This ain't your grandpa's V-22
Old June 15th 06, 03:07 AM posted to rec.aviation.military.naval
Default This ain't your grandpa's V-22
KENG wrote:
Gord Beaman wrote:
"Diamond Jim" wrote:
"Henry J Cobb" wrote in message
http://www.nbcsandiego.com/news/9366221/detail.html
"This ain't your grandpa's V-22," said Maj. David Lane, of the U.S.
Marine Corps. "This aircraft is phenomenally safe. I've got a family. I
wouldn't strap myself in if I wasn't comfortable with where it stands
and where it was at."
Has it really been in development that long? ;-)
-HJC
I think it has been in development forever, :-) at least it seems like it.
DJ
Probably a lot longer than you're indicating (or that you
know!)...it seems most odd that it's NEVER mentioned in any info
I've seen but this aircraft was designed and flown by Canadair in
Montreal in the EARLY SIXTIES!...it was known as the CL-84
Dynavert. First flew in 1965.
http://tinyurl.com/rk2tj
I suppose you believe that the development of the SR-71 started on a
windy day at Kitty Hawk too, eh?
KenG
Don't seem to know much about aircraft do you?...
-Gord.
(use gordon in email)
Old June 15th 06, 05:17 AM posted to rec.aviation.military.naval
Gord Beaman wrote:
"Joe Delphi" wrote:
"Gord Beaman" wrote in message
And then in the 1970s Bell designed and built the XV-15 tilt rotor
demonstration aircraft for NASA research.
http://www.dfrc.nasa.gov/gallery/Photo/XV-15/index.html
JD
The XV-15 did not tilt the wing (only the engine pods at the
wingtips) as both the CL-84 and the V-22 do.
Sorry Gord, while the CL-84 was a tiltwing, both the XV-15 and V-22 are
tiltrotors -- the wing stays put when the nacelles rotate. See:
http://www.navair.navy.mil/v22/index...action=gallery.
among many other sites. The vertical 'wing' section you can see in some
shots when the nacelles are vertical are the large flaps, which droop
something like 85 degrees to minimize vertical drag (Dv) when in
helicopter mode.
Guy
Old June 15th 06, 07:40 PM posted to rec.aviation.military.naval
JD
helicopter mode.
Guy
Yes, you're right, I stand corrected...it 'was' the flaps that
misled me...(your URL didn't work btw - but I found it in Google)
Thanks for the info sir...
-Gord.
Old June 15th 06, 09:40 PM posted to rec.aviation.military.naval
-HJC
DJ
KenG
I guess you didn't catch my note of sarcasm, eh?
Old June 15th 06, 10:17 PM posted to rec.aviation.military.naval
-HJC
DJ
KenG
Well, of course I did, but there's sarcasm and then there's
silly...which catagory do you think your remark was in?...
-Gord.
Old June 15th 06, 11:47 PM posted to rec.aviation.military.naval
-HJC
it.
DJ
Bell has worked on the tilt rotor since the late 40's.
This one took to the air in the mid 1950's.
http://www.vstol.org/wheel/VSTOLWheel/BellXV-3.htm
Old June 16th 06, 01:20 AM posted to rec.aviation.military.naval
-HJC
DJ
KenG
Ok, ya got me there.
Old June 16th 06, 03:01 AM posted to rec.aviation.military.naval
Sorry that this went so far...I don't usually do this, sorry.
-Gord.
Old June 16th 06, 11:13 PM posted to rec.aviation.military.naval
NP
