an owner annual
Back when I used to work on airplanes as an avionics tech, someone showed me
a neat trick for getting stuck screws loose. When you find a screw that
doesn't want to come loose, or that the screwdriver tip cams out of, put a
little valve grinding compound on the screwdriver tip. Valve grinding
compound comes in a tube at auto parts stores, and has a fairly coarse grit
in it. It gives your screwdriver tip much better traction in a screwhead
that's already been a little damaged, and does a great job of preventing the
screwdriver tip from camming out. There's also something similar available
called "Screw Grab" that I found at a hardware store locally, that has the
same grit in it but in a thinner solution. It works just as well. I rarely
have to drill out screws since I started using those compounds.
Scott Wilson
  #87
Old July 4th 06, 10:26 PM posted to rec.aviation.owning,rec.aviation.piloting
Peter Duniho
wrote in message ...
[...] Valve grinding
grit
I'm sure you'll get replies saying (in effect) "you didn't know that?" But
thanks for posting the tip anyway. Lots of the rest of us didn't know it
either.
  #88
Old July 4th 06, 11:18 PM posted to rec.aviation.owning,rec.aviation.piloting
John Kimmel
grit
either.
The Phillips ACR bit sold by Snap-On has serrations which reduce "cam-out".
John Kimmel
remove x
"He's dead, Jim."
Learning from an owner annual Robert M. Gary Piloting 88 July 5th 06 07:07 AM
2006 Annual -- My 8th Owner Assisted -- Update Jay Honeck Owning 14 March 27th 06 07:11 PM
molding plexiglas websites? [email protected] Owning 44 February 17th 05 09:33 PM
Christmas Annual - long drivel Denny Owning 23 December 31st 04 08:52 PM
Annual Costs - Take the Pledge Roger Long Owning 25 February 1st 04 03:41 PM
